Question about Panasonic Palmcorder PV-GS15 Mini DV Digital Camcorder
Panasonic Mini DV Camcorder
As I was rewinding the tape in my camera, I pushed the stop button and all of a sudden the display went to a blue screen and the counter went to all zeros. Now it won't play, rewind, or fast forward, but you can hear the tape doing something in there when I push one of these buttons. I was watching the tape this morning on the camera so I know the video is on there. This is the third tape this has happended to. I used the camera after this problem,and taped a play, and this tape rewinds and plays fine. Why does this happen and can it be corrected or are these tapes history? Please help!!! Tina
  • Panasonic Master
  • 5,519 Answers
Take the tape out to keep it safe, then remove the battery for 24 hours.
Posted on Apr 16, 2017
  • 76 Answers
SOURCE: Help it's going to fast
Your camera has a capstan servo problem which is more than likely being caused by the capstan motor itself.Nothing you can do youself,would suggest bring to service but reccomend getting estimate before repairing.
Posted on May 23, 2007
SOURCE: Incompatible Tape
try a cleaning tape first - best not to rewind the cleaning tape because it will put back the crud previously removed ? into your heads and guides ( last tape to play is prime suspect ) ; - - digital heads wear faster than analog so a new set of heads is next possibility but if the cleaning tape works . . . retire your library soon as possible .
Posted on Jul 29, 2007
SOURCE: Tape wont eject
put the camera to your ear , power it up and listen ! if it sounds . . . jerky ? your tape is stuck to the heads ( not easy to get out , cassette may be toast and - time is money ) ; if you hear whirring sounds ? before shuts down your cassette housing may be bent ( will need disassembly etc . but not usually expensive ) because - if it is a loading problem , it will usually eject ;
Posted on Sep 05, 2007
SOURCE: PV-GS9 mini dv playback problem
I have the same problem, Try to go on record view and record for 2 sec and come back to play back. It should work tamprarly. I am looking for a permanent solution. If you find one let me know!
Posted on Oct 12, 2007
  • 169 Answers
SOURCE: Powers off
the capstan motor of the camera is not running that why the power display is blinking and when you eject the tape there a portion of the ribbon that left..it is a poor connection of the capstan motor to the main board of the camera...
Posted on Dec 16, 2007
Cant playback tape
Videos recorded on one camcorder very seldom play back in another, due to the internal codes put on the tape by the original machine.
Aug 09, 2017 | Panasonic NV-GX7B Mini DV Digital...
Error message "push the reset switch"
Pull the battery out to reset it. Get a DV tape cleaner to clean out the tape deck.
That should solve both.
Aug 20, 2008 | Panasonic PV-GS300 Mini DV Digital...
Jvc wont play back at all
please i am umber and we buy panasonic dv nv-ds5 please send me english languge manual this model and change the japniss language thankx
May 31, 2009 | JVC GR-D850 Mini DV Camcorder
During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
Apr 18, 2009 | Canon ZR40 Mini DV Digital Camcorder
Tapes will not play
Video head is dirty / clogged. Use good quality Mini DV Head Cleaning cassette.
Oct 01, 2008 | Sony DCR-HC32E DV Digital Camcorder
No playback just blue screen
sounds like the dvc7 needs a cleaning tape.
Sep 24, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Camera Will Not Play Back Video!!
normally you receive a head cleaning tape with the unit or you should purchase one and let it run untill it stops playing. i suggest you run it 2-3 times if this does not solve the problem then you may need a head chage. the change will have to be done by a qualified technician.
Jun 24, 2008 | Panasonic PV-GS35 Mini DV Digital...
Panasonic DVC 7
Clean the heads with a Panasonic MiniDV cleaning tape. I've seen many cameras come through our shop with this problem - a quick cleaning made a world of difference.
Mar 13, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Panasonic NVGS4 camcorder problem
Did you try with different tapes? light turr sound is always there in Rew/FF as the tape rotatets very fast. If the head motor stops while spinning, the error will be detected and the unit needs resetting. also if the head is sticky, tape gets stuck on head and unit will stop. Try to clean the head with head cleaner and check.
Feb 27, 2007 | Panasonic NV-GS40 Mini DV Digital...
I covered several threads that recommended buying a Mini DV cleaner and running it up to 4 times. They also suggested to change to change your video tape as it may have been the cause of the original problem.
These solutions may have worked for many but not me. My camera was becoming progressively worse. It went to blue bars and no sound to no picture at all...just blue. After using a cleaner 4 times I became frustrated to the point I was going to buy a new camera.
However, with the camera still playing, I did the typical guy thing and rolled up my fist and gave it a good hit along side of it. Remarkably it went back to just the blue bars. I hit it again and it went back to a perfect picture. I'm not saying this will work for you and hitting it too hard could make things worse but I was at a point where I didn't care any more and took a chance that paid off.
Dec 30, 2006 | Panasonic Palmcorder PV-GS9 Mini DV...
Panasonic Palmcorder PV-GS15 Mini DV Digital Camcorder Logo
61 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
