Question about Ace Hardware Wall Lenk Pocket Size Soldering Iron & Blow Torch
1.5" copper drain joint loose in wall
I found a copper drain pipe has worked loose from the kitchen sink. The pipe enters a tee that goes to the soil stack and down into the slab. The copper pipe appears good but the solder joint failed going into the tee. The location is right at a wall stud in the wall. Any suggestions possibly without a torch?
    President:
  • 2,976 Answers
You can use one the putty type of epoxy repairs. They are very easy to use. Just make sure you have everything extremely clean where the putty will touch. Cut off as much as you think you will need and knead it to a uniform color. Don't mess with it too long though, it will start to harden in 3 - 4 minutes. Once it starts to harden, you're done working with it. It sets up real fast.
Posted on Jan 03, 2009
Diy plumbing
most likely that it is a old drain pipe as some plumbers used copper for that purpose. if it is a drain all u have to do is cap it. if it turns out to be a vent pipe u can install a end of the line vent cap. I cant remember what it is called but your supply store will know. just tell them u want to install a vent under the sink not through the roof.
Jun 04, 2014 | Plumbing
How do I fix my kitchen sink drain?
Underneath most sinks there is a "P" trap leading to the drain line which goes out to the outside sewer system. Occasionally the drain line is simply loose and needs tightening by hand or lightly with a wrench. (do not over tighten) If not, loosen the fitting(s), removing the drain line and replacing the seals is in order. These seals can be purchased at most hardware stores. Be sure to have a small bucket handy to catch water residue in the "P" trap once removed and, be sure to clean and wipe all ends of the pipe prior to reassembly so the seals will work properly.
May 29, 2014 | Home
Kitchen sink drain plugs every several days, sink has garbuator and dishwater attached
Yes, I had a really terrible time with my daughter's sink for the same situation.
After unplugging it about 4 times, I discovered 2 things.
1) She was putting stuff in the disposal that was not chopped up well enough to go through the drain.
2) The pipe I installed for the "tee" between the disposal and the "P trap" was not for a disposal, it was for an additional water drain like the dishwasher, so it was clogging all the time.
First I cautioned her to stop putting stuff to be ground up that would plug the drain.
Second I changed the "tee" fitting to a "large volume tee" and that solved the problem.
Be blessed.
Feb 14, 2013 | Dishwashers
Cant get soder to hold on copper pipe soder flakes away doesnt stick
make sure joints are clean and sanded,flux-use mapp gas in torch burns hotter then propane,needed for 95/5 solder preheat up and down pipe for a few inches then do joints,keep you torch moving around joints it'llget a silver color then its ready.Don't get to hot or it will burn up flux.ps no water in the line or you'll never get it,cleaning pipe and fitting is most important
Jan 28, 2011 | Nibco Reducing Tee Copper X Copper X...
I am losing water pressure, but only on the hot side. Cold pressure is fine, as you add hot the pressure fades, the hotter the less pressure. This is at all points in the house. The water heater was...
You have a clog in the hot water line.
If problem is at one faucet, then remove aerator and clean, then disassemble lines underneath sink.
If problem is at every faucet, then that moves search close to water heater.
Look at hot water line that exits water heater and trace that line to first Tee.
Look at cold water line that enters water heater and trace that line to Tee.
Clog is located between those 2 Tees.
Buy pressure tester that connects to hose thread.
Connect pressure gauge to hot water heater drain valve.
Then conduct same test you did at faucet.
See if pressure drops at tank.
If pressure drops, then clog is on cold side of tank, and probably hot side too.
If pressure does not drop, then clog is on hot side of tank.
Suspect 1 is any place two different metals join. For example galvanized pipe and copper.
Suspect 2 is supply pipes that exit top of tank. Take apart and look inside pipes for corrosion and sediment lining pipe walls.
Suspect 3 is elbow. Disassemble pipes and look for sediment and flakes of rust.
Suspect 4 is all suspects above, each having sediment and corrosion.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 19, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
What is the hose on the side of the dishwasher for. what does it connect to.
A rubber hose from a dishwasher should be the drain hose that goes to the sink drain or garbage disposal. (The metal/copper pipe should be the hot water supply pipe).
Oct 16, 2010 | Kitchen Ranges
Here is an interesting problem. We have a Badger 5 1/2 Hp Garbage disposal hooked up on left side of double sink. The Disposer runs, spins, but will NOT drain.. at all. Left sink with the insinkerator will...
If this connects into a tee between the sinks, usually if the tee is in the middle of sinks, then often there is a divider in the tee to keep water from backing up the other drain. Remove the tee and inspect to be sure it isn't cloggged. Also put a bucket under the outlet. Try running it this way, if you get good flow you know the disposal is working
Aug 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Bathroom drain pipe has no threads
I 'am having a hard time visualizing this problem ? is your drain line a PVC pipe or is it the old style brass that was once used?
Jul 26, 2009 | Plumbing
Water drains slowly from newly-installed kitchen sink and gurgles as the last drops go down the drain
sounds like you have a partial blockage in wall pipe.take of p trap and snake pipe in wall as far as you can.
May 09, 2009 | Home
How to install diswasher
To get the water to the dishwasher, it depends on your plumbing setup. If you have shutoffs under your sink(1/2" X 3/8" compression angle stop), you will need to buy a 1/2" x 3/8" compression double stop. This will be easy to change.
#1 Drill a 1 1/2" hole in the back bottom of the cabinet to run your water, drain line, and power cord through.
#2 First turn off the water at the Hot Water Tank, or the House supply, and turn on the sink to relieve the pressure.
#3 Next remove the Hot supply stop, and install the double stop.( The nut and ferrul do not have to be removed, as they will attach to the double stop. Reinstall the hot supply to the sink to one of the connections on the double stop.
#4 Install a 3/8" x 3/8" x 48" braided flex with the 1/2" MIP
x 3/8" compression ell at the dishwasher.
#5 Install the drain hose supplied with your dishwasher at the bottom of the dishwasher.
#6 Install a 6' pigtail power cord to the power box under your dishwasher.
#7 Feed the drain line, power cord and water supply through the hole in the back of the cabinet at the bottom. As you push the dishwasher back into the enclosure, you will need to feed the 3 lines into the cabinet under the sink.
#8 Attach the water line to the open connection on the double stop.
#9 The drain line will attach to your garbage disposal.(If you have one) Be sure to knock the small piece of plastic out of the drain connection, and retrieve it out of the disposal, before connecting the dishwasher drain line.
#11 Raise the middle of the drain line as high as possible under the cabinet under the sink, preferably attach it to a screw to the bottom of the counter top. This will keep the dishwasher from drawing a back siphonage and getting a bad odor.
#12 Plug in the dishwasher. Assuming you have electrical under your sink. Otherwise an electrical outlet may need to be installed.
#13 Balance the dishwasher using the front legs. After you adjust the depth of the dishwasher, and the level. Use the 2 mounting screws included with the dishwasher to fasten the 2 clips above the door to the bottom of the counter top.
#14 Remove the installation manual and styrofoam from the tray, and turn the dishwasher on. Inspect for leaks as you run a cycle.
#15 Attach the bottom kick panels
You are done.
If you have any questions, please let me know.
Jan 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Ace Hardware Wall Lenk Pocket Size Soldering Iron & Blow Torch  Logo
161 people viewed this question
Top Ace Hardware Welding Tools Experts
Bill Boyd
Are you an Ace Hardware Welding Tool Expert? Answer questions, earn points and help others
