Question about Apple iMac G5 Desktop
35inch Insignia wont pick up HDMI input from my mac
The mac detects it, and even thinks it is displaying things (i can move mouse off screen). But the TV will not get a signal. All it displays is "no signal". This is the case for both HDMI ports so it isnt like one is freezing up. Please help
  • 4 more comments
  • tylerjno Dec 31, 2008
    it goes. Mac DVI out to female > DVI Male to VGA Female > HDMI plugs into TV. I tried it on multiple TVs and still nothing "no signal"
  • tylerjno Jan 01, 2009
    I have not, my computer is a desktop and the cord is roughly 3 inces
    long. There is no way I could get it to the TV. I have the adapters and
    such for extensions cords sort of. (also, one of my TVs has no DVI only
    an HDMI input)
    Model Name: iMac
    Model Identifier: iMac7,1
    Processor Name: Intel Core 2 Duo
    Processor Speed: 2.4 GHz
  • Sam Kirsch
    Sam Kirsch May 11, 2010
    Which mac do you have exactly?
  • Sam Kirsch
    That seems a little much adapters where something could go wrong. Most of the time, HDTVs have a DVI port where you don't need the VGA plug. Also, THe VGA plug looses quality. Have you Tried straight DVI?
  • Sam Kirsch
    What type of cable are you using to connect the "second screen"?
    Sergeant:
  • 369 Answers
THERE IS A LOTS OF CONVERTER AVAILABLE TO CONVERT THE DVI TO HDMI AND U CAN USE THESE TO CONNECT THE HDMI TO YOUR TV..
THANKS
Posted on Jan 04, 2009
How do you connect vizio dvd to insignia tv. We r using hdmi cable and NOTHING is happening
If you are using an HDMI cable that is all you need, HDMI is capable of transmitting video and audio to your TV. So the only thing to do now is to get your tv to switch to the DVD player from its normal TV signal. On your TV's remote control you should see a button called 'input' pressing this will bring up a menu of all the possible forms of input on your tv, most modern tvs will have at least 3-4, there may even be several HDMI inputs, the one you need should be labeled on the back of the tv or wherever you plugged it in, but the easiest way to figure out which it is, is to start a dvd playing, then cycle through the available inputs by pressing the input button on your tv's remote repeatedly until you see the picture on screen. (give each a few seconds before switching to the next, as some tv's do have a slight delay before displaying the image).Then make a note of which of the HDMI ports it is for future use.
Hope this was helpful.
May 31, 2011 | Televison & Video
SLOW MOUSE TRACKING PROBLEM & VIDEO/AUDIO SYNC PROBLEM with 27" iMac Quad computer. Using 42" Insignia as a second monitor using HDMI DVI cable. The video card unable to serve both monitors' draw...
I am using my tv as a second monitor as well, and i believe the lag problems with the monitor are due to the video/graphics card. I am not expert, but my pc is an alienware aurora with quad processors and 6gigs of ram. The only thing not top of the line is my video card, plus it gets slightly pixelated due to resolution not being sufficient from my video card. Otherwise flight sim X runs smoothly, except for the mouse lag issue. Best of luck, if your program is lagging also though, might be your driver
Sep 08, 2010 | Insignia 42" LCD Flat-Panel HDTV
Trouble connecting Insignia HDTV 19" to my macbook pro
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV PortFor best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection.If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference.Mac Pro, MacBook Pro, Mac MiniMac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports.If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac.If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine.iMac, MacBookiMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection.Make the ConnectionOnce you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV.Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac.Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV.Over or UnderscanYou may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan.You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV.Time to Watch a MovieOnce you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
Feb 22, 2010 | Insignia 19 in. Widescreen Flat-Panel LCD...
Bought and HDMI to DVI Cable, Not Fully Functioning
Your setup is probably in "extended" mode - if you move the mouse back in forth, when it leaves the Mac Pro screen you should see it on the external plasma monitor. You can switch to "mirror" mode if you want to see the same thing on both screens. Or put the computer into "sleep" mode, close the lid, connect an external keyboard and the plasma display and wake it up by pressing keys on the keyboard. Then you should see the desktop on the monitor.
Dec 23, 2009 | Televison & Video
Insignia 22'' LED HDTV screen resolution problem with VGA
This is more of an alternative than a solution... but I solved my problem by getting a dvi to hdmi adapter and connecting to my mac desktop via hdmi. Once I then turned off the overscan in the menu I got a perfect 1080p image. Hope this helps. :-)
Dec 20, 2009 | Insignia Televison & Video
I am trying to use my 32 inch Insignia HDTV as the display for my 13 inch macbook. I got an adapter for the vga, connected everything and turned then on. The display only shows one of my desktop pictures...
--==<[ DVI to VGA vs. DVI to HDMI ]>==-- Caleb, what you really want to do to get your Macbook working with the Insignia HDTV is to >RETURN< and exchange the DVI to VGA adapter for a DVI to HDMI adapter. This is assuming your hdtv has HDMI inputs (which I'm pretty sure all the insignia ones do! I own a 1080p 32" Insignia HDTV and it has 4 HDMI's). The reason you should exchange them is that DVI and HDMI are essentially the same connector (and a better connection than VGA), the only difference between DVI and HDMI is that HDMI additionaly contains two audio channel wires. HDMI (which is a smaller version of DVI) is a digital signal and will give you perfect picture quality compared to the analog 'pc vga' type connector you were converting it to with the adapter you described (not to mention it will probably just work immediately since there is intelligent 'handshaking' that goes on with an HDMI connection, so it will tell your HDTV what resolution to use rather than it having to guess....)
I am guessing by now you solved the problem since it was in June that you posted and it's now November as I write this, but I figured you're probably not the only one who tried hooking it up that way. And most people don't seem to realize that DVI and HDMI are essentially the same type of connection, just smaller, with audio added. So someone will most likely benefit from this posting =)
Best regards, -=VRMan3D=- http://www.vrman3d.com <- 3D Screensavers and in browser 3D Mac/PC gaming for free!
Jul 17, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Dell latitude d820 xp: Mouse inputs are moving
Mine did that too, its normal, the actions undearneath maybe stuck just a little and thinks it is required to move when not
Jul 15, 2009 | Dell Latitude D820 Notebook
TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Apr 08, 2009 | Westinghouse Televison & Video
TV stuck on input mode
plug in hdmi input into the input that is displayed on screen. if no change, plug into another input and change input to the device
Oct 04, 2017 | Insignia Televison & Video
Apple iMac G5 Desktop Logo
444 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
