Hiaer hw-c1270tve-u washing machine error code 8
Haier 1200 spin 7kg washing machine error code 8, the book says water exceeds protective level? i have no idea what this means please help lee
  • Anonymous Jan 31, 2009
    I have the same problem! Im about ready to kick the shite out of it!
  • Anonymous Mar 14, 2014
    WHAT U MEAN BY ER 8
  • 15,935 Answers
It appears your pressure switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
Hwd-c1000txveme-u error code 8
The only reference to 'E08' I have is that there is a problem 'water level exceeds protection value'. Water level detection may not be operating correctly and requires a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 24, 2011 | Haier HWD1000
Error code Unb: After the last rinse finishes, spinning fails completely due to unbalanced of the laundry (What does this mean) and How do I clear the error. Machine does not spin the clothes.Every thing...
I have had the same problem with the same model and rang up the help line to be told that the machine cannot sense the clothes in the drum. I tilted the machine forward and this worked for a while, sometimes i have to unplug at the wall so there is no electricity flowing through the machine for an hour and it resets itself,. Its not adequate but it works.
Sep 02, 2010 | Haier Washing Machines
My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Jan 07, 2010 | Haier Washing Machines
My samsung 7kg front loader keeps flashing UE on the error code (spin cycle) and I can't open the door
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 26, 2009 | Samsung WF337AA Front Load Washer
Error code 8
pleas help me
Jan 20, 2009 | Haier HWD1000
HAIER HW-C1460TVEME-U
Err1 : Door not properly shut
Err2 : Drainage error (clean filter check hose
Err3 : temperature sensor short circuit
Err4 : Heater error
Err5 : water fails to meet specified level within 8 mins check tap, water pressure
Err6 : motor error
Err7 : motor error
Err8 : water exceeds protective level check circuit
End : end of wash cycle
Unb : after the last rinsing cycle finishes spinning fails completelt due to unbalance of the laundry
only reason I know is i looked through the manual after getting it myself could be something to do with running a bath while washer on or something perhaps not enough water getting in if powder channel blocked
Sep 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
I have the HAIER HW-C1260TVE-U washing machine, and for some reason it won't do the spin cycle? at the end of the programme in says something like "UNB END". Any ideas?
Hi Mate;
Just had the exact same problem with the spin cylec and now its stopped completely, I was getting ERR 7 on the display, its telling you that there is something wrong with the motor.checked the motor and found that one of the Carbon Brushes was sticking/Stuck, Just 2 phillips head screws and the carbon brush is out, mine had a bit of melted plastic/casing snagging the Carbon brush, i just jusd a bit of fine sand paper to clean the Brush, put it all back together and lo and behold everyting works.
Hope this helps
Listed below are all the error codes:
Display messages:
Err1: Error message. Door is not properly shut 20s after program is started.
Correction: Shut the door properly.
Err2: Error message. Drainage error, water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for blockage. If error still exists, please contact the maintenance personnel.
Err3: Error message. Temperature sensor is not properly connected or damaged (display at the end of a program).
Correction: Contact the maintenance personnel.
Err4: Error message. The heater may be broken or the desired temperature is not met within the specified time due to an overloaded laundry (display at the end of a program).
Correction: Reduce the load and restart, or contact the maintenance personnel.
Err5: Error message. The required water level is not reached within 10 min, or the water level exceeds the protection value.
Correction: Check to see if the tap is turned on and the water pressure is correct. If error still exists, contact the maintenance personnel.
Err6: Error message. Motor speed error. It may be not properly connected or damaged.
Err7: Error message. Motor overheat protection or is damaged.
Err8: Error message. Water level exceeds protection value.
Regards
Bull
Jul 29, 2008 | Washing Machines
My Haier HW-C1460TVE-U washing machine was installed this morning did the empty cycle first then did a load of towels worked perfectly did another wash Err code Unb came up. Got sprit level and checked...
Have been to one of these machines today. UNB will still show even if the machine is empty. I think the feedback amplifier on the main PCB is at fault. If I have any luck with it I'll post another message
Jun 29, 2008 | Washing Machines
Washing Machines Logo
400 people viewed this question
Top Washing Machines Experts
