Question about Boss C350 Car Audio Amplifier
Boss c350 amplifier wiring diagrams
Where do i find them at  this site
3 Suggested Answers
  • 9 Answers
SOURCE: wiring diagram 354xi kicker amplifier
do you need the internal schematics, or how to hook it up? let me know.
Posted on Jul 05, 2009
caroldon
  • 17130 Answers
SOURCE: JUST NEED WIRING DIAGRAM FOR PH5000D BOSS FOR TWO SUB
When two sub woofers are wired the most important thing that must be remembered is to keep the polarity and PHASING to be in line within the space.
The sub can be connected in Series or in Parallel ( if the amplifier takes in very low impedance).
The connections can be bridged from the output.
Finally your taste to listen must determine the final settings and response
Posted on Jul 04, 2012
Jul 03, 2012 | Boss Car Audio & Video
What is the impedence rating for Boss BV9354?
Basically almost all aftermarket decks are 4 ohm. It is the standard for aftermarket audio.
Mar 08, 2012 | BOSS AUDIO SYSTEMS Car Audio & Video
BOSS AUDIO SYSTEMS SE950 Car Audio Amplifier: I have a SE950 boss amp, hooked to 2 audiobahn 12"...
Sounds like you are over working this amp for sure.. Upgrading your power wire & battery might help, check your gain level on your amp to. This is not the volume for the amp. Its to get both amp and the cd player on the same page... And most of all if your subs are wired up to .5 ohm stable, see if your amp do the same... My answer to this ?? Upgrade your amp, Boss audio was never a good company to me, but that is my opinon. Audiobahn set up all the way..
May 16, 2010 | Boss AUDIO SYSTEMS SE950 Car Audio...
My NAD C350 won't allow me to switch input source - permanently on "AUX". Any idea as to cause/fix? Also I need to switch out my power 220v power supply for 120 (US). Would appreciate guidance here as...
Can't help on power problem, but the other sounds like an IC has failed that controls input selection. If you are going to do it yourself you will need a circuit diagram to find the IC.
Dec 20, 2009 | NAD C350 2-Channel Amplifier
Turn off boss RT-735 CAR AUDIO AMLIFIER??
If you want to turn it off - Simply disconnect the remote wire or pull the fuse.
If it is turning off - there is a problem. Thermal shutdown, Grounded Voicecoil or wire, or load us under rated impedence.
Disconnect the subwoofer and power up the amplifier.
Any repairs will have to be from a service center, as repair parts and diagrams are not available from BOSS. The repar may end up being more than a replacement would cost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 04, 2009 | Boss RT-735 Car Audio Amplifier
What is the wire diagram for the 3way bx35 boss crossover
Hello rew_smith,
The wiring diagram is silk screened right on the top of the unit. If your diagram is missing or obscured, you can get one directly from www.bossaudio.com.
The first 3 pairs of connections for subwoofer, front, and rear inputs coming from your receiver or head unit. Top is left channel, bottom is right channel. The 2nd set of connections are the outputs and matched in function to the first set. These are connected to your amp(s).
To the right of the input/output connectors are the 12V +, remote and ground screw terminals. The 2 switches and 9 controls allow you to set the high-pass frequency and output levels for the front and rear channels, and the crossover frequency, bass boost, phase, and output level for the subwoofer.
Hope this helps.
Aug 23, 2009 | Boss Car Audio & Video
I need a manual for Boss AVA 650 Amplifier
Here is the copy of the user manual you needed for your Boss AVA 650.
Click and it will re-directly send you to the downloading site.
Boss AVA 650 Manual
Hope this helps.
Just let me know for further assistance.
micro-
Jul 19, 2009 | Tascam Car Audio & Video
Nad C350 schematic or service manual required
I don't know of the availability of the schematics outside of service centers. Is there a specific problem? I have access to the service manuals but can not by contract send them out.
Dan
Jul 15, 2008 | NAD C350 2-Channel Amplifier
Channels Not Playing
i had afriend who is atechnician. his boss amplifier stopped working on one channel,so what he did is openened the amp,tested the mosfet transistors and it showed signs of failure.then he went shopping for same type of mosfet transistors and with no luck in buying the right type, he put the amp away for acouple of weeks. then one day he hooked it up and strangely it worked again. he told me that while it was hooked up itwent into protection mode and for some reason it worked later. so i would not open it because of static discharge i would disconnect the amp for maybe acouple of weeks then hook it back up.... its worth a try & good luck
Nov 10, 2006 | Boss C350 Car Audio Amplifier
Boss C350 Car Audio Amplifier Logo
265 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
