Question about Umax ActionBook 333T Notebook
Targus ac70u adapter; 0% available, ( plugged in, not charging )
Hi, well i'm having this problem with my Targus ac70u adapter to charge my laptop, and when i hover the mouse over the battery in the corner to see how much percent my laptop is charged[i have windows Vista] it says; " 0% remaining, plugged in not charging. " When I unplug the charger, my computer immediatly shuts off, and i have to plug it in, in order for my computer to turn on. I have a Compaq C500 Presario, and Windows Vista. This charger has worked before.. so i don't see what happened. Please don't tell me to unplug it because i have done that enough already..
Thank you ^.^
  • allyssa_depp Dec 30, 2008
    OK, thank you both.
    This will be my 4th charger i've gotten this year.. i must get pieces of **** chargers then.
    Sergeant:
  • 279 Answers
How old is your laptop? It may just be that you need a new battery if it won't hold a charge.
Further, this charger worked previously on this laptop and with this battery? If so, you definitely might be ready for a new battery.
Posted on Dec 29, 2008
  • Umax Master
  • 32,281 Answers
Is the Tagus adapter your original adapter?
Check the adapter wih a multimeter to see if the voltage output is or slightly greater than what is printed on the label.
The adapter may not have sufficient amps to charge the battery and run the laptop, check the current rating of the original adapter and compare it with the Targus, it should be the same voltage and current rating or higher current rating.
If the adapter is OK then the battery is worn out and needs to be replaced. Recharageable batteries have only a limited number of charge and discharge cycles, when this is reached they just don't work any more. Buy a new battery, not a 2nd hand one because of the reasons I've mentioned.
SOURCE:
HI there! I am using a targus universal wall power adaptor for laptops, it has an output of 19.5 V and 90 W. I was wondering if I could use this to charge my UK laptop from ADVENT. The charger for this has...
The wattage is to different, the wattage for the adapter is 90watts, and the charge for the advent is only 65w.
You can always try it, but you risk damaging your battery, or motherboard.
Jul 16, 2011 | Targus APA30US AC Laptop Charger AC...
The toshiba laptop a505 S6980 will not charge the battery when the AC is plugged in and dies immediately if unplugged . Meters shows 0% available (plugged in), charging. But it is not really charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Apr 20, 2011 | Toshiba Satellite L500-ST2521 Laptop AC...
I have an nv5468u with Part Number LXWDG02030. My laptop wont charge the battery, I can still turn it on using the ac adapter but it wont charge the battery, the battery light indicator just alternates...
Hi there. Your problem seems to be the battery. Usually when the battery is at the end of its life the indicator stays at 0%. If you are still unsure you can go to download.com and get free battery testing software. Good luck...
Mar 30, 2011 | Gateway NV5468u Notebook
I dont have charger . is there a way i may charge my laptop using a desktop pc
Hi
No, that is not posible. you might want to get a universal charger for the laptop, they are fairly cheep. At the bottom of the laptop you can see how much power the laptop uses like:
19V (Volt) 1,2A (Amps)
Regards
Mar 26, 2011 | Televison & Video
Thrid party battery, third party adapter, Dell 8600
It is either the adapter or the connections to the motherboard. It would definitely feel better about telling you which one it is if you could try another adapter. Last thing i can say for now at least is have your ac adapter checked and make sure it is putting out the required power.
Jan 21, 2009 | Dell Inspiron 1501 Notebook
Power problem with laptop
The problem may be in the charger now. It could have shorted out. Do you see any lights on the unit when it is plugged in? James
Dec 30, 2008 | Computers & Internet
No power
Try purchasing an original adapter. I've had several machine of different make through my shop that the Targus adapter just simply won't run. For example, a Dell Inspiron 1100 and HP dv4000 won't run at all, and a Dell Latitude 1501 and Gateway crv503 will run but won't charge the battery. Targus adapters are junk, if you can, get your money back.
Jun 28, 2008 | HP Pavilion dv1000 Notebook
Notebook smells like burning plastic.
cud be your onboard voltage regulator for the battery charging. if you remove the battery and use the external power source does it smell also?
if the battery charges normal out of the unit, and the laptop works well with the AC power unit without the battery, then it's your voltage regulator for the batt charging
Mar 17, 2008 | Computers & Internet
Targus 70watt adapter
Mine was brand new and it worked for 2 days then started doing that. I know it's not my laptop. I work in a computer shop and I tested it several different ways. I think it may be a faulty capacitor. either way, you just have to replace it. That's what I am doing. I would suggest the same.
Feb 27, 2008 | Computers & Internet
If the new Targus charger is really rated correctly for your laptop, your battery isn?t charging and you smell the burning plastic coming from the laptop when you plug it in that is a fairly dangerous situation and you shouldn?t plug it back in anymore. The power from the charger runs through a PCB board which distributes power to other components in your laptop. I suspect one of the components (probably a capacitor) had a catastrophic failure and is the cause of the smell and the lack of battery charging. Once again assuming that the Targus is the correct one for your laptop current you probably have a laptop damaged beyond home or economical repair.
Dec 02, 2006 | Compaq Presario 700 470024-192 Notebook
Umax ActionBook 333T Notebook Logo
1,286 people viewed this question
Top Umax Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
Henk de Ruiter
Henk de Ruiter
Are you an Umax Computer and Internet Expert? Answer questions, earn points and help others
