Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Pairing Sky+ Remote with Panasonic Viera remote
Can you tell me how I do this please? Much appreciated.
  • 27 Answers
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Posted on Apr 08, 2009
How to connect remote control to panasonic hdc mdh1 "?"
is this a sky remote? or a multi remote?
if its a sky:
http://helpforum.sky.com/t5/Archived-Discussions/Help-remote-code-for-Panasonic-Viera-TX-L42E5B-needed/td-p/361937
Jul 03, 2014 | GE Televison & Video
My original remote for Panasonic Viera no longer works. I have bouht a universal remote but do not know the panasonic code to put into it. please help
each brand unversal will have its own seperate code for panasonics. I would recommemd getting the original remote which wont require any programming. You can get the remote from www.tvrepairworld.com
Jan 02, 2013 | Panasonic VIERA TX-26LMD70 26 in. LCD TV
Sky remote code for panasonic viera TH-50PX70BA
[0051]
678 254 278 154 242 368 191 302 128 544 241 065 395
379 389 103 576 136 650 278 136 678 254 065 650
Jun 10, 2012 | Panasonic Viera TH-42PX80U Plasma TV
Need sky code for my panasonic viera
Hello
Sky remote codes for Panasonic TV are:
Panasonic
Panasonic
TX2151 TX2151T TXW28R4 TC2153R TXBW28D20P TX25MD3 TX21M1T-BK TX28DK1
278
Panasonic
TX215521
136
Panasonic
TX21512 TX2153T TX29AD2DP TX32PK2 TX32PK20 TX28PK3 TC21L3PX TX25X1DL TX25MD1B TX28X1 TX32PK1 TX2132V TXW28R4DP TX33A1G TX25MD1/M TX2151TBH TX21ND4 TX21CK1 32DTZ TX21V2BC TX21MD41 TX47PT1 TX25MK1 TXW32R 4DA TX28PL10 TX28LD16B TX29A3 TX25W2 TX32PL10 TX36D3DT TX25MD3 TX32TF1 TX28PS12 32PD30 TH42PA20B TX32PB50 TX32T5S TX29AD1DP TX32PS1 TX28DTX1
678
Panasonic
TX2482 TX21612 TX2471 TX25T2K TX21T1
254
Panasonic
TUDSB20
065
Panasonic
TX32PLI
650
OK.
Oct 08, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have a Panasonic Viera TV (with Sky+ plugged into it). All of a sudden it has stopped responding to either the Sky remote to which it was synced or the actual TV remote. It displays no error, just a...
I know it sounds simple, but have you tried turning it off at the wall for 3 minutes? This can sometimes resolve a coruption on the motherboard's memory, by resetting it.
If this doesn't work can you provide more information on the TV, such as the model number.
Hope this helps.
TV_Doctors
Jan 03, 2011 | Panasonic Televison & Video
I am looking for the codes to run my t.v. my t.v. brand is Panasonic and the universal remote I am using is RCA RCU800MS 8-Device Universal Remote. I lost the code book and was wondering if I could get the...
The codes I have are: Code 003 for Panasonic TV
Code 054 for Panasonic TV
Code 055 for Panasonic TV
Code 062 for Panasonic TV
Code 109 for Panasonic TV
Code 130 for Panasonic TV
Code 170 for Panasonic TV
Code 214 for Panasonic TV
Code 350 for Panasonic TV
Code 351 for Panasonic TV
The codes can be looked up here: http://remotefinder.rca.com/default.aspx?site=rca for most RCA remotes. Please note these codes will work for TVs released at least 6 months before the remote was programmed.
I hope this helps.
Nov 19, 2010 | RCA Televison & Video
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Sky + code
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0051
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
May 09, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Remote control code
3. Press tv again
Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
Code
Hi
I have a Panasonic viera TX-32LMD70 TV and a Panasonic
remote control. I also have sky and I cant use the sky remote
control for the sound when I try to change it asking for the code
and I do not have any for the panasonic remote how came with the TV when I bouth it. Can you help me.
Thank you
Gill Plimmer
Aug 18, 2008 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
748 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
