Question about Iomega (33215) 250 GB Hard Drive
Iomega 250Gb stopped working
Dear all, my iomega 250Gb USB storage device has stopped working. The power light comes on but not the "Data" light, it can no longer be read by my laptop (running XP). In the device manager there is a yellow exclaimation mark next to it, double clicking on the symbol it states I have a "Code 10" problem. I have tried removing and re-installing it but to no avail. Has anyone else experienced this? Many thanks to anyone who can help, regards Rob.
  • Rob Butler May 06, 2007
    Benimur, many thanks for your response, I have tried your solution but it didn't make any difference, I think the unit is faulty as it's started making a strange "whirring" noise! Thanks again.
    Brigadier General:
  • 6,966 Answers
Hi, according to Microsoft Support: Code 10: If the device has a FailReasonString value in its hardware key, that string appears as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message: This device cannot start. (Code 10) (http://support.microsoft.com/kb/310123) Recommended resolution: Device failed to start. Click Update Driver to update the drivers for this device. On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard. Uninstalling and reinstalling does not fix, then you have to right click and updtae drivers assuming you have enabled you Automatic Updates. Hope this be of some help. Pls post again how things turn up or if we can be of further assistance. Good luck.
Posted on May 01, 2007
My iomega hard drive Model No GDHDU has just stopped working the power light isnt on but the power lead is fine I CAN`T ACCESS ANYTHING PLEASE HELP
Your hard drive is not getting the power from the port u r connecting to. So please check it with other port . If the same behaviour then it is physically damaged and u have to take it to the service centre
Feb 01, 2011 | Iomega (33150) Hard Drive
My computer refuses to recognize the external hard drive what do i do
Hello there,
What type of OS are you running ( Windows # )
What type of motherboard
Here is what i would do to start off with,
STEP ONE - Check all connections
  1. Unplug the USB data cable from the drive and the computer.
  2. Check the ends of the USB data cable to ensure that they are not damaged.
  3. Reconnect the USB data cable to the drive and the computer. Check the connections to ensure that they are secure.
    Note: If you have a Portable Hard Drive with a 2-line USB/power cable, connect both the data line and the supplemental power line (usually marked with a lightning bolt icon) to USB ports on the computer. If the status light on the drive glows steadily, the drive is receiving power. Go to step E.
  4. If you are connecting an Iomega Desktop Hard Drive, check the power supply connections to the drive and power outlet to ensure that they are secure.
  5. Restart the computer.
  6. Double click the Computer or My Computer to see if the Iomega Hard Drive is detected.
    If the Iomega Hard Drive is detected, you can now use the drive.
    If the Iomega Hard Drive is not detected, please try another USB cable and/or power supply (if available). If the Iomega Hard Drive is still not detected, continue with the next step.
if that doesn't work go to this helpful site and follow the Steps one by one to fix this problem
https://iomega-na-en.custhelp.com/app/answers/detail/a_id/1235/session/L3RpbWUvMTI5NTk4MTQwOC9zaWQvZGMzcHNaa2s%3D
don't forget to Rate
Jan 25, 2011 | Iomega Prestige 500 GB USB 20 Hard Drive
I have an iOmega Prestige 320GB USB drive. After using for abou 12 months it now requests the drive be formatted and is recognized just as F Drive instead of iOmega USB Drive. How do I correct this and...
Ted this problem start when you installed a flash drive or any other usb devise or did you map a network drive or anything like that if you did you need to unplug from the hardware settings in control panel then you need to reinstall the iomega if it does not work after that take it to anouther computer and see if you can get it to work
if all else fails I would find somebody that has a linux system and see if the can boot it up and get your data off for you.
Chris Thrash
B52Computers
Jan 23, 2011 | Iomega 250GB USB2.0/FW 250 GB USB 2.0 Hard...
My Iomega (p/n 31706500R) 500GB USB isn't working. When I turn it on the blue light comes on for a second. I can hear / feel it working but then the light goes off (it is still whirring inside). The...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Nov 17, 2010 | Iomega (33654) Limited Edition 500 GB USB...
