Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Panel between fridge and freezer very hot and no sound at all
Whirlpool american fridge freezer started making intermittent loud running noise for a few months, then stopped making the noise but the front panel between fridge and freezer extremely hot to touch
  • 1 more comment
  • manjuvek Jan 04, 2009
    i did as you said, but when i opened the back panel, i found that the fan wasn't turning and the compressor was very hot, so maybe a new motor fan is needed, as after cleaning the grill from the kick panel and the dust from the back, the front panel between fridge freezer is still very hot.
    many thanks for the suggestion though.
  • Anonymous Mar 19, 2009
    same problem. any solutions??
  • inc123 Apr 24, 2009
    same problem!
  • 242 Answers
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Posted on Dec 30, 2008
2 Suggested Answers
  • 103 Answers
SOURCE: panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
Posted on May 31, 2009
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Loud buzzing noise
Yes that is your relay they are pretty common use your model number to track one down may tag is owned by whirlpool so most local places will have them
Mar 01, 2014 | Maytag MFD2560HES Bottom Freezer French...
Hi I have a whirlpool s20d rsb33-a/g american fridge freezer. the centre panel where the two doors meet is red hot, the freezer alarm keeps going of. and some times there is a clicking noise. can any
Your compressor is clearly overheating when this happens. Cause can be lack of airflow at condenser fan,defective fan and/or defective compressor start/run components. The compressor will also cause these symtoms when the start relay and run or start capacitor become defective. I don't recommend running refrigerator under these conditions as this can cause internal overload on compressor to weaken. Thanks, Sea Breeze
Feb 17, 2012 | Refrigerators
Freezer makes intermittent fan noise
one time i ran into this problem and found out the lady was putting hot things in the freezer creating alot of moisture. check your door seal also make sure its sealing if it had gaps you can heat it up with a hairdryer to streach it out.
Mar 28, 2010 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Whirlpool fridge and freezer will not cool
Replace the start relay on the compressor.
Jun 08, 2009 | Whirlpool Freezers
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 20RB D4 Fridge Freezer clicking
Hi the reason for your noise coming from the fridge freezer is the plastic that is used in the design of your product is of a low quailty which reacts to the temp change and then as they get cold again they start to crack inside the frigde! Nothing to worrry about........
Hope this helps.....
Dec 23, 2008 | Freezers
Have a whirlpool side by side american fridge freezer,,
If the fan in the freezer is working.
You can hear this fan running when you open the freezer. Then I think the noise you hear is the fan hitting an ice build up.
This is a failure of the defrost system.
Dec 21, 2008 | Whirlpool ED2FHSS Side by Side...
Fridge intermittently bangs like very loud champagne cork popping
Sometimes when fridge first starts they can sound like water dripping into hot oil or deep fryer, this is caused by liquid refrigerant returning to compressor which has hot oil in sump, this is normal and no need for alarm, unless the fridge is not keeping temperature.
Nov 04, 2008 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
571 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
