Question about Toshiba TP50H60 50" Rear Projection Television
Toshiba tp50h60 convergence
My TV would not power on. I changed out the convergence IC's. Now TV turns on, but convergence is out of alignment. I went to fix it in the menu and I don''t have any of the cross hairs show up. Everything else in the menu appears, the Red and Blue color options, and the screen with 1-9 showing. But no cross hairs to line up
  • ramon49
    ramon49 May 11, 2010
    Did you change all three and the green coils?
    Scholar:
  • 27 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Posted on Jun 14, 2010
When I turn on my toshiba tp4880a tv it turns off immediately and then I have to unplug and plug it back in several times to get it to power on
You are probably experiencing primary stages of a convergence IC failure. This repair is composed of replacing two output IC's and alignment. Standard repair is around $350
Bill W
integrityhomeworx.com
Mar 23, 2011 | Toshiba 57H81 57" Rear Projection...
50H13 Red Convergence Problem
I do wish people like troylove11 would stop giving advice on things they obviously know very little about. The Toshiba projection sets never have loose connections on the convergence IC's, and there are never bad resistors in those sets. There is no separate convergence board and there are no adjustments on any boards. The convergence adjustments are done electronically, through the remote in the service mode. Also, moving or bumping a projection set cannot cause a solder joint to crack loose. Your set has 2 large convergence IC's and one of them has burned out. This is very common in projection sets. Do not attempt to enter the service mode to make adjustments, because you will only be messing up the correct settings and when the new IC is installed, the colors will still be way out of alignment. Replacing a convergence IC is a very simple thing for an experienced tech, and it is well worth getting the set fixed. If your set uses the STK392-010 IC's, it is probably a good idea to go ahead and replace both IC's with the newer, upgraded STK392-150 IC's. If you have not changed the convergence settings, the picture will return to normal once the IC is replaced and very little realignment will be necessary. When I do a housecall for a set like that it takes about an hour and a half and I charge $150, but shops in your area will vary so ask around.
Sep 07, 2007 | Toshiba 50H13 50" Rear Projection...
Picture is completely out of alignment, went to do
It means the convergence IC gave up already ang needs a replacement. And also check the 5A picofuse in the power supply.
Dec 28, 2009 | Mitsubishi WS-65869 65" Rear Projection...
1998 TOSHIBA TP50H60 THE COLOR WON'T MATCH, LOOKS LIKE 3-D MOVIE WITHOUT THE GLASSES. IF YOU HIT THE SIDE OF TV, SOMETIMES GOES BACK TO NORMAL.
Sounds like a classic convergence problem. most likely bad connections on the bottom of the stk's. If a repairman were to do this for you it would run $300-$500, if you were to do it yourself it would run less than $100. Bad connection on the vertical IC can cause something simular to this as well. If you need more help or would like to fix it on your own please let me know
Tim
Sep 10, 2008 | Televison & Video
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Panasonic PT-53WX42
convergence IC bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Toshiba TP61F80 Projection TV
Check power supply for open micro fuse{s}-- If the fuses for the convergence circuits B+ are open,replace convergence IC,s and fuse devices.Then perform re-alignment in servicer mode.test run.Don't forget--PVAT! solder any/all bad connections.
Sep 28, 2007 | Toshiba TP61F80 61 in. Rear Projection...
Replacing the STK392-110'S
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://www.eserviceinfo.com/
Jan 08, 2007 | Toshiba TP50H60 50" Rear Projection...
Convergence problems
Nov 20, 2006 | Toshiba TP50H60 50" Rear Projection...
Televison & Video Logo
327 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
