Question about Aiptek MPVR Digital Camera
White Screen my aiptek camera has a very bright white screen when i turn it on...how can i make it go back to normal??
  • rocket123 Jul 13, 2008
    My Aiptek 720p has a white screen that shows up when turned on. It still takes pictures and video but can't see anything on screen just white.
  • 21 Answers
I don't know if you stil have the camera in question, since this is a fairly old post.
I've just tried to make this happen with my MPVR and even turning LCD brightness and Exposure all the way up doesn't result in this unless I'm pointing the camera out a window at bright daylight. If you aren't able to access your menus I'd say something's gone wrong with your camera.
You could try posting at http://forums.steves-digicams.com/forums/view_forum.php?id=92
to see if anyone there has heard of this.
Posted on Dec 30, 2007
LCD screen is white, dim picture and sound works fine
seems the white balance is set inccorectly and the brightness is set wrong check your TV's menu and set them back to normal or reset the display controls in the tv menu if it turns all back white and dim then the display panel of your tv is needing repair
Mar 02, 2017 | Televison & Video
Canon rebel xsi lcd is faded and doesn't shut off
To eliminate the chance of the screen actually being damaged due to the camera being dropped, here's a little test you can do? Click on the MENU button and scroll to the 5th icon, the first setting you should see is LCD Brightness. Look at the scale and make sure the little top white arrow is in the middle, that setting should give you a normal brightness for the screen, if it is towards the left side that would dim your screen, move it to the middle using the side buttons around the main SET button. If the little white arrow is already set in the middle, then you screen might be damaged after all? Theres not other setting for the LCD brightness other than that one.
As for it not shutting off, do you mean the camera doesn't shut off or the screen doesn't shut off after a few minutes?
Oct 11, 2014 | Canon EOS Rebel XSi Digital Camera
My camera screen is white totally no colours no menus cant see anything just a plain white screen it dropped about 13 inches any help
Have you tried pullimg yhe memory chip ad batteries and reloading them. And if camera is that new it should still be under warranty take it back to where you purchased it, dont tell them you dropped it and they should help you or replace the camera.
Aug 23, 2012 | FUJIFILM FinePix XP10 XP11 Digital Camera
LCD screen and small viewfinder screen go snowy than white. When I turn the camera on the LCD worked fine, when I than turn it, it was just white. Now it won't even turn on normal. I can still make...
Go to your menus, set all to factory settings or default.
Test the camera by using more of the settings, and notice how it works.
The LCD settings especially are what you want to make sure are set right...not too bright, and of course not too dim either.
Sep 25, 2009 | Canon Cameras
My camera's monitor/screen is black with no picture
My AIPTEK 1080p was powering on but the screen was turning off within one second of turning the unit on. I verified that the camera was still working and just the output onto the screen failed. I was able to resolve this by hooking the camcorder up to the TV and viewing the menus on the TV and then turning the camcorder off with the power button. I think this problem happened because I didn't do a "clean" shutdown the last time I had my aiptek hooked up to the TV. It is now working perfectly!
Jul 27, 2009 | Aiptek Video Cameras
Sony ericsson k750i-white screen in camera
On the side where yuu can turn your volume up and down for the phone the brightness is just turned up, press the down button to make it return to normal. Try that
Jul 12, 2009 | Sony Ericsson K750i Cellular Phone
Camera shows white screen when used outdoors
You are having the following problems:
White balance setting incorrect.
images are too bright
ㆍExposure is excessive
→ Reset exposure compensation
● Adjusting LCD Brightness
1. In any mode with the exception of Voice Recording mode,
press the MENU button.
2. Press the LEFT/ RIGHT button and select the [Setup]
menu tab.
3. Select the [LCD] menu by pressing the UP/ DOWN button
and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN
button and press the OK button.
[LCD] sub menu : Dark, Normal, Bright
5. Press the menu button twice and the menu will disappear.
Turn camera off. Try removing the fully charged batteries for 30 seconds, reinsert batteries and turn camera on. Hope this helps.
Dec 10, 2008 | Samsung Digimax i5 Digital Camera
White screen when taking pictures in daylight
Go to the menu screen for LCD contrast and adjust, it sounds like it is to high. Kinda like a back light for a plasma screen.
Oct 23, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Screen frozen white
Try turning it off with the power button on the screen, then closing it, then plugging it in... (?) That's what I would do if you havent already.
Sep 27, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Screen has gone white
Either your LCD is damaged or the cable connecting it to the rest of the camera is loose. I would suggest taking it to be repaired.
Sep 09, 2008 | Canon PowerShot A540 Digital Camera
Aiptek MPVR Digital Camera Logo
243 people viewed this question
Top Aiptek Cameras Experts
mohamed salim shaikh
Greg Cann
Greg Cann
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
