Question about Maytag 24 in. MDBH950AWS Built-in Dishwasher
MAYTAG MDBH945AWS MODEL WANT START. ONLY START LIGHT IS ON.
THIS IS A TWO WEEK OLD DISHWASHER. WHEN IT WAS WORKING IT WORKED GREAT. HOWEVER ONE DAY I WENT TO LOAD AND START IT, AND THE START LIGHT KEPT BLINKING ABOUT 4 OR 5 TIMES. THATS ALL IT DOES, EVEN IF I HIT CANCEL. WHATS WRONG WITH THIS THING?
  • stacy314 Dec 31, 2008
    Thanks, but that did'nt work. Maytag is sending out a technician. When they find the issue I will let you know.
Stacy314-
I just had a similar problem with a GE Triton. Suddenly the lights on control panel went wacky and it wouldn't start. I don't know if this will help you but try disconnecting the power source and wait a bit (this involved turning off the circuit breaker to d/w in circuit box). It cleared up the problem with the control panel and d/w just finished a good cycle. Hope this helps you. It was Step #1 on another site and they said there that this will allow the "computer" to re-set.
Good luck.
TootieC
Posted on Dec 29, 2008
All Cycle Lights on with one blinking sometimes working often not working.
1) tight the connector wires very well and clean with spray contact, of course unplugged the machine
2)resolder all point from the board for colder joint
3) Try again.
4) If the problem persist the problem is the board defective.
5) Call some service tech.
God bless you
Jun 19, 2012 | KitchenAid KUDS301V Dishwasher
Same thing happened today
with the door open when your dishwasher was working normally Did the lights light up on the keypad? I am wondering because if the answer is the keypad only worked with the door closed .....you possibly have a bad door switch.
or it could be a blown fuse inside the dishwasher. are any lights on at all?
Jun 12, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Start light is blinking
It appears that your door switch is intermittently working. Make sure that the switch clicks on and off when you gently press on the release door lever. It you don't here a distinct click sound then you'll have to go into the door switch and do a little filing on the plastic bar so it does not bind with the depressing of the switch. It is very simple to take apart and put back together.
Aug 31, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Model # DU1055XTPQ3 WHIRPOOL DISHWASHER RESET CODE
chris72 had the solution to my Whirlpool DU1055XTPQ3 not turning on. Per Chris's suggestion, I pressed back and forth between sani rinse and heated dry. All the lights came on as it reset and it was good to go. The dishwasher started up immediately. Saved me a service call, THANK YOU Chris!!
Aug 07, 2008 | Whirlpool 24 in. DU920PW Built-In...
Samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Jul 31, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Start light blinking
Test mode is Heated dry - Normal - Heated dry - Normal in 6 sec....
does it blink slowly or three time or fast or 7 times then repeat... let me know and I can help
Jul 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore dishwasher wont start blinking clean light
today January 9, 2009...blinking clean light, kenmore dishwasher would not run,,,the solution on Fixya ..."keep hitting normal -heated wash-normal -heated wash buttons over and over...unlocked the blinking green light problem. Dishwasher is running as I type this....will post again when I see the results of another washing tomorrow. H.T. Las Vegas Nv
Jan 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
DISHWASHER LOCK
I too had the same problem,,and tried it again,,,and it worked for me,,i pushed the button next to the lock light it blinked and i kept holding in the dry button and the lock went off,,,,good luck
Aug 15, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag 24 in. MDBH950AWS Built-in Dishwasher Logo
406 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
