JVC I Art No Sound
Hi - My JVC TV has sound while watching DVD's, but not with cable - any suggestions? Thanks so much for your help!
    Brigadier General:
  • 6,966 Answers
Hi again,
Glad to be of assistance and appreciate the kind words on the review and the rating.
Cheers.
Posted on Dec 30, 2008
Jvc i art av 36f475: no sound
Good Day sir/maam, my guess are several, lets start at the common ones, make sure that the AV cables are good. you can try swapping cables to make sure. If possible try the cables on other units such as any DVD player. There is a possibility that the sound jack, is bad, try to vibrate the plugged cable, and see if the sound goes back if it does, you need to solder the terminals. Worse is the Amplifier section of the TV. does the TV sound normal on broadcast? check the volume, mute. or the TV setup. hope this helps. if you have additional info please feel free to ask again, let me know any progress. thanks
Jul 28, 2009 | JVC AV-65WP55 65" Rear Projection...
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
Sony KV36XBR450 - no sound
Hi!
Check for the cables to the cable box/reciever. What type of cable are you using for connection with the cable box(HDMI,RCA component cables)? Your tv is fine as it is working with the dvd player. The issue is with the cables connecting the cable box or from the cable company. Call them to get more information about this issue(maybe weak signals)
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Sony KV-36XBR450 36" TV
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
JVC I Art No Sound
I would suspect that your tuner section in the television has developed a problem. Since the input sound is directly input into the tv's microprocessor, then the tuner is probably the culprit and should be replaced.
The tuner section is the shiny box-type section with the cable connector attached to it. I do not recommend trying to repair this set by yourself, though. The voltages inside the television can be lethal. Please refer this unit to a repair shop , as the repair should not be much. Or, you can use a VCR as the tuner to the television, using same input that you use for your dvd player, and use the VCR remote to change channels.
Hope this helps you...
Dec 29, 2008 | JVC AV27F476 27" TV
Setting up Unit
I called the JVC tech service rep. I went from the Cable box to the JVC unit with a Digital Optical Cable, from dvd/vcr player to jvc unit with a Composite Cable and Audio Cables. From cable box to tv with hdmi cable and from jvc unit to tv with componet cables and cable box to dvd/vcr with Audio/ Video and S-Video cables. This allows me to have the cable TV access and Surround sound in all mode. I have HD and Digital surround sound in three diiferent modes. Everything is working great.
Thanks for the opportunity for help just the same.
Sincerely, cthomas249
Sep 25, 2008 | JVC THD-50 System
JVC i art 32" flat screen
your tv is under shutdown state, there is a protecting circuit that prevent the tv from turning on when there is a short
Sep 10, 2008 | Televison & Video
Does anyone know where can I buy a screen for a 27" LCD Insignia TV. Model is NS-27LCD? My screen creaked. I checked out e-bay and have not found a broken TV with a good screen. Does anyone know where I can buy a screen at.
Thank you all for you time.
JC
Jul 22, 2008 | Televison & Video
Hooking it up
To get the dvd working hook up to amp with a optical or coax lead to your amp digital in,set out put on dvd to give 5.1 sound,next put a phono cable from cable box to tv input on amp or sat input,now put phono cables from tv audio out to tv or other free input on amp.Set sound to prologic2 and you should have surround sound for all.
hope this helps.
CABLE GUY.
Jun 05, 2008 | JVC RX-6030V Receiver
Ur video ic inverter board is dead.
U need a new one.
May 13, 2007 | JVC AV-27530 27" TV
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
