FixYa.com
Tags:
Canon PowerShot A510 Digital Camera
Camera lens
posted by rheak on Apr 29, 2007
i turn on my camera and the lns does not go out...it only shows the images, and so i can not take any more. i need help please
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 16, 2007
FixYa! (100)
advance
Rank:Guru Guru
Rating: 91%, 319 votes
This can be caused by several different situations.
Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include:
*you may hear no mechanical sound at all when the camera is turned on
*you may see visibly mis-aligned components of the lens
*you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on
The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include:
*A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown.
Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include:
*the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem.
*the lens will move in and out easily by hand as if free from any resistance.
All of these problems require disassembly to repair. The charge is around $125 labor at my shop.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Digital Cameras problems?
camera stuck on picture review
when i turnt he camera on i can... Answer This...
Disc will not eject
I have a Canon PowerShot A510.... Answer This...
change batteries error
did you find a solution to the... Answer This...
my camera quit everything!
when i power on the camera, it... Answer This...
my camara
the buttons on my camara won't... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
