Question about Samsung HCM4216W 42" Rear Projection Television
Blue and Yellow doubles
Hi: Just turned on my Samsung 42in HCM4216W TV (5 years old). Everything was good for a few minutes, then the blue and yellow got separated into double images. Turned it on and off a few times. Everything, it was good the first 5 seconds it's on, then the double image shows up. Could someone please advise if this is something simple / inexpensive that one could fix (just have very basic electronic skills) and, if so, some guidance on how to do so would be appreciated!
Well, fortunately the television that you purchased has an auto-convergence feature. What is happenning is that your color lamps are misaligned, did it get moved at all recently? Anyway, in your menu you should see a "Convergence" menu, and inside that menu, a section called "Perfect Focus". Run Perfect Focus in this sequence: Green --> Red --> Blue After that your picture should look great, if not try tinkering with the manual adjustments on the "Convergence" menu. Here are some URLs that you might find helpful: (just copy+paste into your browser) Your Television On Samsung's Webstire: http://www.samsung.com/Products/TV/ArchivedTelevisions_2002/HCM4216WXXAA.asp Your Television's User Manual (Download And Open With Adobe PDF Reader) (The "Convergence" Menu Is Section 3.3) http://www.usersmanualguide.com/samsung/tv__projection/hcm4216w
Posted on Jun 19, 2007
Blue shadow
You Need Convergence Amp PCB, Cost Is roughly 150.00
Dec 15, 2009 | Samsung HCM4216W 42" Rear Projection...
Sony projection tv 5 years old
you will need to call an electronic repair shop to get this problem resolved
Oct 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
Samsung hcm4216w
can you look into the blue lens when the set is playing using a hand held mirror and see if there is a picture in the blue CRT. If not you will need a new tube for the blue. If you do need a tube let me know as I have a source for good used tubes that are very reasonably priced.
Sep 27, 2008 | Televison & Video
Studioseries (samsung) 42" rear projection tv red duoble outline of picture
sounds like the red convergence Ic is weak ready to go out. try replacing the ICs around 10.00 do the blue as well as that will be next.
Mar 18, 2008 | Samsung HCM4216W 42" Rear Projection...
Samsung 42in Plasma 1 year old
VS is vertical scan of course it is controlled by applying voltage, lower or higher you affect the scan, it appears as focus or sharpness, if it is outside the specifications listed on the back cover(inside) then it will not function properly. definitely get with samsung on this and get a ticket number so they can not just blow you off, if you have an extended warranty they might have to replace the tv as this sounds like it may be a tube issue not just a scan issue, also don't let the tech leave until the tv has warmed up and the image is either the way you like it of he stays.
Jan 09, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung 42" HCM4216W Dim Horizontal line across screen
THIS HAS NOTHING TO DO WITH CONVERGENCE or any of the stk integrated circuits.There are few capacitors close to the vertical output ic, they are usually blue or red (could be 1000uf 50volts for e.g.)That where the problem is
Nov 03, 2007 | Samsung HCM4216W 42" Rear Projection...
Double print on screen
I have the exact same problem with my six year old Samsung!  Your are the third person I have seen with this problem today.  This is too weird.  i wish i could help, then I would be able to fix my TV too.
Oct 25, 2007 | Hitachi 43FDX01B TV
TV turns off by itself (not timer issue)
Probable bad green CRT. Also, look for coolant leak from
CRT onto PCB.......T
Oct 24, 2007 | Samsung HCM4216W 42" Rear Projection...
Samsung 42in rear prejection tv
If your remote is not a universal then you will have to take down the remote and clean it probly it is clogged with dirt.if that does not work then you will have to replace the remote.good luck.
Apr 12, 2007 | Samsung HCM4216W 42" Rear Projection...
Samsung HCM4216W 42" Rear Projection Television Logo
331 people viewed this question
Jerry Greenberg
Jerry Greenberg
