Question about Toshiba 36A50 36" TV
Toshiba 36A50 Noise Issue
My TV generates a noisy picture and audio noise, both of which vary in intensity. They could even go off for a few seconds. The noisy picture and audio noise are appear at the same time. Especially the white lettering seems very choppy. I brought in another TV and plugged the TV signal cable from my noisy tv to this other. The other TV had no noise. So its definitely my TV. My email is akizil@hotmail.com and CELL is 603-729-0101
    Genius:
  • 1,074 Answers
Your tv needs a tech the problem is in the IF circuit.good luck.
Posted on Apr 30, 2007
SOURCE:
Fan noise loud and always present
If the fan is very dusty that an cause a lot of noise as it will be unbalanced. If the fan is on all of the time, maybe the bios requires updating. There may be a GPU issue and that will make the cpu run hot.
Jan 03, 2014 | Toshiba Portege R400-S4831 - Core Duo...
Samsung DLP HLN5065WX/XAA
that's from a thermal switch, to keep the innards cool, post use. Seems to me that you might just check to see that all vents are open and clear of debris, for starters.
May 07, 2008 | Televison & Video
Toshiba, 36A50 picture is a thin white line. Can this be repaired?
Yes...this TV may be repaired. The line you describe is in the center and is horizontal across the TV. You will need to resolder the vertical IC pins. This vertical IC is mounted on a large heatsink. Under the board you will see there are 5 or 7 pins that will have rings around them. Resolder these. And you should replace two or three capacitors that are next to this IC. A bad cap will overheat an IC and separate the solder grounds. If you can find my expertise page on this website, you will see the repair in more detail. Thanks for asking and show a few hands of support.
Dec 12, 2010 | Toshiba 36A50 36" TV
TV does not turn on. There is a yellow blinking LED light on the right lower corner of the TV
Disconnect your TV. for few minutes (10) then plug it back on, turn it on using your remote control, wait few seconds, until the light bulb gets its normal intensity, if you can not see anything, but there was a clicking noise,then you bulb it's burn out
Dec 23, 2009 | Toshiba REGZA 47HL167 TV
36" toshiba suddenly turns off and the little red light flashes
Some el.components are loose on tv circuit board.I have removed the back cover,supported tv picture tube 45 deg.against wall.This tv is heavy!One screw on left holds the circuit board to bottom case.Removed and supported this board on few heavy books.Turned tv on and gently probed all the componets on top of the board with plastic drinking straw.In my case transistors Q-830 and Q-421 needed resolder loose joints.These components are mounted on flat aluminium heat sink strips located sligtly left of center of the circuit board.Also blobed bit of silicone into base hole and foot of alu.heat sink to support it.
Apr 15, 2009 | Toshiba 36A50 36" TV
A blank black box appears midscreen
need to turn off close captson off hope i speled that right.
Feb 28, 2009 | Toshiba 36A50 36" TV
36A50 Digital ready?
Hi duce1500,
Unfortunately, the 36A50 is not HDTV-ready. That means you will need a converter box. Here is a link to the model's specs, which includes this information:
http://www.amazon.com/Toshiba-36A50-36-TV/dp/tech-data/B00004YMBV/ref=de_a_smtd
I should mention, however, that if it's connected to cable (or certain satellite services), you won't need a converter to watch the TV - you'll receive the digital signal (although you won't have the 1080-pixel HD resolution - the 36A50 only has 850 lines of resolution).
I hope this helps. Please let me know if I can be of any further assistance.
H2H
Dec 13, 2008 | Toshiba 36A50 36" TV
36" 36a50 tv won't turn on
My 36A50 suddenly shuts off losing audio and video. The red light on the on/off switch continues flashing until the set is unplugged.
Jul 16, 2008 | Toshiba 36A50 36" TV
Toshiba 36A50 Horizontal Line in the middle
  • the problem is most common & simple to repair at your home only at minimum cost by skilled technician.
  • as per problem is concern it is due to electrolytic capacitor failure in vertical output stage.
  • hope this will help
  • good luck.
Oct 21, 2007 | Toshiba 36A50 36" TV
Toshiba 36A50 36" TV Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
