This sounds like the brake light switch or the control switch on the brake pedal is bad or loose. Check under the dash above the brake pedal there should be one or two switches that tell the brake lights to come on and the cruise control to shut down.
Are you sure the drive belt is still on the engine ? The battery light usually comes on when the alternator is not charging the battery, and the power steering is also belt driven. The brake warning light can come on when the brake fluid is low, but also when the battery light comes on.
You have multiple probs. Dash lights are powered off Headlamp switch, which sounds bad. Brake lights are operated off brake light switch which is just above your brake pedal under dash. Sounds like brake light and head light switch both need to be replaced.
youve got a bad connection on the ground too the headlight switch, when you hit the brakes it grunds the system thats why they come on,try running anothe ground off the head light switch if you can if not run a ground form the dash lights but you have too pull the dash apart too get too the wireing for it!!!
Do you mean the ABS and BRAKE lights? If so, the ABS module is bad which causes both lights to come on. After rebooting, the module gets tested and the ABS light will come on after a few seconds. If it a module problem the BRAKE light will also come on. The brakes will work normally, but will not provide the anti-lock feature.
