Question about HP Compaq d530 PC Desktop
Does my d530 CMT have a SATA connector?
My d530 CMT came with a 40 GB Maxtor DiamondMax Plus 8 ATA/133 HDD, which I'm told is an IDE drive. What's puzzling is that I've got two different types of plugs on the same cable supplying power to the HDD. A total of 6 white plugs labelled P1 through P6 that have the 4 wire setup. And 2 black plugs on the same cable attached to nothing, labelled P4-1 and P5-1. These two black plugs have a narrow multiple strand socket, like a small serial plug.
(1) Are the black power plugs used for SATA drives?
(2) Does this mean my d530 supports SATA drives that are faster than the ATA/133 variety?
(3) what kind of SATA socket on the mobo should I look for?
(4) Geesch - anyone have a diagram of a d530 mobo?
Thanks again guys,
Mark
  • 1 more comment
  • Mark
    Mark Dec 29, 2008
    Thanks! But I've scoured this website and HP's all afternoon trying to find a mobo diagram for the d530 - and can't. Does that mean that they used a zillion different boards from as many manufacturers? If you can find a diagram I'd be surprised - and indebted!
    Mark
  • Mark
    Mark Jan 06, 2009
    Another poster sent me a document titled, "New Key Technologies and Features of HP Compaq Business Desktop d530 Series" from "HP Confidential" published in May 2003.
    "Although the 865G chipset does support SATA, HP engineering does not believe the entire solution [is] ready for mainstream corporate deployment. Essentially, the current maturity of the SATA subsystem (controller/driver/HDD) does not meet HP’s robustness and error recovery requirements and hence will not be made available until after the
    d530 launch. The HP d530 series products will be "SATA ready" at launch. A customer can purchase
    a third party SATA HDD and cable and expect some functionality. This allows customers to begin cursorary SATA testing."
    I suspect "some functionality" refers to the d530's SATA controller allowing speeds of only 150 bts/sec. roughly the same as the PATA/133 standard. To get the current SATA 300 drives to be recognized, jumpers have to be set to slow the speed to the 150 bts/sec the controller can handle, likely voiding the drive's warranty. As well as the hassel of updating the BIOS as you state.
    Although it would be neat to push this venerable old machine to it's limits by running a comparatively slow, first generation SATA drive, there would be little if any speed advantage. So in the end I decided to stick with a well tested WD Caviar 160 gb PATA/133 drive. I figure I'm saving myself the trouble of making BIOS changes I don't fully understand. Anyway, by the time I need a newer machine, 160 gb thumb drives might be out, putting the need for a SATA drive in question anyway!
    How would you rate my decision?
    This has been a real fascinating exercise.
    Thanks guys.
    Mark
  • Mark
    Mark Jan 07, 2009
    Gary - thanks alot. Got the WD 160 gb PATA/133 yesterday - learned to set the jumper on both the master and new drive to "CS" (neat - so when it's time to switch the old C drive to slave and new one to master it's just a matter of swapping their position on the serial cord). Then I followed the easy steps to initialize and format the new drive. And bingo - worked flawlessly.
    Truthfully, I'm a little disappointed I don't have a SATA drive - but I didn't have any headaches either. And for what I do, the 2nd IDE drive will be adequate.
    Two new things though - what's a good, i.e. free, software that'll copy my operating system on the new drive? Someone posted that Seatools by Seagate had a good mirrowing function - I couldn't find that under "Tools" - but I did discover my old drive has 57,000+ hours of operation!
    And second, I've got a digital video card/error message issue - that's described in a new message.
    Thanks again for your interest in all this Gary. The level of expert help I'm getting here is hard to find anywhere.
    Mark
    Novelist:
    Scholar:
  • 72 Answers
Answers to your questions:
1. Yes
2. Very likely
3. a Google search should show you what the connectors look like.
4 HP/Compaq do a good job of providing documentation. Go to hp.com and put in your system information. You should be able to locate motherboard diagrams there. If you can't let me know and I'll try to locate them.
Posted on Dec 29, 2008
  • honest1abe
    honest1abe Dec 30, 2008
    Nice job by Cytherian. I knew the information had to be somewhere.
    Nice detective work.
    Novelist:
  • 124 Answers
Hello Mark, the D530 CMT does support SATA drives. You can reference further details in these documents:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00059137/c00059137.pdf
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00072736/c00072736.pdf
The SATA connector looks like this:
http://images.tigerdirect.com/itemdetails/psu-5pinsata-small.jpg
http://images.tigerdirect.com/itemdetails/PATA-SATA-Module/sata-cable-logo.jpg
I can't recall if the plugs in the D530 are black, but you should be able to tell from the diagrams if they are the right ones (they won't fit otherwise). The older IDE style connectors for Ultra ATA are slower, so you'd definitely want to leverage SATA for better throughput.
http://static.tigerdirect.com/pdf/SerialATA_comparison_UATA_Technology.pdf
  • 2 more comments
  • Gary
    Gary Jan 05, 2009
    NOTE: On the power cables, you will see a SATA power connector. It is black
    and about half as thin as the standard 4 pin power connector. On the
    left side of the motherboard, you'll see a very small circular
    component with a yellow dot on it, labeled for "CPU Reset". On either
    side of this are the SATA motherboard connectors. The one on the left
    is slot "0", which is the one you would use.