I need one user manual for iomega 250GB prestige USB 2.0 portable hard drive. Thanks. Sincerely J. Cervantes.
Portable Hard Drive USB 2.0/FireWire (Silver Series USB/FireWire)
User's Manual: View Online [HTML] - http://www.iomega.com/support/manuals/hdd2007/webhd07oct/en/consolidated/main.html#portdual
Download users's manual [717KB zipped HTML] - http://download.iomega.com/english/manuals/english/webhd-userman-en.zip
Quick Start Guide [PDF 943KB] - http://download.iomega.com/qsg/portable-usb-fw_euqi.pdf
Specifications - https://iomega-na-en.custhelp.com/app/answers/detail/a_id/18648/session/L2F2LzEvdGltZS8xMjkzMDc3NDkyL3NpZC9mNDUtY2Npaw%3D%3D
Oct 31, 2010 | Iomega 250GB USB2.0/FW 250 GB USB 2.0 Hard...
I just got a 250GB Iomega eGo external hard drive and my Vista laptop will not recognize it in my computer but it is displayed as a mass storage device in device manager. I tried to update drivers through...
You may assign a drive letter to it by going to Start
  • right click computer
  • Select Manage
  • Go to disk management
  • select the drive It may be displayed as Disk 1 or Disk 2 (depends on your confug)
  • Change Drive Letter
  • Assign a Drive Letter
  • It should display on your computer
  • If you have not data on it, you may format it by going to Start and
    • Select Manage
    • right click on the drive and select format it.
    Oct 30, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
    Hello, I plugged in my iomega 1tb desktop hard drive storage device and the drive does not appear in my drive or computer. I do have the new hardware 'sound' that comes up but I dont have the drive show up...
    Iomega 1TB Desktop Hard Drive is a dedicated usb 2.0 plug and play external storage device that has an ability to transfer at 480Mbits/second. having these large capacity storage drive needs a fast connection and additional power source to make sure to run the external unit system properly.
    just make sure both power and data cables are properly plugged and connected respectively. if you are using it with a desktop, please always plug your usb connection from the Iomega 1TB external drive to the rear USB port in line where you built-in LAN is.do not plug it in the frontload ports. some motherboard manufacturers uses usb 1 and/or 1.1 only for frontload desktop casing provision.
    thank you.
    Dec 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
    Hello. Can I use the iomega 250GB On Windows 98?
    This device wont work with windows 98 its requires windows 2000 or higher, this is a link for the complete system requirements of this device http://www.buy.com/prod/iomega-250gb-ego-usb-2-0-portable-hard-drive-camo-iomega-ego-portable/q/loc/101/207899438.html
    Hope that helps..............
    Sep 15, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    My Iomega Network Hard Drive has a Problem
    Reinstalled your network? I'll bet your network setting change gave your computer a new system identifier... and that the Iomega has data encryption set up to prevent anyone other than the original computer name from reading the data. What it sounds like is that when you are trying to connect to it, the Iomega is telling you that you can create a new 7Mb LUN, which is probably allocated as overhead space. Can you connect directly to the Iomega and turn off LUN security and data encryption? I'm not certain how the LUNs are created on this unit or if additional data encryption software was used, but it could be that the LUNs are set up with encryption as well. If the data encryption has it locked down to only present to the original device key, you may have no other choice but to blow away your data and start fresh. If this network hard drive is your only disaster recovery plan, I would suggest that you add a tape device and do an incremental back up this drive daily to a rotating pool of media... and a weekly full backup of everything on your network. A network hard drive is only meant to be a central storage location where multiple hosts can read/write data. The tape backup can then be used to recover your data in case of a disaster... like you've got.
    Oct 26, 2007 | Iomega NAS 200d 160 GB Hard Drive Array
    Iomega (33215) 250 GB Hard Drive Logo
    1,754 people viewed this question
    Top Iomega Computers & Internet Experts
    Marvin
    Marvin
     Grubhead
    Grubhead
    Alun Cox
    Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
