Question about Maytag Performa PAV2200
Maytag Performa Washing Machine Issue
My four year old "top of the line" washing machine is costing me too much money!! It is a super capacity washer (family of 6 generates ALOT of laundry). Up until about 6 months ago everything was fine. Now when we try and do a load in the cold cycle, the water trickles out (takes more than 1/2 hour to fill the tub). The warm & hot cycles work fine (i.e. water comes out in a good, steady flow). The lines are not kinked. I switched the hot & cold lines to see if it was something "outside" of the washer and then the cold flowed freely. It is definitely a problem inside the washer. I assume something is clogged but do not know how to fix it. Can anyone troubleshoot this for me? Thanks so much-
    President:
  • 1,462 Answers
Switch cold water off, remove hose. there is often a gauze filter, could be at either end. this could be blocked. alse peer into the valve where the hose screws on and see if any dirt build-up
Posted on Apr 30, 2007
SOURCE:
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
8-24-2009 5:55 P.M. I have a Maytag Performa PAV3240AWW top loading washer 2-3 years old has worked well for an active family of four until the last load of wash. It seemed to wash and rinse cycle OK when...
It sounds like the belt broke or the lid switch could be bad. Use a screw driver to manipulate the switch with the machine on. If you can tip the thing back enough to check the belt. I hope this helps.
Aug 24, 2009 | Washing Machines
Burning smell when my Maytag top load washing machine is running
Sounds like the belt is sliping. ether it's loose, or the trans needs lubed, or both.
Jan 14, 2009 | Maytag SAV5710 Top Load Washer
My MayTag performa oversized capacity washer wont spin
Usually this is caused by the pump being cloged or broken. Remove the pump and clean the pump out. Make sure it spins freely by hand.
Nov 20, 2008 | Washing Machines
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
I own a Maytag Performa 4 Speed/24 cycle Washing machine. it is 4 years old. Problem: A very LOUD grinding sound when washer engages into wash, rinse, spin cycles. The Tub does agitate - but I don't...
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
Jul 11, 2008 | Maytag Washing Machines
Maytag washing machine
Hiya .. would suggest you having a look at the balance around the drum, ( normally heavy concrete blocks)... locate the fixing bolts and tighten them up ....should sort your prob.
Also make sure that the washer is fairly even and tight on its legs.. this is what usually causes the problem in the first place..
Regards Faggly
Mar 27, 2008 | Maytag Performa PAV3200
Washing Machines Logo
126 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
