Question about Directv Televison & Video
Trouble recording on the DVR.
The DVR won't let us watch something on another channel while we are recording another program.
  • Brian Fells
    Brian Fells May 11, 2010
    are u a cable customer or satellite customer
  • 86 Answers
Do you have a Dual tuner DVR? If so, verify that you have 2 cables from the dish plugged into the back, one into each tuner.
If thats not the problem, go into your settings and verify that you do not have one tuner disabled. If both tuners are enabled, check the signal strength. If its good on both tuners and resetting the receiver doesn't fix it, its probably time to call DTV to discuss a new receiver.
Posted on Mar 24, 2009
Why cant I change channels when recrding 2 progs?
Hello Anonymous,
You did not specify if you are using a DVR capable cable/satellite box, which I what I presume is the case.That DVR has two tuners in it - each tuner allowing you to watch and/or record two programs at one time and in any combination.If both of those tuners are used for recording then you cannot watch another "live" stream as there no available tuners to tune and display (or stream to the DVR hard drive for recording). You can only switch between the two recording programs.
As a side note, if your TV has a built-in tuner, you can split the cable and have one going to the DVR and the second run going to the TV set. You can then use the TV's built in tuner and watch what anything it can get. It won't get scrambled digital cable but will get analog and Clear QAM channels.
Feb 15, 2015 | Televison & Video
Why does my R15-100 DVR Plus not record 2 programs at same time. What can I do to fix it?
When we had the R15 (we have since upgraded) we could record two channels at once with no trouble. You have to have two satellite connections in the back (since it uses a separate tuner for each channel) and you cannot watch a third channel while recording two others - if you're going to watch, you have to watch one of the two shows you're recording.
May 16, 2014 | Directv Plus DVR DTV Receiver / 100-Hours...
We just dvrs hooked up a few weeks ago.when I am recording somthing down and my daughter goes upstairs to watch her tv and tries to change her channel to watch somthing a message comes up on the tv that...
Hi, poog_23350, I caught your post! How a Duo DVR receiver works is that the TV you have it set to record on will not allow you to change the channel while the recording is in progress. The other TV, that isn't recording anything, can be used freely to flip through channels.
In this case, it's TV2, the one upstairs in your daughter's room, that's currently set to record on while the downstairs TV is free to use. This can be adjusted by pulling up the Main Menu with the Menu button on the remote, selecting option 8, then option 5, and changing the TV1/TV2 setting there on the Record Plus screen.
If you'd like a receiver capable of allowing channel changing while recording a program, our VIP 612 receiver is a Solo receiver that acts like a Duo. What this means is that it has one TV output and two tuners. Along with being able to change channels while a recording is in progress with this type of receiver, you can also record two programs on two different channels simultaneously.
Hope that helps!
Aug 29, 2011 | DISH Network DVR-625 DTV Receiver /...
Cant record two programmes at once
Well no matter the DVR, you should be able to record 2 programs at once...but you CANNOT watch a 3rd live while they are recording...also, if your DVR is hooked up to more than one tv and someone is watching something else in the other room, it will not record 2 at once, either. You can watch RECORDED programming while 2 others are recording, but not live tv.
You might want to check how many "inputs" your DVR has...most have 2 which allows the double recording...if you have an older DVR maybe you only can do one at a time. On my DISH box, they call these "TV1" and "TV2".
Hope this helps.
May 14, 2011 | Televison & Video
How do i record a program and then watch another one, with the Magnavox H2160MW9
The unit is not a DVR capable of recording one channel and watching another. You can only watch or record one program at a time. Sorry.
Sep 22, 2010 | Magnavox H2160MW9 HDD Recorder
Direct TV DVR Recording Problem
call tech support & ask them to hit your box to reset it, in the meanwhile unplug it for 15 seconds
Apr 22, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
Jan 22, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Connecting my DVD Recorder to Dish Network so I can record
If it is hooked up right to record as the program is on. Then make sure the input is set correctly, the tv should show pic from ext-1 the e-55 should be on channel 3. This should solve ur problem.
Jan 04, 2008 | Panasonic DMR-E55 DVD Recorder
Tivo and direct tv
No, unfortunately there is not. That tivo only has 1 tuner, so you can only record or watch 1 live program. You can however watch a pre-recorded program while recording a live program. If you have directv, you can step up and get their hr20 dvr. It's not a tivo by any means, but it has 2 tuners so you can record 2 things at once and watch a pre-recorded show. It takes a little while to get used to the interface, but once you get the hang of it, it's pretty straightforward.
You can also get an older DVR w/ tivo (hr10) however, it will not get ANY of the new MPEG4 High Def channels that are out there.
If you have an hdtv, then you really should grab an hr20, give directv customer retention a call and ask what they can do for you. You'll need a new slimline dish and they'll come out install it and everything you need for watching off the new satellites and enjoying the new mpeg4 hd channels (the old hd channels are in mpeg2).
Good luck.
Dec 12, 2007 | Tivo Series 2 80-Hours Video Recorder
Problem with programmed recordings
DID you set the channel on the VCR to the sttating your recording? Also does your cable go to the tv, then to the vcr? If so the channel you record will be the one your watching. Or did you accidently screw the cable into the "cable out" on the dvr?
Nov 27, 2007 | Rio DVR4100 DVD Player/VCR
Televison & Video Logo
193 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
