Question about Dell Inspiron 6000 Notebook
Dell Inspiron 6000 LCD Display not working
The last time I used the laptop everything was fine. This time I started it up the green lights showing it is on and the drive is working and even the microsoft start-up music were functioning but no diplay on the lcd. Is there a test I can run to see if it is the video card or the display. Is the video card seperate from the motherboard on this model. Estimated cost of repair and is the Geek Squad a good source for repair.
Thank you
  • 3 more comments
  • businessbrok Dec 29, 2008
    Tried F 8 and F2 while booting up. No display and didn't go into safe mode or if it did I couldn't tell because there was no display
    No kids and I am not aware of a button for brightness on the laptop display.
    When I press Fn +F8 simultaneously a couple of times nothing happens
    I found the brightness buttom on the keyboard. I've had this laptop for five years and never knew it was there. Unfortunately, it didn't resolve this situation. I pressed the Fn key and the up arrow key with the brightness icon on it simultaneously and also tried tapping it and still no display.
  • businessbrok Dec 30, 2008
    I just hooked the laptop to a projector and the projector displays the desktop on the screen. So my guess it not the video card.
    Sergeant:
  • 279 Answers
Try Fn + F8 to switch display outputs. Post back how it goes.
Posted on Dec 29, 2008
  • Edward Morgan
    Edward Morgan Dec 29, 2008
    Okay, after it's booted, and you press the FN and the F8 keys simultaneously a couple of times, does anything happen at all?
  • Edward Morgan
    Edward Morgan Dec 30, 2008
    Okay, according to the online manual, it's Fn + F8. I guess that's wrong. Look above the function keys at the top of the keyboard for a little icon that looks like a computer monitor. Then when you've found it, press Fn and that function key simultaneously. Post back with how it goes.
  • 151 Answers
Tap F2 as it is starting to get to safe mode and check the video card drivers.
  • 2 more comments
  • djxtreme979
    djxtreme979 Dec 29, 2008
    Do you have kids in house? Is there buttons they could touch for brightness?
  • djxtreme979
    On my laptop it is Fn key and > arrow to lighten display
  • djxtreme979
    No Fn hey and right arrow. Try that
  • djxtreme979
    djxtreme979 Dec 30, 2008
    Bizarre. Right click on the desktop. Anything happen?
My dell inspiron 6000 its display is very dark though its working.cause i can see my windows desktop.is thers something wrong with my lcd?
Sounds like the back light is bad. The display will have to be replaced because replacing the back light itself is very difficult and the bulb itself is extremely fragile.If you have tried turning up the brightness with you keyboard with no luck it's the backlight
Oct 12, 2011 | Dell Inspiron 6000 Notebook
Dell 1545 laptop with white LED screen on start up. Works fine when connected to external screen via vga connector. Everything else works ok. Broken & remade connections between mobo & screen = no...
If the display works fine when connected to external screen via VGA connector then then the problem is either with the LCD display panel ( which consists of the display panel and inverter ) or the LCD cable that connects the LCD to the motherboard. You could try to re-seat the cable connection on the back of the LCD panel.
Aug 01, 2011 | Dell Inspiron 6000 Notebook
Dell 6000 Inspiron Screen will not display anything...has a green hue....tried hooking external lcd and it would not display
power system on holding the letter D while pressing power button, (see if you have 4 solid colored screens displayed) if you do, then the LCD is ok, and this issue is likely a problem with the motherboard
Jan 15, 2011 | Dell Inspiron 6000 Notebook
Hi , my dell inspiron 6400 vista has no disply but external monitor it shows fine ?
If the external monitor is fine then there might be the issue with the display panel cable ( cable which connects mainboard with display) or the display itself. Ypou will have to replace.
Thanks
Mar 09, 2010 | Dell Inspiron 6000 Notebook
Inspiron 6000 - no back light. Problem occurs on
try the lcd inverter chip. it is commonly 90% of the time the problem.
Nov 15, 2009 | Dell Inspiron 6000 Notebook
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Jun 02, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 to TV
On a dell laptop, the key combo FN  F8 cycles through the display options. Laptop screen, External screen, Laptop and External screen at the same time.  Try pressing the FN F8 key to get the video to display on both laptop and lcd and the same time.  If that doesn't work you can also change the settings on what the laptop does when the lid is closed.  Check the power settings in the control panel.
Dec 31, 2008 | Dell Inspiron 6000 Notebook
Inspiron laptop Battery won't charge
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
Jul 10, 2008 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 laptop
maybe..or it's deeply discharged..you may need to run the computer, sans the battery, then install battery while the computer is up, and then do a full recharge.
May 03, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
146 people viewed this question
Alun Cox
