Question about Sony MHC-GX450 CD Shelf System
I have sony component system mhc-gx450 the red light is blinking
How do u repair cuz it only blinks with the red light when plugged in
  • joshamanning Jan 05, 2009
    plug in, it blinks.
    Unplug ribbon cables inside it still blinks
    Is there a fuse on this machine?
    Problem Solver:
  • 5 Answers
Do u have any extra speakers plugged in?
Posted on May 28, 2009
Mhc-rg222 red light blinks power button wont turn on unit
Check the back of the unit for speaker wire shorts, if everything looks fine suspect the output ic's in the stereo.
May 26, 2012 | Sony MHC-RG222 CD Shelf System
My subwoofer for my sony mini component system mhc-gx450 will not work any sugestions???
Is the LED on the front of the subwoofer unit glowing?
If not then check that (a) the plugs are correctly inserted in the two sockets on the back of the the mhc-gx450, and (b) check that the subwoofer is activated on the mhc-gx450 unit.
Oct 15, 2011 | Sony MHC-GX450 CD Shelf System
I have no clue how to hook up my acer computer to a sony mhc gx450. Please include all the wires i need.
http://www.retrevo.com/support/Sony-MHC-GX450-manual/id/268ag305/t/2/
Look up "Hooking Up Optional Components" and assess what your PC's audio and video capabilities are that would use the Game Inputs. The Sony end accepts standard RCA pin cables x 3. Adapters are available at any electronics store to match your PC to that. Within the PC you need to configure the audio via whatever Sound Controls are in charge.
Jul 11, 2011 | Sony MHC-GX450 CD Shelf System
Why do my sony mhc-gx450 cd shelf system power lights keep blinking
This usually indicates faulty wiring, or miswiring. Disconnect the wires, one set and turn the unit off and on to see if that elimates your problem. If it does, the wiring or component is at fault. If you disconnect everything and have the same problem, it's an internal fault with the unit and will have to be troubleshot. Get and estimate first, to evaluate whether or not it's economical to keep, or replace with a new one. Good luck, hope this helps.
Mar 25, 2010 | Sony MHC-GX450 CD Shelf System
The CD Tray won't open on my Sony MHC-GX250
te same thing happened to me know i juat turn the stereo off to where the red light is blinking then turn it back on after the standby message disappears and then i quickly pree the eject button......tr it! and let me know!
Jun 24, 2009 | Sony MHC-GX450 CD Shelf System
My sony MHC-GX450 has power but does not function, power light just blinks. Any advice would be great!
Mine did the same thing. I unpluged , and carfully took top off where I found a CD stuck. I carefully rermoved CD and put back together. When I plugged it back in I heard a click and the display lit up and I was good to go. I might have just lucked out.
Jun 11, 2009 | Sony MHC-GX450 CD Shelf System
How do I connect ipod to sony MHC GX450? can i hook my ipod to my sony mhc-gx450
yes you can connect using rca phone jack to rca jack it depend on what cable you use from your ipod. connect from your ipod audio output to auxillary of sony mhc-gx450.
May 31, 2009 | Sony MHC-GX450 CD Shelf System
Sony MHC-GX450 On boutton flahing red system...
I have the same problem.Power button blinks red constantly.
Nov 13, 2008 | Audio Players & Recorders
Hello
Un Plug It for like 10 to 20 seconds and plug it in it should work it happens to me all the time if it contionuls check the speaker wires and see if the wires are toching together that will be the problem to
Oct 27, 2007 | Sony MHC-GX450 CD Shelf System
Hello my name is mariah
here is what i found on amazon. i will let you know if i have sucess.
4 of 4 people found the following review helpful: stars-3-0._v47082372_.gif Easy fix for GX250, June 11, 2006 By J. Petrosky - See all my reviews
c7y_badge_rn_1._v47060296_.gif I recently repaired a GX250 that refused to turn on (flashing power led), and apparently this fix works for most other problems too, including "no disc" errors and no sound output.
What you need to do is clean and reseat the (widest) white ribbon connector that connects the front panel to the large circuit board on the side. To get to the connector, you'll have to take off the sides and the top, and then unscrew the cd tray so you can lift it up and get your arm and hand in far enough to reach the connector from the opposite side. Then unplug the ribbon cable, blow the connector out with some compressed air, and plug it back in firmly.
Sony MHC-GX450 CD Shelf System Logo
995 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
