Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Water filter leak Whirlpool ed25rfxfw01
Water is leaking from the water filter and spilling in the floor. We replaced the water filter and it worked fine for about a week then it began to leak again.
  • 2 more comments
  • lemonswirl Jan 05, 2009
    My Whirlpool undersink filter is also leaking. I've had no problem installing new filters today and suddenly when I installed the new filters today, they are leaking! I called Whirlpool support and they told me to look for a hairline fracture in the unit that attaches to the filter cartridges but there is nothing there.
  • nasserk Jan 07, 2009
    water leaking from water filter housing
  • Anonymous Jan 23, 2009
    same problem
  • trout1209 Apr 06, 2009
    Same here, bought one and it leaked badly.
    Exchanged it, 2nd one worked for about an hour and started dripping.
I have an undersink filter from Whirlpool that is leaking also. I had an older one that also leaked and I replaced it. Worked fine for about six months then water all over under the sink. I believe it is leaking from the O-ring which seals the body and the cap. I think they have a lousy design and will look for another filter.
Posted on Jan 01, 2010
After 7 to 10 days, all water leaks on floor.
Does it get heated? If so, Heat makes filter dry and it starts to leak.
Mar 24, 2016 | Humidifiers
Water leaking out the front bottom right side.
Without a model can't pinpoint exact cause but in sounds like a leak in the evaporator drain pan
Feb 05, 2014 | Whirlpool Refrigerators
Water freezes when going into ice maker model # ed25rfxfw01 whirlpool
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn't take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Mar 24, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
I have a Whrilpool refrigerator, model #
the drain hose to the base is plugged that sends water to the lower area by the floor to evaporate
Aug 01, 2010 | Whirlpool Refrigerators
Water pan under water filter fills up...spills all over floor
can you hear water running? possible tha the water filter itself has gotten a crack and is leaking itsel, to fix this removethe filter and repalce it with a new one. if thats not the case, pull hte refrig out and check to see if the fan next to the compressor is runnning, if the fan is not runnnig the water will build up ans well as you compressorwill be overheating, lastly check the incoming wtersupply for a dry rot/crack in the plastic tubing
Jan 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The drain pan at the bottom of the freezer side is overflowing.
If your water filter is " thru the kick plate , at the bottom , replace the filter . I have found several times now , where the filter rubber seals , have leaked into the drain pan , causing it to over flow . You do not have to replace the filter housing , just the filter .
Nov 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water dispenser leaks
The most likely reason for the leaking at the water dispenser is the dual water control valve on the back and near floor is leaking water while shut off. The only option is to replace the water control valve. Sea Breeze
Aug 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ed25rfxfw01 whirlpool fridge water dispenser ...I have a slow drip from the dispenser hose. I assume I need a new water inlet valve. How do I access the inlet valve for replacing?
It should be on the right hand side in the back take off the compressor cover on the back should be 8 or so 1/4 screws nutdriver type and then two more hold on the water valve. If you have a RO system hooked up to refrig you may need to change the filters on the ro or just change the filter on the refrig. those two will also cause the water to drip thru the valve allowing it to drip on the front
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
HI, I can help you. Is the water leaking from the freezer side?
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
2,090 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
