Question about Dryers
Does the plinth have to be cut to install a KVT1I drier
I wish to purchase an integrated tumble drier but some I have seen require the plinth to be cut so that the vent can be seen on the front. Is this the case with the Kenwood KVT1I?
5 Suggested Answers
Oceti
  • 51 Answers
SOURCE: white knight 767 tumble drier
If the rug was very heavy you could have burnt up the motor. If it will restart after it cools off, replace the motor and clean out the vent system.
Good luck.
Posted on Dec 08, 2007
  • 5 Answers
SOURCE: Lost user manual
try this website: http://www.managemyhome.com/mmh/
Posted on Apr 27, 2009
  • 15 Answers
SOURCE: Drier tumbles but will not heat up, checked for
check you legs on the plug it might have a bad leg (prong) or you need a new pig.
Posted on Jun 05, 2009
SOURCE: Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Posted on Oct 21, 2009
Small water leak from under the washing machine
not un common for manufacturers to test every 5th , 3rd , 10 th machine if yours came with a defective/ cut/ or otherwise failed pump to drain hose or tub to pump hose. my 15 years in the business hint noisy in spin points at unseated main tub seal/bearing call for factory service don't void warranty by fiddling with it your self ( maybe an easy fix slipped hose,maybe a 3 hr repair for a qualified journeyman appliance technician.
Oct 24, 2016 | Beko Washing Machines
Tumble drier keeps cutting out
High limit is tripped, may need to replace limit switch.
Mar 17, 2016 | Dryers
TUMBLE DRIER STOPPED HEATING
Gas dryer?
If so, probably bad gas solenoid valves. They can safely be replaced without fear of releasing gas. Two phillips screws, two pull off wire plugs. That's it. Cost about $30 bucks depending on where you buy them. They are a universal part and will fit 99.9% of machines.
www.repairclinic.com
Best of luck...
May 18, 2015 | Dryers
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
Siemens v34 97
That is a tumble drier, not a desktop PC.
Jul 02, 2013 | Computers & Internet
Tumble drier tumbles but no heat its an Indesit...is it the thermostat
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Nov 02, 2009 | Tricity Bendix TM310W Electric Dryer
The tumble dryer tumbles but I have no heat and the filter light
Since the heating element is not heating up when powered up you must have a bad heating element.
Oct 06, 2009 | Candy CDC266 Dryer
White knight 767 tumble drier
Good luck.
Dec 08, 2007 | Dryers
Dryers Logo
Top Dryers Experts
