Question about Maytag Neptune Washer
Maytag Neptune Front Loader Washer
Goes through the wash cycle and stops like normal. But water is left in the bottom of the washer and the clothes are still soaking wet. I just put a new pump on it today and it didn't help. Also the door lock red light doesn't come on anytime during the wash cycle. I can open the door at anytine during the wash cycle.
    Habit-Forming:
  • 36 Answers
Sounds like the door lock unit isn't locking and may be bad. It is also a possiblity but not likely that there could be a problem with the computer board but start with the door lock unit first
Posted on Jan 01, 2009
My maytag neptune spins water out, the tub is empty but when you turn the tub manually you can hear water sloshing and the clothes smells moldy after washing
There will always be some residual water left in the outer tub after draining. This is normal for most washers. Purchase a container of Oxy-clean and cycle the washer a few times using hot water settings with a half-cup of Oxy-clean added to each cycle. This will help remove any organic matter left behind that might be causing odors.
Oct 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
Washer wont go through the cycles... it stops working before the final rinse cycle
MAH5500B Maytag Neptune washer stops and I have to put back into star and not just wash one side wet clothes and Susie sige water drains can only hear a buzz and it takes many items and each shaved marked "nf" and "Lf"
May 29, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune MLG2000A doesn't drain completely and has moldy smell
You need to clean the stationary "brush" that collects lint and debris from the water during the cycle. The brush can be seen around the tub directly touching it along the bottom/front of the device. Right were I pour my detergent in, after the cloths are in there. To remove the debris I use a bottle brush. You can expect to use trial and error for your attempts. As far as the water being left.... My device has always left water in the bowl. I periodically just run a cycle with no cloths and bleach...HOT.....Mine is not spinning at the moment...again....I think its another call to the local dealer....AGAIN....
Jun 11, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
Neptune MAH 4000AWW works good but some whater is left
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Apr 11, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front loader
check the following
power cord plugged into a grounded 3 prong outlet
the inicator on the cycle conrol knob proprely lined up with a cycle? turn the knob to the right slightly then pull the knob
are you using a extention cord if so dont
washer overloaded
Jul 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
What does the max extract feature do
If the washer is removing all of the water from the washer during the spin cycle it is likely working properly. Not an expert but I believe max extract causes the washer to spin for a slightly longer period of time in order to remove more water from the clothes. We use it regularly because our clothes come out to wet otherwise.
May 03, 2009 | Maytag Neptune MAH6500A Front Load Washer
Front loading Maytag Neptune doesnt drain all water
the washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
Mar 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Washing Machines Logo
200 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
