Question about Kenmore 744-08BH Mechanical Sewing Machine
Kenmore sewing machine Model 744-08BH
Sometimes my machine doesn't let the thread from the needle pull up the thread from the bobbin. While sewing, I'll feel a little kick in the stitching, like it's hard for something to move. When this happens, the thread from the needle keeps winding itself around the pin in the middle of the casing. (?) The thread will look like a big spaghetti mess when I pull it out. I've cleaned & oiled the machine. Still have the issue.
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
Posted on Dec 10, 2007
  • 1388 Answers
SOURCE: bobbin tension
If the looping is happening on the underside, it is your top tension that is to blame, conversely looping on top is bobbin tension.........take a look HERE for detail on cleaning lint buildup.
Top tension should be set around the middle of the range, usually 4 - 6.
I would not advise playing with bobbin tensions, however, you can take the needle plate off to clean the hook race area (where bobbin case sits) ...this is good housekeeping, my wife does this every time she replaces the bobbin....just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint, if there appears to be fine dirty deposits, a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit will do the trick.
Posted on Jan 27, 2008
  • 87 Answers
SOURCE: no bobbin tension
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Posted on Mar 18, 2009
  • 255 Answers
SOURCE: I have an older kenmore sewing machine. It's been
When I have run into similar problems with my older Singer, it's because there is a bit of thread caught somewhere in the bobbin mechanism that doesn't allow the shuttle to run freely. Take the bobbin assembly apart and use a bright light to see if you see any bits of thread in there.
Good luck and let me know if this works!
Posted on Jan 15, 2010
  • 48 Answers
SOURCE: Kenmore 27-stitch machine jamming badly in bobbin
Sounds like a timing issue. Did you attempt to force fabric through too quickly? Sometimes this can alter the bobbin's tension, and alter the timing of the machine as a whole as well. Not a cheap fix, sadly(Local to me, for example, this will cost about 70 bucks to have fixed. Do NOT try to do this yourself, leave it to the professionals, there are more moving parts in a sewing machine than in a space shuttle.)
Posted on Apr 23, 2010
  • 3 Answers
SOURCE: Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
The winding sound is the rubber O-ring against the spinning pulley (back of hand wheel) - do not let this continue, it will wear out the O-ring.
I had the same problem and I found the shaft bushing of the winder dry and needed lubed. Use oil or spray lithium grease and it should work fine. Spin the bobbin shaft by hand (not the hand wheel) to get it freed up after oiling.
You can oil from the top and should take off the side case to clean the excess oil from the O-ring. The shaft bushing is a tight fit and any dry oil will get sticky and prevent winding.
Posted on Nov 05, 2010
0 characters
1 Points
Singer model 620 sewing machine needle pokes holes in fabric but doesn't sew with the thread?
try changing the needle--make sure it's the right needle for the
fabric being sewed
rethread the machine top and bobbin
make sure the bobbin is inserted into the bobbin case
it's also possible that the machine could have a timing problem
and needs to be checked
Feb 12, 2013 | Sewing Machines
Thread breaking
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Aug 13, 2012 | Janome Sewing Machines
Bobin will not pick up
The most common reason I see for bobbin thread not being picked up is that the needle is in backwards. Or the needle is a little bent (sometimes it's so little you can't see it, but the machine knows!). So start by trying a new needle (size 80/12 is what's used for test sewing on most machines). If that doesn't work, turn the needle 180 degrees and try again -- there is a definite front and back to a sewing machine needle.
Make certain that your bobbins are the exact ones recommended for your machine. Many look similiar, but if they are off even slightly in depth, they will not work. Also, make certain your bobbin in locked into position in it's case and the thread is coming from the bobbin in the correct direction. When holding my metal bobbin in my hand, the thread pulls counter clockwise before placing it into my front loading bobbin case. Each machine is different so check your manual.
Jul 12, 2011 | Simplicity Sew Precious SWSP2 Mechanical...
It is threaded. but it goes through motion but there is no sewing.
Make sure that your bobbin is full and that you have picked up the bottom thread. Before you start sewing you should have two threads lying on the needle plate. To catch the bobbin thread, hold the needle thread and turn the machine by the hand wheel. The needle will bring the bobbin thread up with it. Pull the threads out about 4 inches and then you are ready to sew.
Feb 24, 2011 | Kenmore 15516 Mechanical Sewing Machine
Needle won't take up bobbin
Make sure the needle is inserted with the flat side toward the back of the machine.
Lift the presser foot and then re-thread the machine.
Hand walk the needle down and back up while holding onto the end of the thread at the needle, then pull the bobbin thread up and along with the top thread, pull under the presser and to the back of the machine
Mar 06, 2010 | Sewing Machines
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
Kenmore 385 model Automatic Button Hole Apparatus Jams Thread?
Practice and practice some more! Use the same fabric and interfacing as your project and a NEW needle (the correct needle) This is for the Sears Kenmore 385 automatic button hole maker. Make sure you pull the bobbin thread through the Guide Block - it is that simple. Make sure you pull your thread to the back of the machine though the presser foot slot - the correct presser foot. Account for both thread tails before starting to sew. Keep thread tails to the back of the machine 4-5", insert fabric under presser foot keeping thread tails clear. Mark button hole and sew.
Mar 30, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Jun 05, 2008 | Kenmore Sewing Machines
Kenmore 744-08BH Mechanical Sewing Machine Logo
22 people viewed this question
Top Kenmore Sewing Machines Experts
Bargain Box
Bargain Box
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
