Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Hight adjustor does not work...
I have looked at the plastic wheel hight adjustment and I can see that the wheels cannot receed up into the vacuum. For the life of me I can't see how it ever did. The wheels can pop out easy enough but when cliped back in they obviously don't have the full ability to receed low enough to allow the adjustment lever contact with them to adjust the height. I hope this expanation makes sense. If not off to the store I go.
Mike
  • jshga1 Jan 10, 2009
    Vaccuum does not pick up like before - inspection shows the wheel height adjustment and I can see that the wheels cannot reach the vaccum. It must have worked, but like MIKE I can't figure out it out. Because the vaccum is not low enough there is no suction, nor evidence that the power brush is meeting the carpet!! This is very frustrating, and with all the plastic - there is nothing we can remove to exam or repair.
  • whitdakjd05 Jan 22, 2009
    I thought my height adjuster knob was broken and it is not. It acts like it snaps back in but when you raise upright it falls out. Is there a spring under there?
I think we got this figured out . . . . the height adjustment doesn't work when the vacuum is UPRIGHT, but when you disengage and lower the handle the plastic that is blocking the wheels from receding will rotate and then it can receive the plastic on the "top" of the wheel assembly. Try it and I think you will find that it works. I thought it was the wheels that were keeping the vacuum from working well, but that's not the case. Still don't know why it's gone to heck in 9 months.
Posted on Mar 21, 2009
  • 328 Answers
The height adjuster won't work if the cleaner is put in the upright position or if the handle is locked upwards. Check under neath = where the beater bar is you'll see the main hinge where the wheels come down - sometimes they need a clean if anything is clogged behind - or the screw could be loose which keeps the adjuster dial to the plastic hood. Check that the wheels are moving when you move the dial around (with the handle and bin to the floor).
Posted on Jan 02, 2009
Hight adjuestment won't work
Lock the vac in the upright position and then tilt the unit back off the front wheels, it should move easier. If the height adjust does not work, there may be a broken part, I would recommend service by a vac shop.
Aug 23, 2014 | Hoover Company Wind Tunnel U53019 Upright...
The roller stops when I start to use the vacuum. Is the auto hight adustment bad?
no. The auto height adjustment has nothing to do with this. Sometimes on these units the belt will stretch even just due to normal use. It is recommended that you change the belt at least once a year. Twice a year if you are a pet lover.
Good luck
Mark
Nov 14, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
Vacuum not sucking up dirt
It could be a belt. Also make sure that you have correct hight adjustment. For instructional video look HERE.
Good Luck,
Rocky
Nov 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Height adjustment not adjusting
The height adjustment wont engage unless the handle is in the down position. Not knowing this led me to overturn the hight adjustment knob.
Step on the handle release, pull the handle back and lay the vac on its side. Then you can get the knob and the plate back together again.
BTW, the reason I had this problem is because the front brush slows dramatically when using on carpet, I thought it was set too low, and turned the knob (in a manly fashion, putting it past its limit). Still working on that one. After inspecting the belt, looks like one worn and cracked spot gumming up the works.
Jun 21, 2009 | Bissell 3920 Bagless Upright Vacuum
2 year old machine...new noise in beater bar area
I have a dyson 17 animal and have a loud noise comming from the beater bar area.Also I don't think the hight adjuster is working properly.
Apr 15, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
How to change carpet level for Kirby Heritage II? at highest level and can't lower it.
step on the hight adjustment on the left side of the head. If you need anything for a kirby or help feel free to call 970 824 3772
Mar 26, 2009 | Kirby Vacuums
I have a Miele S1721 Powerhouse upright vacuum. When the belt broke I took it into the shop (because when i tried to replace the belt, the tension was so tight I couldn't get it back together!!). When I...
Hi
The Miele uprights (S170 and upwards) with the Powerhouse title are ALL Panasonic uprights which have been at one time sold in the UK. Therefore the upright may use TWO drive belts which need to be looked at: Take off the sole plate and examine the drive belt which is around the beater bar. Check that this belt is moving easily. Then look at the fly wheel to the motor (usually to the left hand side) and check that the smaller motor belt is moving - it may be broken which is why the beater bar isn't moving and why tension is tight.
Generally NONE of the Miele Powerhouse models have a manual selector for height adjustment - they all use auto adjustment which means no manual selector. The vacuum principle means that general carpet which comes into contact with the brush creates a vacuum anyway between the brush and the floor. If the brush isn't touching the floor then its a possibility dirt or debris has managed to get between the bottom 2 rollers after the beater bar. Check behind the wheels to see that there is nothing there - most auto adjusting Powerhouse models will have a spring behind the wheel and it may have come off.
May 04, 2008 | Vacuums
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
472 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
