Question about LG 42PX5D 42 in. Plasma HDTV
Embedded image on screen
I have an image (the "Play" logo from CBeebies!) permanently on display, although in the background no matter what channel I am watching. As I say, it is not prominent but it is visible to me. I am nt sure if it is a TV problem or an issue with the Sky+ box. Is this problem familiar to anyone?
    Novelist:
    Scholar:
  • 67 Answers
What you have is probably a "burn-in" from a stationary logo present on the screen for a long time. There is really only 2 ways to repair this kind of "burn in." One is to replace the panel (which is usually cost-prohibitive) or the other is to put a raster generator (whole-screen color display machine) on an input and run it for a few days.
The latter takes a good raster generator (HD capable, 1080) on a white screen, and leaving it on for a couple days to take most of the imprint out of the screen. It may work beautifully, or it may not work so well, depends on how bad it is.
A local TV shop should be able to help you, should have the equipment to do this, and should do it for not much money.
Posted on Dec 29, 2008
What does the HUD button perform?
Your windshield serves as a giant screen, and a projector embedded in the dashboard sends a transparent image onto it. The image leaves the projector and bounces off a series of mirrors, magnifying and flipping the image so that the data comes out right-side up and legible. Press a toggle switch by the dashboard and you can adjust where the display is on your windshield-something accomplished with a rotating mirror.
Some car companies like Mazda project their heads-up data onto a small plastic window that flips up, known as a combiner. This creates a uniform image no matter how the windshield's shaped. It also reduces the number of mirrors needed to send the image onto the windshield clearly. And a lot of aftermarket displays use such a combiner so you can install it in nearly any vehicle you please.
Oct 24, 2017 | Cars & Trucks
Dark Screen and Blue Lines Arc Across Background
Hello!!
If the coolant is cloudy or has debris floating in it, the coolant will have to be changed and the lenses and crt face will need to be cleaned. Coolant can be ordered from any electronic distributer
Dec 28, 2007 | Sony KP-57WV700 57" Rear Projection HDTV
Tip
How do I add a transparent Logo to my AVI (MPG4) file using VirtualDub
First download the latest software from SourceForge HERE
at the time of posting is v1.9.8 (24th Dec 2009) then create your logo or download one.
The background that you want transparent must be black.
You must also re-size it to the correct pixels that will suit your AVI on a 640 x 320 a logo set to 60 x 30 as this example shows
Select your AVI file then add the logo press
<CTRL> + <F> scroll down to logo this is an internal logo to it will be included in the bundle, you will see about 20 others also.
You must select the Logo image the same as the Alpha image, and tick all boxes, its a good idea to offset the X and Y more that 15 pixels;
This is the HBO logo added to the DivX7_postinstall.divx you can clearly see the logo in the top left-hand corner as selected previous
To ensure that the new DivX clips has the logo embedded then you must select the correct compression method this file has a FOURCC='divx' , if you don't select this then the default Uncompressed RGB/YCbCr will be selected and you file will be huge.
All you need to do is press <F7> to save as AVI, you can't save as DIVX, if you want to do this when the output has completed rename the file extension to *.divx using the file explorer.
on Jan 27, 2010 | Philips DivX DVD Player
Cable to Display from motherboard has change and i get a now backlight image on screen, the book goes fine on micro dvi to dvi and i gor the camera working too. What is the problem ? the screen the...
If you can see the LED back lights then the screen is at fault. If you have a logo permanently etched onto the screen then this is also going to need a new display.
(Have a Google around for screen burn-in) If the fault is temperamental try moving the display back and forth, if you have issues then this means it is the cable running from the motherboard to the display.
Mar 01, 2011 | Apple MacBook Air
Is plasma burn in real?
Hello.
Well it does not catch any real fire if this is what you mean. What actually happens - PDP (Plasma Display Panel) is "burning out" throughout it's use. Especially if someone is watching TV channels with fixed logo (Like CNN for example). That steady image can get "burned in" into the screen and stay there forever. So it is important to watch different channels and programming so screen does not get any permanent "marks" and spots.
LCD and LED technology does not have this issue because of totally different method of producing image on the screen.
Regards.
Russ.
Aug 18, 2010 | Televison & Video
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
How do i remove pscan from our dvd player? ok so we are trying to watch a movie but on the screen is a permanent PSAN! image in an orange block...how do we remove this?
DUDE I HAVE THE SOLUTION LOOK IN THE BACK THERE SHOULD BE A SWITCH IN THE BACK. FLIP THE SWITCH. THEN TURN ON DVD AND PLAY THE MOVIE
HOPE I HELPED MY YOUTUBE CHANNEL IS PCGAMERONVISTA
Aug 24, 2009 | Memorex Progressive Scan DVD Player...
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
Horizontal Span across 2 screens - now displays multiple offset background image
you have tried differrent setting in your video resolutions, what you need is just return to your default settings
Nov 29, 2007 | XFX GeForce Fx5700 (128 MB) Graphic Card
LG 42PX5D 42 in. Plasma HDTV Logo
101 people viewed this question
Computer Repairing
Computer Repairing
