Question about Cuisinart Thermal DGB-600 Grinder
The bottom half of grind chamber will not release to clean
The bottom half of the grind chamber is locked in place and can not be removed for cleaning. Every thing else works fine!
  • llrobbins Jan 07, 2009
    It worked! Thanks.......I have not used the grinder chamber for the last year. Now, I can grind and brew!
  • 8,596 Answers
1) Rinse area with vinegar/water on a cloth to break up oils
2) Fill grind chamber with ice covered in a small plastic bag - try removing again after 10 mins
Posted on Jan 07, 2009
How do I load brads and close magzine?
push release
slide it open
place strip of brads in chamber - insure that they r at bottom
they have a tendency not to go all the way to bottom on some units
close slide til it locks
If an old brad is jammed u will have to open the cleanout port to remove it.
Jan 13, 2015 | Tools & Hardware - Others
How do I clean my burr mill (Models BMX3, BMX4, BMX5 and BMX6)?
Clean your burr mill before using it for the first time. Then, to ensure optimal mill function and durability, clean it regularly following these simple steps.
  1. Always unplug your burr mill after use and before cleaning.
  2. Open the hopper lid. Empty any whole beans from the hopper. Remove the top burr mill by rotating it clockwise. For better results hold the grind setting button while rotating the burr mill clockwise. This will allow you to clean the grinding wheel and the grinding compartment.
  3. Clean the interior recesses with a soft brush. Note: Never use water or liquid for cleaning the lower grinding section of this appliance. BRUSH NOT INCLUDED.
  4. Wipe the whole bean hopper, its lid and the mill exterior with a damp cloth.
  5. The ground coffee chamber and lid can be washed in mild detergent and water. They both are top rack dishwasher safe. Do not immerse the mill or the whole bean hopper in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  6. After completely drying the whole bean hopper and top burr mill, replace the burr mill in position by aligning snaps with receptacle and rotating counterclockwise to lock it in position. For better results, hold the grind setting button while rotating the burr mill counterclockwise. Once the burr mill is in position, pull gently to check it is properly locked in position. If the burr mill comes out, repeat this step again.
  7. Replace the ground coffee chamber and lid, making sure both snap securely into place.
  8. Fill the hopper with whole beans.
Sep 02, 2011 | Bunn NHB Coffee Maker
How do I clean my burr mill (Models BM1 and BM3)?
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Some idiot put ground coffee and water in the whole bean reservoir of out titanium Gaggia machine. I may have been there for a day or 2 before we noticed something wasn't working correctly. we took it...
It is fairly easy (if you have the instructions I'm going to give you) to take the grinder apart to clean it out completely. This would be the best way to clean it - by removing the burrs so you can get right into the grind chamber and grinds delivery chute to clean.
At least vacuum it out as best you can and don't add any beans until it has had time to dry out.
OK ... first take off the water reservoir and set aside. And unplug the power cord. While you're at it, remove the drip tray and set aside and remove the brew group and set aside. You'll want to rinse off the brew group very well.
Next remove the three screws that hold the bean hopper and lift the bean hopper out and set aside.
Lift off the round rubber top from the grinder - it has four slots that line it up so it'll be easy to put back on later.
Now, notice the ring with gear teeth on the edges? This is the grind adjustment that turns around when you turn the grind adjustment knob. Twist that ring counterclockwise and you'll see a painted mark - twist counterclockwise until that mark is pointing to about 7 o'clock. Now you can lift out the center part (the burr) - you'll need to wiggle it a little and you should be able to lift it out - notice the painted mark that would have been pointing to about 3 o'clock. Brush this burr clean with a stiff brush (a toothbrush would work) and set it aside for now.
Vacuum all the mess out in the grind chamber - you may need to loosen the coffee grounds up with a toothpick or a stiff brush.
Once you've vacuumed out all the grinds, there is a "chute" where the coffee grounds go through - it's hard to see because it will be caked up with coffee grounds. This is at about 5 o'clock in the grind chamber that you just cleaned out and goes towards the front of the machine. Poke something in there (a chopstick or a wooden coffee stirring stick works well - or the handle of your brush) to loosen up the caked up coffee grounds and vacuum again.
To really get this clean, tip the machine onto its back and open the front door (you've already removed the drip tray and the brew group, right?) You'll see a little trap door with a triangular shaped handle - this is right directly above where the funnel of the brew group would be if the brew group were inserted. Pull down on that triangle and the trap door will open. Vacuum and brush out all the grinds you can and you should see the other side of the "chute" that you were trying to clean out earlier in the grind chamber. Poke your chopstick or stirring stick in there and loosen all the packed coffee grounds (they'll be falling back into the grind chamber now). If you have a can of compressed air you can blow it in there and get coffee grounds all over your kitchen (oops).
You may have to go back and forth a few times between cleaning under the trap door with the machine on its back and then setting the machine upright and vacuuming out the grind chamber and then putting it on its back again and cleaning under the trap door.
You may want to tip the machine completely upside down so any coffee grounds can fall out. This is all very messy but you'll have a nice clean grinder when you're done.
