Question about Microsoft Xbox 360 Controller
Xbox controller will not Connect
The 4th player controller will not connect on my Xbox 360 Elite. From what I can determine, it is not the controller because for any of my 4 controllers they will all connect to the spots 1,2, or 3, but not 4.
  • Anonymous Feb 07, 2009
    The controllers are wireless, which port??? Using a corded controller will work. Suspect 2.4 ghz channel frequency interference.
  • fsdfas May 17, 2009
    This is happening to me too.
First Turn on the Xbox, then turn on the controller. Then at the same time push the little white button on the front of the Xbox console (which is next to the two slots) and the little white button on the front of the controller. You'll be playing in no time.
Posted on Jan 28, 2010
  • snarf412 Jan 29, 2011
    They are wireless, so no ports to clean.
    Novelist:
  • 146 Answers
The port on the XBox has gone bad or there is dirt or something in the port. Use compressed air to blow out the port and see if it helps. If not the unit needs repair.
Cheers
Posted on Dec 29, 2008
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Oct 11, 2013 | Microsoft Xbox 360 Controller
My controller was working one day and then stop working the next day it had fresh battery
Solutions
Jul 31, 2013 | Microsoft Xbox 360 Controller
Ho w to fix x box from controller to x box is really slow how to make it normal
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
How to connect original xbox joystick to xbox 360 elite black.
There might be a adapter, but i haven't heard of it, since there is no usb connection for the original controller it wont work unless you find some sort of adapter.
May 18, 2011 | Microsoft Video Game Consoles & Games
I have wireless internet how do i get connect to the xbox 360
Depends if you have an Xbox Elite or an older Xbox 360?
If you have an Xbox Elite then there will be an in- built wireless, For older xbox 360's you will have to go and buy an Xbox wireless adapter.
If you go to settings, network settings, and select connect to xbox live via wireless then you will be prompted to input your security details for your Wireless and you should then be connected via wireless to xbox live.
Feb 06, 2011 | Video Game Consoles & Games
Can you connect a white xbox 360 controller into a black xbox 360 console. If yes how??
Yes you can do this. Simply get the White controller turn it on and hit the sync button at the same time as hitting the sync button on the Elite Console.
Jan 23, 2011 | Microsoft Wireless Controller for Xbox 360...
Como conectar el control
To connect the controller first press the small connect button on the xbox itself. It will be left of the power button on the front of the xbox, the elite will have a round button on the older styles, otherwise the new slim version will have a square button. Then hit the button on the controller while the xbox lights are spinning in a circle to connect. This button is next to the charging port on the front of the controller and will be a small round button, about 3 mm wide.
Let me know how this works out for you.
Benjamin
Dec 08, 2010 | Microsoft Xbox 360 Elite Console
My xbox 360 wireless controler will not conect with my xbox 360 elite (black xbox 360 black controler)
If you are using an hdmi cable, make sure it is pushed firmly into the console and tv.
Remember to thumbs up if this helps.
If not comment for further assistance.
Mar 13, 2010 | Microsoft Xbox 360 Console
It will not connect to the console
have you synced it ??
the little button on the top of the controller (where the fire buttons are) ....press it (which will make the green ring (around the 'X' button on the controller) rotate)....you then need to press the sync button on the front of your xbox elite with-in a couple of seconds of pressing the button on ur controller... this will also make the green ring (around the power button on the xbox) rotate for a few seconds until both player '1' lights illuminate on both the xbox & the controller :-)
hope this helps ?
Feb 13, 2010 | Microsoft Xbox 360 Wireless Controller
Keeps saying connect controller,this is a new xbox elite
the problom is your controller , bring it back 2 the shop were u bought it 4 a replacement 1 ,. u can also open it up and fix it yourself but if u dont know how , i wouldnt advise it.
Jan 13, 2010 | Microsoft Xbox 360 Wireless Controller
Microsoft Xbox 360 Controller Logo
877 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
