Question about ASUS Xonar DX Sound Card
No output to speakers from line-in port
I want to connect my record turntable/preamp to the line in port, but I'm getting no output, what can I do?
  • myungul Jan 02, 2009
    I fixed the problem, Yes, the monitoring check-box was unchecked in the recording settings, so I checked it and the problem was solved. Thank you so much.
  • 35 Answers
Usually record turntables are not amplified at all.
Also make sure you are using Line In (stereo) and not Mic In (Mono). And be sure the cable from the record player (turntable) is stereo also.
Check your audio settings in your pc software and make sure the Line In is not muted and is at the correct level for you to hear it. Some sound cards also allow the Line In to be Line level or Pre-Amped the signal from the turntable may need to be boosted. Let me know if this solves you problem or maybe I can help further.
Please help me continue to help you with a good rating when it is deserved. Thanx, - CompuWayne
Posted on Dec 31, 2008
  • compuwayne Jan 02, 2009
    No problem. Glad I could be of help.
I have a Yamaha RV-V450 receiver. Where can I hook up my turntable. I have tried many different options. I can hear very faintly the record playing but only after turning the volume up. I am having trouble...
Turntables generally do not have a strong enough signal to drive an amplifier. You can check on the back of your turntable and see if it has a switch to change from phono to line level. Most do not, but a few will.
If your turntable does not have this switch, you will need to purchase a phono amplifier to boost the signal to standard line level. You can get these on ebay for around $15.
You connect the turntable to the phono amp input and then connect the phono amp output to any of the inputs on the back of your receiver (aux, cd, etc).
NEW BOZAK Phono Preamp Pre Amp Record Player Vinyl LP Album Amplifier eBay
Dec 30, 2017 | Yamaha Audio Players & Recorders
Preamps, turntable and 24bit / 96kHz recording
You need an ADC ( analogue to digital converter) along with a phono preamp to restore the RIAA correction to the turntable output. Check out musicdirect dot com for some examples. Alpha Design Labs makes a great one that retails at $500.
Apr 19, 2014 | Audio Players & Recorders
Hello. Just bought a pl990 and trying to connect it to creative speakers for the meantime. Im using a female rca plug but the sound wont come out in the speakers, nor is it working on my pyramat chair or...
The problem is that the output signal from a phono cartridge is very low. A turntable is meant to be plugged into a receiver or amplifier with a turntable input designed for that level. An auxiliary input on an amp is made for a higher "line-level" input. To use a turntable with a line-level input you need a preamp (here's a typical model at Amazon.com) to boost the signal to the amplifier. Then you'll be able to play your records and hear them.
Jul 02, 2011 | Pioneer Audio Players & Recorders
Purchased stanton T.52 Turntable. hooked it up to stereo but volume is very very low. cannot find line / phono switch if there is one on this model.
The only output from the turntable is the low-level signal from the cartridge. Most likely, the receiver you've hooked it to doesn't have a phono input. Many receivers today don't come with one, and if you connect the turntable to a line-level input you get either very low volume or none at all, depending on the cartridge. What you'll need is a turntable preamp to boost the output to line level so the receiver will work properly. Radio Shack still carries a preamp, available online and in some stores. You can also find preamps online (here's one at Amazon). With the preamp connected you can use any free input on the receiver.
Jun 05, 2011 | Stanton T52 Turntable
Hooked it up but sound is very low. Has a ground
Didi you try to change the middle. that was what was wrong with mine
Jan 13, 2010 | Audio Players & Recorders
Connecting NAD 2600a amp.
Never connect incompatible connections. Speaker outputs are for speaker inputs. Period.
The various inputs on this or most any amp are for Line Level signal with the exception of anything explicitly labeled "PHONO" as that would be for a non-preamplified turntable ONLY.
From what I have found online, Lab-In was a NAD feature that restored the frequencies that were rolled off when turntables were being used in the (assumed) preamplifier that fed this amp.
http://web.295.ca/~peak//audio.html
"NAD belleived at the time that practical PHONO stages and the preamp and power amplifier stages be rolled off at subsonic frequencies to prevent subsonic wow and flutter from Turntables and supersonic frequencies (EMI/RF/Radio) signals from getting into the system in the first place. Their notion was that if your ears cannot physically hear it, then why amplify it. For the PURIST, there were a set of LAB IN amplifier inputs with more extended response called "LAB IN" inputs"
Use the Lab In's UNLESS you have a turntable source.
Aug 22, 2009 | NAD Audio Players & Recorders
Using mac with the ion turntable to record vinyl--it records fine and imports into itunes, but when I play songs back I cannot hear any sound. Computer is set to 'line in' for sound input and 'internal...
Funny thing about analog to digital recording without a preamp. You will record a signal, but that signal might be below the level of human audibility, if the line levels are left at the level that left the turntable, given the absence of a PREAMP.
Apr 28, 2009 | ION Audio iPTUSB Turntable
No sound from speakers when turntable playing records
hi,, please check your RCA cable...or replace it possible...
Mar 12, 2009 | Aiwa PX-E860 Turntable
No Sound When Records are recorded to Computer via the Microphone
use tape1 record out to the Line in jack on your computer. you should then be able to record to .wav, .mp3s etc. with an audio program like Nero.
Dec 22, 2008 | Technics SUV500 2-Channel Amplifier
Output from Denon D-700?
Hi ...
If there's a tape monitor in/out on the D700,turn the tape monitor on and connect the "Play out" phono jacks on the 700 to the line-in on the computer. Spark up the turntable and you should be able to listen to the vinyl on the PC while recording.
Nov 21, 2008 | Denon AVR-1803 Receiver
ASUS Xonar DX Sound Card Logo
467 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