OK ... now that everything is clean and dry - here's how to put it back together and get it aligned correctly.
Put the burr back in with the paint mark pointed to 3 o'clock. Make sure that the outer ring still has its paint mark pointed at about 7 o'clock. Wiggle the burr a bit to make sure it is sitting all the way down in place and then rotate the outer ring clockwise a little - as the ring gets to about 10-11 o'clock it should have locked the burr in and started to pull it down. Verify that you cannot lift the burr back up (if you can, then you didn't get it fully in place and you need to turn the ring counterclockwise again back to 7 o'clock and make sure the burr has snapped all the way into position and try again).
OK - now that you can feel the burr being captured by the ring as you turn the ring clockwise, turn the ring all the way clockwise (the paint mark will be pointing at 3 o'clock. Put the rubber cap back on top of the burr and work it down so the four tabs are fully through the four slots.
Notice the straight plastic piece with gear teeth on it to the right side, just above the burr. This is the dose adjusment - push it all the way towards the back of the grinder.
Now get the bean hopper and set the grind knob to zero and the dose knob all the way to + as far as it will go. Set the bean hopper in place and you may need to wiggle the knobs slightly until they line up in the gear teeth and the hopper can set fully down in place. Verify that you can turn the knobs and see the adjustments moving below (the outer ring should turn and the straight rod with the gear teeth should move forward and backward. Turn the three screws back in to hold the hopper in place.
With the grind setting at 7 or 8, you should see the paint mark on the outer ring at about 1-2 o'clock when you look through the clear plastic of the bean hopper - and this is a good starting place for your grind setting.
Clean the brew group really well (no soap - just water) and put it back in the machine. Put back the drip tray and the water reservoir and plug the power cord back in.
Now that the grinder is completely empty and clean, the first time you fill it with beans and make coffee it will take a lot longer than usual for the first cup to grind - it may tell you the bean hopper is empty - just select a coffee again so it grinds some more. Once it has ground enough beans to get them moving through the chute it should start making coffee again.
Hope that helps --- it isn't as hard as it sounds.
Oct 16, 2010 | Gaggia Titanium Espresso Machine
My cuisinart cbm-18 does not grind at below a 10 setting?
Hello, and thanks for using FixYa.
I'm guessing the problem is that the grinders blades, or the parts that do the grinding have become somewhat dull, (opposite from Sharp.) and no longer can get to the beans like it used to.
Cleaning the machine properly might improve its performance.
CLEANING/MAINTENANCE INSTRUCTIONS
1. Be sure plug has been removed from outlet.
2. Beans can be removed from the hopper by lifting off the lid and pouring excess beans out. Hold down the Manual button to cleanout any remaining beans.
3. The bean hopper, bean hopper lid, grind chamber, and grind chamber lid can be washed by hand with hot, soapy water or placed in the top shelf of a dishwasher. Dry thoroughly.
a. Remove the bean hopper by rotating counter-clockwise bringing the selector past grind setting 18, align the arrows and lift up. Make sure the hopper is empty.
b. Remove grind chamber by pulling toward you.
4. Remove the burr grinder, once the bean hopper has been removed, by grasping the metal handle and lifting up. Use the brush to remove grinds or wash by hand. Replace the burr grinder onto the unit and rotate until the piece is fully inserted. Push handle down and replace hopper.
NOTE: The hopper will not attach to the unit if the grinder has not been fully inserted.
5. Wipe body of grinder with a damp cloth.
6. Any other servicing or maintenance should be performed by an authorized service representative.
WARNING: NEvER ImmERSE UNIT IN WATER
Oct 14, 2010 | Cuisinart CBM18 Electric Grinder
Spidem Trevi Plus coffee is not being dispensed.
The grind chamber is blocked, remove the beans and brew unit then clean the grinds chamber, then adjust the grind 2 numbers coarser and try again.
Nov 05, 2009 | Spidem Trevi Digital Coffee Maker,...
Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end of the grinding cycle. Make sure that the grinding chamber is completely cleaned and dried before using the grinder.
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
Revere Ware old fashioned coffee pot
1) Boil the water you’ll need in another pot.
2) Put 1 tablespoon of ground coffee (drip grind, not percolator grind) in the reduced diameter, perforated bottom of the brewing chamber.
3) Put the grind/water separator (the perforated, flat handled plate with cup markings on the handle) in the Brewing Chamber, over the coffee grounds.
3) Put the Brewing Chamber on top of the Holding Chamber.
4) Pour the appropriate number of cups boiling water into the brewing chamber; put the lid with the black knob on the brewing chamber.
5) Let the water drain through the coffee grinds (5-10 minutes).
6) Remove Brewing Chamber, clean out the coffee grounds, and replace the lid on the holding chamber.
7) Enjoy your coffee! Keep it warm on the stove at LOW heat setting.
for the most information on the Revere cookware lines, go to: http://mysite.verizon.net/vzeoywo4/theshineshop2/id1.html
Charlie
Jun 16, 2008 | Coffee Makers & Espresso Machines
Cuisinart Thermal DGB-600 Grinder Logo
263 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
