Question about Sewing Machines
Hello, r u there, I have a brother xl- 5001 and I lost my bobinng case or holder, can you please help me were can I get a replased one tnks. Hugo
  • mast1407 May 11, 2010
    try brother spares & accessories ebay or google this is easily replaced
    good luck
    mary h
How to put the bobbin case back together on a brother xl 2600 i
I would go to a sewing machine store with it and ask them it it looks right .if I wasn't sure
Oct 10, 2012 | Brother XL-2600I
Bobbin size for Brother 5001? Not used my machine for a while...took it out, first it wouldn't work because it was Jamed up, oiled it and got motor working. Stitch size still ver stiff, and won't do a...
I just looked on ebay and there is a store that sells your bobbins, 25 for $13.99. You can google your machine bobbins, by entering "brother xl 5001 bobbins" and you will get the sites for them. You may find that a class 15 bobbin will work or a SA156. There are also sites that sell your manual, and of course, you can always call Brother at 1-877-276-8437 and complaint that they do not have your manual available for free to download.
Mar 13, 2011 | Brother Sewing Machines
Brother XL3030 SEWING MACHINE ..STRAIGHT STITCH LOOKS GOOD ON TOP OF FABRIC, BUT BOTTOM STITCHES ARE SKIPPING AND LOOPS FORM IN PLACES..YOU CAN PULL THE THREAD RIGHT THROUGH AND UNRAVEL ALL STITCHING! I...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 19, 2011 | Brother XL-3030 Electronic Sewing Machine
Brother xl 2230 - cannot fill spool as holder does
Check the bobbin winder rubber......remove the top cover and take a look. Remove worn rubber and use as a sample when you go to the Brother Store....also have your model number handy. If you cannot access easily, phone Brother store and ask for a quote to replace.....if it is any more serious they should confirm with you prior to doing additional work.
Sep 05, 2009 | Brother LS-2125 Mechanical Sewing Machine
HELP ASAP!
The bobbin case is in the wrong position to lock into the shuttle holder.Try instead of holding the the release lever of the bobbin case open, instead position the bobbin case finger to the up position and insert the bobbin case by pushing it in with your thumb. You should feel or hear it snap into position. You may have to rotate it slightly to get the finger in the proper position.
Nov 17, 2007 | Brother XL-5340 Mechanical Sewing Machine
Sewing Machines Logo
54 people viewed this question
Top Sewing Machines Experts
Bargain Box
Bargain Box
Irene Tulloch
Are you a Sewing Machine Expert? Answer questions, earn points and help others
