Question about Audio Technica Audio-Technica DR-VX1 Professional Microphone
Mic problem again...
Hi i recently contacted you with a problem with my audio-techinica dr-vx1 mic. I went out and bought another one and its doing the exact same thing! Im really at a loss for the cause of this problem. your help would be appreciated
  • 58 Answers
SOURCE: want work
You need to fine tune (to connect wirelessly) ur wireless mic to your wireless receiver unit. Put a fresh battery to ur Mic then power-up ur receiver unit, find the right channel for both unit.
Posted on Aug 11, 2007
  • 71 Answers
SOURCE: i have a dr-vx1 mic and have hooked it to a
I use the same mic w/edirol FA64 and Macbook pro. Try a different mic, if still faint, check system settings to use m-audio mic in.
Posted on Jul 24, 2009
  • 417 Answers
SOURCE: Audio Technica PRO-35: need wiring diagram for mic end
If you feel the shield goes to the middle, try red on one terminal and white on the other. If not, reverse it.
If it's labeled on the circuit 1, pin 2, pin 3, then pin 1 is usually ground, pin 2 is hot (red), and pin 3 is cold.
Posted on Apr 15, 2010
  • 26 Answers
SOURCE: i have a macbook pro,
Sounds like a phantom power issue. Good Luck, Cody J.
Posted on Dec 17, 2010
SOURCE: hi i am using the
This mic has a 10db pad or attenuator switch near the bottom of the barrel... make sure you haven't accidentally engaged it.
If that's not.... it try changing the lead. Also the power supply on your preamp could be failing.
These are a few cheap things to try before spending money for fixing.
Posted on Jan 09, 2011
  • 3400 Answers
SOURCE: i have several microphones, one's Audio
You might consider sending it in to Audio technica for repair. They're really customer oriented and alot of times they'll repair and or replace for just cost of shipping. Try contacting them directly.
Posted on Apr 30, 2011
0 characters
1 Points
How do i connect it? does it need a sound card to be connected? thanks..
The Roland DR-80C Microphone is an condenser microphone which requires phantom power or a 12V power supply.. Usually this is supplied by connecting the mic to a microphone preamp or an audio mixer that has an 12v mic/line input.
May 28, 2011 | Roland DR-80C Microphone
Will phantom power damage my audio technica DR-VX1 microphones?
No it will not. The reason for the word phantom is that it does not affect microphones that don't need it (apart from some types of ribbon mics)
Jan 04, 2011 | Audio Technica Audio-Technica DR-VX1...
Dr-vx1 microphone was dropped now it does not sound like its suppose to how do I fix it?
Open the unit and look for damage. If nothing is obviously wrong, the element probably has fatal damage.
Jul 18, 2010 | Audio Technica Audio-Technica DR-VX1...
Mic to PC
This mic is a condenser type microphone. It needs phantom power (48v) to operate. Might want to buy a USB mic preamplifier box, like an M-Audio product, which will provide phantom power, xlr/1/4 inch inputs and USB output.
May 23, 2010 | Behringer C-3 Professional Microphone
Roland DR-30 Mic - how do you use it?
If the mic is a dynamic microphone, you would need a small mixer. The line input is a high level input and the mic level needs to be boosed. We here at Pro Line Music have small mixers 215-736-8055
Dec 26, 2009 | Roland DR-30 Microphone
DR-VX1, No sound comes out, fresh out of the box
There is a setting on your computer that will give you a Mic boost. Here is how you set it. Double click on the little speaker icon on your taskbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure the microphone box is checked then click ok. Now a window will open that will show your microphone recording level. You can turn that recording level up using that slider. To give your Mic a boost click on the Advanced button at the bottom of the Recording Control Window. Then at the bottom of the next Window check the Mic Boost box. This should give your Mic a little more kick and you can lower the mic recording level using the slider if your recordings become distorted.. Good luck with this and I hope I have been helpful.
Mar 17, 2009 | Digital Reference DR-VX1 Consumer...
No volume from Audio-Technica ATM410
the mic you mention is a dynamic mic, and needs a mic preamp to get decent levels for most computer sound inputs
Nov 26, 2007 | Microphones
Want work
Aug 05, 2007 | Audio Technica Audio-Technica DR2600...
Not acknowleging
just make sure that you are hocking up you mic in the right plugs int he back of the computer. just match the colors. you need also to go to the audio panel (it is called volume icon)and check in for mic and make sure that is not muted there. if you use the mic for msn for instance, you need to go to tools, audio and video options and just follow dircetions.good luck
Feb 25, 2007 | Logitech (980240-0403) Microphone
Audio Technica Audio-Technica DR-VX1 Professional Microphone Logo
24 people viewed this question
Top Audio Technica Microphones Experts
Ben Armstrong
Are you an Audio Technica Microphone Expert? Answer questions, earn points and help others
