Question about HP PSC 1510 All-In-One InkJet Printer
Stupid scanner! I press the scan button and it scans like a good little scanner then when I check the results, most of the time, it's just a close up of like a quarter of the page. The last time I tried scans 1,2,5 all turned out that way but not 3 and 4 which worked perfectly. Somebody help me please!
In this case try scanning via the desktop shortcut and preferably use gray-scale. After the scan in TIFF format, you could then render to jpeg type format.
Posted on Oct 15, 2007
SOURCE:
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
Getting scanner to scan
Make sure that the keypad isn't locked. See if there is a little key in the display. If yes, then hold down the lock key to unlock the keypad. Next, hit 'scan' and you will have to select a group to scan, so press the #1 or #2 button IF you have frequencies loaded into it. Can you press the WX button to hear the weather? Let me know. Good luck.
Apr 20, 2014 | Radio Shack Pro-95 Handheld Scanner
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
How do you stop a test page from printing every time the printer is turned on?
Welcome to FixYa!
Here's how to stop the unwanted print out of test pages.
1. Let the printer print the test page.
2. Place the printed test page in the scanner face down and wait for 10 seconds.
3. Press the scan button of the printer to scan the printed test page.
Make sure that the printer scanned the document properly.
That's it. Every time you install a new cartridge, the printer aligns the print cartridge as well as testing/aligning the scanner.
Note: Try to look at the top of the test page, it should have instructions to place it in the scanner.
I hope that this will help.
Thank you for using FixYa.
Jas247
Mar 07, 2011 | HP PSC 1315 All-In-One InkJet Printer
How to scan a photo?
These are the simple steps in using your hp scanner to scan pictures.
  • 1
    Start the computer and the scanner by pressing the power buttons.
  • 2
    Open the scanner and place the photo facedown on the bed. Close the scanner.
  • 3
    Click "Start" on the desktop task bar. Click "Programs" and then "HP Solution Center." Alternately, you can double-click the HP Solution Center icon if it's on your desktop.
  • Read more: How to Scan Photos Using HP Scanning Software ' eHow.com http://www.ehow.com/how_4515665_scan-photos-using-hp-scanning.html#ixzz1BkrQvbkc I hope this works for you. Good Luck! Mongkey "Understanding explains better..."
    Jan 22, 2011 | HP Office Equipment & Supplies
    How to scan, can use the feeder, or I have to scan page by page?
    Follow these steps to scan:
    •1
    Open the software program that came from your scanner.
    •2
    Lift the lid of your scanner, place photo on scanner bed and close the lid.
    •3
    Press the "Scan" button on the scanner or in your scanner software program.
    •4
    Preview the scanned photo on your computer screen and check that the borders are straight and even. Rescan the photo if you make changes.
    Sep 01, 2010 | Brother MFC 7840W Printer
    Why does my HP 1500 prints a test page every time I begin touse it???
    HI
    As soon as the printer prints the test page or alignment page place it on the scanner glass (Place the printed side down) before that Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
    After That press scan on the printer button panel it will resolve your issue.
    Try to double check it by turning it off and turning the printer back on after 2 minute's. If still the problem exists call HP Total Care 800 - 474 - 6836 if you are from US/Canada.
    ) Lift the lid of the product.
    2) Place the top of alignment page face down in the right front corner of the glass.
    3) Place the alignment page face down
    4) Close the lid.
    5) Press the Start Scan button.
    6) The Power button light will blink during the alignment process.
    7) After the Power button light stops blinking, alignment is complete.
    Aug 04, 2010 | HP Office Equipment & Supplies
    Uniden scanner will not scan
    Mine did the same thing. I installed ARC-XT-PRO software from BuTel, deleted all factory programming from the scanner, then downloaded/programmed everything I wanted from RadioReference.com. The BCD396XT and BCD996XT are fantastic scanners, but you have to beat them into submission before they will do what you want them to.
    Aug 02, 2009 | Uniden BC244CLT Base Scanner
    Don't know how to set scanner for multiple page scan into single pdf file
    The supplied Canon software is horrible, but it can be done!
    Launch ScanGearStarter, choose advanced tab and click preferences button, then select scan tab.
    Untick box "Automatically quit ScanGear....." then click ok.
    (This box being ticked totally prevents multipage single file scanning).
    Now choose simple mode tab, select the document type, dpi and document size.
    Now click the green "Multi Scan" button, place the document on the scanner glas and press next in the new window.
    The page will be scanned and the ScanGear window will return, just click "Multi Scan" again and place next document, press next. Keep repeating until all pages are scanned, then close the ScanGear window.
    This will bring up a third window showing thumbnails of each page, any of these pages can be deselected if required.
    The other important step is to choose from the pull down list Saved as Type: "MultiPagePDF".
    Choose the location for saving the file and click save.
    Hallelujah! .......stupid software.
    Jun 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    Brother Scanner, scans the page but prints black and vertical
    I called technical support for this issue previously with my brother mfc. It would only do this during color scanning. b&w scanning was just fine. The tech support put me through resetting the reference point of the scanner through a series of button pressing and closing and opening the paper feeder. I kept gettting the same lousy results. Then they determined that the scanner module needs replacing and I needed to take to the nearest service center.
    Dec 23, 2008 | Brother MFC-8640D Printer
    HP PSC 1510 All-In-One InkJet Printer Logo
    Clive
    Clive
    Thomas F. Schneider
