Question about Nikon COOLPIX P4 Digital Camera
My screen is blank on all modes except playback and setup
My screen goes blank on all modes.all black though i do get the menus.if i want to see the pictures i have already taken,i can still see them but the minute i try to change the mode its black again.the start up screen still does come on so i know it isnt a problem with the lcd screen.have tried changing all possible settings with no solution.please help! i'm on holiday and my camera isnt working!
If you can playback captured images ok but in capture mode your screen goes blank and taken shots are black then the CCD sensor in your camera is faulty and has to be replaced. Nikon agent -if you can find one- will do this for you but it may be uneconomical repair on this entry level model.
Posted on Sep 14, 2007
What causes DTV mode to not work.
why do you want to use dtv mode anyway . if everything else works .
Oct 30, 2015 | Vizio P50HDTV10A 50 in. Plasma HDTV
Olympus u820 image distortions colour and form
One answer time for a new camera the cost to repair is about the same as new.
Mar 15, 2017 | Olympus Stylus Stylus 820 ยต Digital 820...
LCD Screen
Your camera is working exactly as SLRs have worked for the first half-century since their invention. You frame the picture through the viewfinder then take the shot. The display is for menu settings and reviewing pictures after they've been taken. Newer DSLRs will let you use the display for picture-taking (and take videos) but the A200 belongs to the previous generation.
Mar 26, 2014 | Sony Alpha DSLR-A300 Digital Camera
My Nikon Coolpix s4 shows no picture on screen but just black. No image.
I wish I could solve as I have the same problem. The LCD shows the menus settings but does no display the picture image - same whether in camera mode or playback mode. Please help.
echorey@hotmail.com
Oct 14, 2010 | Nikon Coolpix S4 Digital Camera
I have a cannon sd1000 , bought 1 month back. suddenly its stopped capturing pictures. i.e while in shot mode the display is black and not showing and capturing the image.but able to access al the menus....
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 17, 2009 | Canon PowerShot SD1000 Digital Camera
Canon SD1000, screen blacked out and takes black pictures
try taking the batteries and memory card out let it set and put everything back in it ang cut it on
Jun 18, 2009 | Canon PowerShot SD1000 Digital Camera
Panasonic Lumix DMC FX12
HI,
It's impossible to turn the camera off. Only way is take out the battery.
No button warks, but I can change the shooting mode and turn playback, but I can't change the image in playback mode.
Please, help me to solve this problem.
I think, the camera needs to be restarted, but how to do that?
Thanks a lot.
Jun 17, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
Panasonic DMC-TZ1 operates in Playback mode only
The position from the dial wheel is not corresponding with the electrical position. If you can do it by yourself you can adjust it and tighten the midscrew from the dialwheel
Regards, Rob NL
Apr 20, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon COOLPIX P4 Digital Camera Logo
338 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
