Question about LG WD-1280FHD Front Load Washer
Water not heating up
LG WD1280fhd,has been smelling mouldy lately,have tried most solutions.now seems water is not reaching temperature.dont know how long ago i last noticed temperature actually getting warm-just hadnt checked this till now.anyone know whats wrong?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
Moldy smell is most certainly due to left over soap residue and body oils that accumulate between the outer and inner tubs. This happens when there is an oversudsing issue and the extra soap does not breakdown properly. Be sure to use an HE (high efficiency) detergent and do not use too much. 2-3 tablespoons is all that is required. To clean the problem you now have you can use Whirlout (available at Home Depot by the hot tubs). Just use one capful in and empty load with hot water cycle. Repeat once a month to keep your unit fresh and clean. Note, even when selecting a cold cycle the unit will add hot water if needed to make the water at least 78 degrees F. This is to allow the HE soap to break down properly. A problem with your hot water (or the heater) could also cause the soap to not break down and operate efficeintly.
Posted on Jan 07, 2009
Whirlpool built in dishwasher DU840SWKQO
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Dec 22, 2011 | Whirlpool Dishwashers
I have a haywood h series h 400 pool heater. Each night the the pool pump timer runs b/t 12-7am.. The heater was working fine. and pool temp is around 70-80.. However, lately the heater which is on when...
Allheaters run off of a thermostat just like the heat to your house. It will shut off once heated to the selected temperature. Turn up the temperature, and monitor it for a couple days.
Dec 28, 2010 | Hayward H-series Electronic Gas Pool...
Compressor ?
Sounds like you are over heating the compressor, try cleaning the out door unit coil. Take a hose and blow water through it, be carefull not to bend the fins.
Jul 17, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
My whirlpool dishwasher just stopped working the middle of the cycle with water still in the bottom and now nothing lights up or comes on and the water is just sitting in the bottom. Any suggestions?
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault and required to be replaced. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 04, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Du1100xtpq7 dish washer keep repeating wash cycle doesn't go past this just keeps washing
Hi
Thanks for using FixYa. If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 07, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
Cycle won't finish Dishwasher goes on at 11.00 pm but is still in the cycle over 8 hours later
Hi
Water-heating cycle
Timer
Thanks
Rylee
Dec 23, 2009 | Neff Dishwashers
Cycle won't advance out of initial draining mode
There could be many reasons, but the 2 most possible would be :-
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 26, 2009 | Bosch 24 in. SHV4303 Built-in Dishwasher
Machine smells mouldy- washing stinks!
Find out where your filter is; it is at the end of the thick hose coming down from the bottom of your tub; open up and clean out. Another possibility is there could be something stuck in your drum, feel if you could locate it. Next clean out the hoses in machine. After all this flush out with a hot wash, without clothes. People shd ask the service man where the filter is. If he knows that is.......................It gives you the biggest problem if you dont check.
Mar 19, 2009 | Whirlpool Washing Machines
Won't run through cycle
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
please rate my solution thanks
Jun 30, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
LG WD-1280FHD Front Load Washer Logo
99 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