    I can't find a motherboard diagram, but the components are well labeled--you should be able to find whatever you need. Here's a hardware reference document that may also help:
    http://h20000.www2.hp.com/bc/docs/suppor...
  • Gary
    Gary Jan 05, 2009
    Here's another hardware reference document. There isn't a motherboard diagram, but you really don't need one. You should be able to tell what is what, because everything is labeled. And you can always refer back to the manual for further information.
  • Gary
    Gary Jan 06, 2009
    Good information uncovering there, Mark. I didn't realize that SATA
    has had different supported controller speeds. But it does make sense,
    seeing the timing of SATA and the unveiling of the D530 CMT. You could
    of course buy a PCI SATA controller card, if indeed you wish to
    leverage the data throughput. However, if your needs are unlikely to
    push it, you made a good decision with the IDE drive.
    Later on, you can always acquire an external drive. I did and it
    performs extremely well. I use it for large media files and backups.
    ~Gary
  • Gary
    Gary Jan 08, 2009
    Hi Mark,
    I'm glad to hear the new drive is working very well for you. :-)
    There
    are a variety of solutions available to mirror an entire disk drive,
    sector by sector. Most are commercial and cost some $$. I've heard of
    one called EASEUS Disk Copy, that is free.
    http://www.download.com/EASEUS-Disk-Copy...
    I've not used it so I can't guarantee that it'll be fool proof. But
    when you're starting out with a completely new drive it can't hurt to
    give it a shot (if it doesn't work, just reformat and use something
    else like Symantec Utilities).
    Once I replace my PSU, I'm going
    to mount an existing 250Gb drive I have into my D530 CMT. This should
    hold me for a while... but if I decide to go for another drive, I may
    go with SATA. For just $20, you can buy a Rosewill SATA PCI controller
    card with one internal SATA connector and one external. Not a bad deal:
    http://www.newegg.com/Product/Product.as...
    Cheers,
    ~Gary
My Maxtor DiamondMax Plus 9 80GB ATA/133 HDD with a X-Media USB2.0 TO IDE & SATA cable adapter
Check (under high light) flat IDE cable pins on the mini-board. Many pins, and many chance to loose contact.
Feb 10, 2014 | Computers & Internet
Hi,I've an external case (diamondmax 11 Model:6H500F0)--500GB SATA 3.0GB HDD. And I wanna to activate it,but I Dont have the Installation CD,plz I need your help URGENTLY. (I've an widows XP for my...
Maxtor DiamondMax 11 is a SATA Hardisk and you need SATA External Case. After adding the Harddisk, all you have to do is connect it to the system via the cable of the external case. There is no need for additional drivers/ CD as all the external harddisks are 'plug and play'and the Operating System detects them automatically.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Maxtor DiamondMax 11 400GB 7200rpm 133MBps...
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax 10
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Is the maxtor 6y120p0 a ata or sata format
Maxtor DiamondMax Plus 9 120GB 7200RPM IDE Ultra ATA-133 3.5-Inch Internal Hard Drive Mfr P/N 6Y120P0
thanks and regards
kindly rate this solution
Oct 28, 2009 | Computers & Internet
My hard drive is going bad. So says my HP Compaq dc7100 SFF
Instead of posting here, why don't you look for a dealer.
You can buy hard drives just about anywhere now - and it doesn't have to be Maxtor.
Oct 18, 2009 | Maxtor DiamondMax Plus 8 40 GB Hard Drive
Dead Maxtor drive
the soec of the drive will have to match up in order to get the no pcb to wrok so the heads ,sectors,cylndrs and so forth
Apr 23, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
HDD unable to detect at My Computer
Well first I would pull the hard drive out of the case. I would then get a USB to IDE/SATA drive cable. I would connect the drive not being able to be detected to another computer via USB.
If it works the drive is still good but the data might be corrupt. If the data is corrupt I would be sure to get any stuff you can off of it and basically reformat and reload.
Mar 13, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
ATA HDD on IDE connector with a SATA drive on a SATA connector?
Yes. You can leave the ATA-IDE and add SATAsCan you not still buy a 150?
Dec 31, 2008 | HP Compaq d530 PC Desktop
What new HDD will match my Maxtor DiamondMax Plus 8?
Mark,
You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
Dec 29, 2008 | HP Compaq d530 PC Desktop
HP Compaq d530 PC Desktop Logo
3,576 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
