Question about Toshiba TheaterWide 50HP16 50 in. Plasma HDTV
Toshiba 50hp66 power light cycles will not turn on
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is pointing towards the scaler board. I was wondering if anyone has a confirmed fix for this or the 50hp16. Thanks, Nick
4 Suggested Answers
premtech
  • 934 Answers
SOURCE: Toshiba 50HP16 - no picture or sound.
Drummer,
Check mosfet at Q104 2SK2370 which will sub to an Nte2970 on the main power supply. Leakage can cause cycling but my bet is on the scaler board also. You say you have +5v at pin 11 of CP3201 and 3.3 at pin 2 of IC3804 - and all the troubleshooting charts and schematics I've reviewed suggest replacing the scaler board, Toshiba p/n# 72784101 and unfortunately they're about $240.00 dollars. But that sounds like the problem to me...
Bill
Posted on Dec 01, 2007
Old Drummer
  • 5 Answers
SOURCE: Toshiba 50HP16 No Power
I bought a Scaler board from someone on eBay but it did not fix the unit however I'm not sure the replacement was not a dud. I planned to send the board to PTS Corp but haven't yet. I have sent other boards to PTS wit good success. http://www.ptscorp.com/tech_support.html
Posted on Dec 30, 2008
dspider
  • 30 Answers
SOURCE: I have a Toshiba 50hp66 that the power light
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Posted on Aug 11, 2010
Toshiba 50hp66 Plasma repeats power sequence without turning on
A case of which came first the chicken or the egg, Power supply board may be the issue or the sustain board--have you looked for the usual bad caps on the power board?
Dec 03, 2012 | Toshiba 50HP66 50 in. Plasma Television
My tv suddenly wont turn on. it powers on by itself then immediately goes off then starts the same cycle again. I checked the capacitors and non of them are blown. any ideas. when the tv tries to start, i...
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
or
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here.
Aug 20, 2011 | Toshiba 50HP66 50 in. Plasma Television
50HP66 50 in. Plasma Television: i have red dots/shadowing on my tv...
I got the red dots really bad on my toshiba 50hp66 after an hour or two of watching tv. I found out that if you open up the tv in the back on the left you will find two adjustment pots labelled Vsc and Vy. I took a sharpie and marked where the factory defaults were first. Then I adjusted the Vy pot down a little bit and the red spots were gone! My tv looks great again!
May 16, 2010 | Toshiba 50HP66 50 in. Plasma Television
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba 50hp66 The tv shuts off and the red light
Sounds like a system failure - one of the controller boards may have gone bad. If the unit is still under warranty, contact Toshiba for warranty service. Otherwise you will need to contact one of the authorized service centers or your local TV repair guy to arrange for repair.
Nov 08, 2009 | Toshiba 50HP66 50 in. Plasma Television
My Toshiba 50HP66 will not turn on. It powers up like it is trying to turn on, then it makes a clicking sound and turns off. It will do this over and over until I unplug it.
Most TVs have a "Protection Mode" that turns the unit off when it detects a failed part inside the tv.
The most likely the tv has a power supply related problem. I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 28, 2009 | Toshiba 50HP66 50 in. Plasma Television
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
50HP66 Plasma TV wont turn on fully. I hit the power button. It goes green for like 3-5 seconds then go back to red off light. It continues this untill I unplug the TV.
did you get your tv fixed? have same problem last night...a loud click and then blank screen and just tries to turn on, can you email at res116@comcast.net
May 18, 2008 | Toshiba Televison & Video
Toshiba 50HP66 plasma
It can be the power supply, and or a short on one of the boards that is causing the set to go in to protect mode.
The service tech will swap out boards to find the problem. He will leave the board installed that does the fix.
Be prepaired, these sets are rather expensive to service.
Jerry G.
Apr 21, 2008 | Toshiba 50HP66 50 in. Plasma Television
Open Questions:
Toshiba TheaterWide 50HP16 50 in. Plasma HDTV Logo
88 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
