Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
FEX831CSO dryer stopped heating mid-cycle
Installed approx. 03/06 - checked and circuit breaker not thrown. Are there fuses anywhere inside this unit that should be checked/replaced? Troubleshooting guide mentions 2 fuses.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
Apr 22, 2010 My dryer would not dry the clothes either. the heating element would only come on once then nothing. The high limit thermostat was bad. Pull the electrical plug. Remove the top cover and the thermostat has an orange/black wire to it. It is hard to get to the screws but I was able. Then I found the element would cycle many times but not stay on long enough to dry the clothes thoroughly - I found the culprit - the motor driven fan creats a suctionin the drum and the hot air from the rear coil is pulled thru the drum, thru the front door (via the holes in the door's inner face) down thru the lint screen, thru the outer fan housing and out the exhaust. My problem was that the door's cardboard backing had seperated and along with the trapped lint clogged the door's holes and restricted the air flow. I took the door off, seperated the 2 halves, removed the cardboard and cleaned the lint out. The dryer is now working like new. Summary: The high limit thermostat was bad probably from cycling so much and the air flow diminished slowly over time to the point I did not notice until the clothes just wouldn't dry. Check the air flow first. Hope this helps
See less
Posted on Apr 22, 2010
It stopped mid drying -- came back to partially damp clothes. No power and checked circuit breaker.
There is a fuse inside (not sure where on that model) that kills the power. There is also thermal fuses and thermostats that will prevent the heating element from getting power (usually clogged vent). But no power is the fuse (usually encased in white plastic so it doesn't look like a fuse.
Feb 27, 2014 | Frigidaire Affinity AEQ6000WH Dryer
Runs but does not heat up and does not dry. The service man showed me the reset button. It was tripped for him but does not appear tripped now. We have had this problem intermittently for a year. Every...
HI,
If your dryer doesn't heat, check these:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 11, 2008 | Asko Dryers
80 series kenmore dryer wont heat - blows cold air during drying cycle. Dryer is all electric.
Heating element
Thermal fuse
Wiring
Jul 21, 2008 | Dryers
Dryer stops while cloths are still damp
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 19, 2010 | Kenmore 64902 Electric Dryer
Roper elec dryer starts and runs for 10 sec then stops runnning
Hi
Hope this helps...
Daniel
Sep 14, 2010 | Roper RES7646KQ Electric Dryer
My dryer doesnt heat at all! Goes straight to
If your dryer doesn't heat, check these:---- Power from the house:------ Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.----- Heating element:------- Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.---- Thermal fuse:----- On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)---- Wiring:------ A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.-----
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Feb 19, 2010 | LG DLE5977 Electric Dryer
Kenmore 66812 dryer stops but heat stays on
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Oct 26, 2008 | Kenmore 62802 Electric Dryer
Estate gas dryer model#TGDX640JQ2 running no heat
Heating element
Thermal fuse
Wiring
Oct 26, 2008 | Whirlpool LGV4634JQ Gas Dryer
Kenmore Ultra Care Dryer- Electric
Your dryer doesnt have a fuse. Your home breaker panel is the only protection it has..Check your circuit breaker box for a tripped breaker.
Oct 22, 2008 | Kenmore 62602 Electric Dryer
New GE Dryer Not Heating
Heating element
Thermal fuse
Wiring
Jul 25, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
687 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
