Question about Kenmore 44102 Front Load Washer
Hubby did very uneven load n wash then suddenly leaking
Husband didvery lopsided load, tried to fix load, turned back on and suddenly started leaking all over the floor during filling stage of rinse cycle (GE washing machine..old) never had any problems before.
  • 15,935 Answers
It appears your main tub bearing gasket seal has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Drum wont spin looks lopsided
The "Guides" around the drum are worn out or the bearing is bad, which usually causes it. Replace the bearing and guides. You Tube has many videos on these fix's. and there is a good chance your machine will have one to view.
Nov 29, 2013 | LG Tromm Front Load Washer And Dryer Set
Wash stopped mid-cycle , on/off switch flashing and second and fourth lights flashing. Whats wrong and how do I fix . Dont have manual.
Did you try moving the clothes around sometimes if the load is lopsided (to heavy on one side or the other)it will shut itself off.Try moving clothes around or takeing them out and try.
Sep 28, 2010 | Washing Machines
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Grease/dark spots on 'clean' clothes
This is a cronic problem of front loader machines. The two bearings that hold the wash drum are dried out and then they over heat. The heat build up weakens the seal that keeps water in and grease out starts to leak and the problem just becomes worse with every load. A service repair man will charge you the cost of a new machine to fix the unit. You can replace the bearings and seal with parts from a bearing supply store and if you do, only use bearings from Japan or Germany. Your machine came with ones from China and that is why these machines are failing after 4 years.
May 24, 2009 | Kenmore 46462 Front Load Washer
My Ge washer the tub in it is lopsided
It is probably from an unbalanced load of clothes. Just move the clothes around so they are not clumped together.
Mar 14, 2009 | GE WBSR3140DW Top Load Washer
Clothes are dirtier after washing...
go to your local appliance store and ask for "Affresh" washer cleaner. works excellent. If hubby need to get into the machine have hime clean out the pump. You probably have **** in there thats also contributing to the problem. good luck
Jan 26, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Old GE washing machine w/ no prev. probs., hubby did very uneven load(wobbling crazy), suddenly started leaking all over floor when started filling for second load
It appears your tub seal has failed in this instance.
Dec 29, 2008 | Kenmore 44102 Front Load Washer
Washer Stops/Starts when filling with water
Looks like part 8571359 the control electronics is out and guess what? Can only get through Sears and Whirlpool. This is why you cant get an error code, it isnt working well enough to choke one out. You know this is hard to say but a Oasis has its issues but at least it is still on market. I would if hubby is handy to find a used machine and pull the part. It is a chance but cheaper than 500 bucks to have a tech come out and fix.
Oct 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite front load
not much to go on,the gasket would not stop it agiating, but it should stop it leaking if it was the problem in first place
Oct 29, 2007 | GE WSXH208A Front Load Washer
Lopsided during spin
  This can be caused by a brake that has failed.  Try to spin inner tub with washer off.  It should NOT turn.  If it turns the brake is bad and is allowing the tub to spin when agitating.  This causes clthes to bunch up.
Oct 27, 2007 | Maytag PAV2300 Top Load Washer
Kenmore 44102 Front Load Washer Logo
29 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
