Question about Canon PowerShot A75 Digital Camera
Memory card error
I have 2 diffrent mem cards and both of them read mem card erorr. sometimes i can get one to work for 2 shots and then back to error. what do i need to do?
  • Canon Master
  • 4,738 Answers
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Posted on Dec 30, 2008
Memory card error
pull mem card, pull battery. wait 10 secs reinstall battery, turn on.
if all is well, and just needs mem card, turn off, install card, turn back on.
if you get the memory card error, throw away that mem card, anything else you put it in, might get damaged.
Apr 09, 2012 | Canon PowerShot A520 Digital Camera
New ps1 mem card wont formaton ps2...
I have read that some manufacture PS1 memory cards will not work properly on the PS2. I would suggest trying another PS2 to see if it's a problem with your specific PS2. If the memory card doesn't pop up on the browser screen of another PS2, it could be defective or incompatible. If it does work on another PS2, it could be something weird going on with your memory card slot on your PS2.
Oct 09, 2009 | Sony PlayStation 2 (PS2) Console
My w850i can't read memory card
to make sure the problem please insert ur mem stick to external card reader, if it can read ur mem stick so ur phone card reader had a problem and i think its hardware problem, but sometimes when system files(hidden files) in the mem stick is missing can make the same problem, so u better insert ur memstick to the same device that worked to really make sure the problem is (ur memstick or ur phone card reader), and u also can try to insert the memstick from that worked device to ur phone (just make sure problem solution) :)
Apr 01, 2009 | Sony Ericsson W850i Cellular Phone
Canon pwshot S3IS "memory card error" "card locked"
there should be a little swith on the side of the card. switch to the opposite and then try
Mar 23, 2009 | Canon PowerShot S3 IS Digital Camera
Card Error
1. Change batteries, MEM Error/Card Error can also be that the card is FULL in which caseyou upload those precious shots to the PC, then delete them from the card ;-)
2. Look at the card. Does it have a small slideswitch on one side? If so, that is the WRITE safety, and should be marked (ON/OFF, WRITE/SAFE, LOCKED/UNLOCKED etc...) If there is one, and it is not marked, simply slide it to the opposite position. If I recall, most are slide DOWN toward the gold contacts to allow writing and you may have inadvertently caught that slideswitch on the edge of the MEM card slot or the camera body when pushing in in and moved it UP to LOCKED.
3. Get an eraser and CLEAN those gold contacts
4. But another card and see if it works(?) if not, you may have bad or bent contacts INSIDE the camera ((in the MEM slot) which will require a steady hand to fix.
Let me know... I may be close enought to help
Jan 15, 2009 | Polaroid I533P Digital Camera
SONY DSC-P9
older cameras didn't support pro cards-if door where card goes in says memory stick anly and not pro you need to find PURPLE card that maxs out at 128mb and that's the only card you can use-hard to find-maybe staples or office depot sometimes or online-if door says mem stick pro try formating card through menu in camera-
Jul 26, 2008 | Sony Cyber-Shot DSC-P9 Digital Camera
3110c 1gb "memory card not formatted"
nokia 3110c show the disiply memory cord not formated how to solwe thes prablam
Jun 29, 2008 | Lands Phones
Memory Card Guitar Hero 3
Try this... if you have another Mem card then insert it in second slot and start Sony browser now copy your save game data form Mem card 1 to Mem card 2. Place the second mem card in first slot and start game now load your game. Best of luck.
May 08, 2008 | Sony PlayStation 2 (PS2) Console
Unlock cyber shot k550i
take the mem card out the battery 2 waith a few secounds put the battery back and but not the mem card ....and try 2 power on
Mar 21, 2008 | Sony Ericsson K550i Cellular Phone
Canon PowerShot A75 Digital Camera Logo
239 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
