Question about HP DeskJet F4280 All In One Printer InkJet
Fax will not recieve or work.
Im trying to recieve or make the fax work, instructions would be good.
  • me_he Dec 29, 2008
    sorry it was 6210 Officejet Hp all in one
    i have 6210 Officejet all in one, what is the 'Auto answer' for, does it need to be on. It worked before but we moved it and then it wouldn't fax any more.
    what does have to be on and what doesnt have to be on or if someone can help me start ove with it i would appreciate it.
    President:
  • HP Master
  • 990 Answers
Hello sir; is this unit brand new? If yes , check the phone line from wall to the machine did you plug in the jack it said "Line" on the machine. if that's old machine, please change a cable see what's happen.
Posted on Dec 29, 2008
With my epson 520 i can recieve faxes but i can't send them.. everytime i send one it says no answer but i verify that the fax line im sending it to does work.
Hey I had this issue as well with my FAX and I validated that my setting were good and I'd even hear the Fax line pick-up and get a "no Answer" error. I went into FAX settings and just turned something called TCM off and then it worked. Maybe it is for sending it to an older Fax machine, but I did get it to work!
Dec 05, 2010 | Epson Stylus Multifunction Printer/...
Stuck on manual recieve
Press the RECEIVE MODE button on the panel until the display reads FAX on the right side.
Jun 18, 2007 | Brother FAX-575 Plain Paper Thermal
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Brother mfc-260c not recieving fax, has dial tone.
Im not very familiar with that that model in particular. I would check to see if the is an auto recieve button on the control panel or in the fax settings. Just a thought not an absolute solution.
Jun 02, 2009 | Ricoh Aficio 450 Copier
Unable to send/recieve with my Samsung SF 565P fax
Plug a phone in to fax port, Is there a dial tone there also? can you dial a number and make a call from the fax port? You should be able to with a regular phone. If you can't, try plugging in the fax machine to the other port where your phone is plugged in. try sending a fax.If it works there, then the Vonage device or your service itself is the problem.
Apr 22, 2009 | Samsung SF-565P All-In-One Laser Printer
Brother mfc-7420n fax not recieving faxes, disconnecting
Please double check all cords and besure you are in the right plug.
Mar 27, 2008 | Brother MFC 7420 All-In-One Laser Printer
HP officejet all in one fax/printer
hi,
try this
> print a fax test
> decrease the speed at which the faxes are being sent.
you can perform these from the menu button on the printer
thanks and regards
agnel
Mar 14, 2008 | HP Officejet 5610 All-In-One InkJet...
How to fax
The online interactive e-STUDIO 282 manual can be found here
Jan 15, 2008 | Office Equipment & Supplies
HP DeskJet F4280 All In One Printer InkJet Logo
41 people viewed this question
Ben Johnson
