Question about EuroTech EWC177 Front Load Washer / Dryer
Euro Tech Washer Front Load
I had repair men in my basement(due to a Flood) and they put heavy boxes on top of the Washer , now I have cracks all ove the 3 sides of the top of the washer unit
Euro Tech 12 Model #: EWF 172W
20032411325-010477001-01 01
120V --- 60 HZ
Washer 9S xS listed
Can this be fixed or replaced ? What is the process and cost of this?
you may contact me : Mrs. G. Conlin (416) 696-2565 or (416) 428-5918 cell . If you can look into this matter as soon as possible. My insurance company is waiting for
an answer.
Sincerely yours,
Mrs. Giselle Lupovici Conlin
3 Suggested Answers
SOURCE: euro tech front load washing machine
YOU CANNOT RESET ERROR CODES ON APPLIANCES BY MERELY UNPLUGGING THEM FOR 5 MINUTES. MOST MANUFACTURERS RECOMMEND AT LEAST 30 MINUTES IF YOU GOING TO ATTEMPT TO TRY TO RESET A COMPUTERIZED CONTROL BOARD. STOP POSTING THIS INFORMATION INCORRECTLY.
Posted on Sep 30, 2008
MNfisherman
  • 11896 Answers
SOURCE: My euro tech washer door
Go to partselect . com or daysappliance. They will have the part, the diagram, and more. Awesome sites. They new seal should come with the adhesive as well. After your rip off the old one, clean the surface really well before applying new adhesive and seal.
Posted on Sep 19, 2010
Why wont the motor on a top load roper washer work after a flood
If the motor was submerged in water it's probably shot. They aren't made to function during and after exposure to water.
May 20, 2014 | Roper RAS8445KQ Top Load Washer
Basement got about 4 inches of water. Washer will turn on, but does not function.
Sounds like the Motor Controller on the left side of this Pic may be the issue. The Drain Pump/Pressure switch is on the left side of the Pic. I feel the drain pump may not work after the basement flood. You can get into Service Mode and try to turn it on from the Console once the machine is dried out.
Aug 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
F/ll blinking is there a switch in case of flood?
If you had a flood and any water got into bottom of machine, you have probably shorted out a motor control board. These board are either in the lower back right or front left corner bottom. A qualified service tech should be called to do this repair.
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Why no bleach?
Simply put. It's not needed in this machine. The hole idea of a front load washer (most euro models anyway) is the old "mechanical wash" idea. Hence no need for bleach, which is solely for use in a "chemical wash" machine, i.e. top load washers.
Sep 17, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Hello I have a front loader & I saw a 'UE' msg can you tell me what that is u can email me @ rsb9747@gmail.com Thanks
Code UE is an unbalanced load error, usually shown when there is a very small load where the machine cannot redistribute the weight to balance it (because there isn't enough clothes to go around). I suppose it could also occur in a larger load where there are heavy items mixed with larger lighter items and the drum is full - here again, the machine wouldn't be able to balance the load due to the drum being full.
In some cases, a more serious problem exists requiring service, as in the case of either a loose sensor (easy to repair by a service tech) or a bad control board (easy to repair by a tech but you have to wait on parts).
good luck
Jun 20, 2009 | LG WM-2277HW Front Load Washer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Washer vibrates during spin cycle
Front loaders have to be situated on solid flooring such as a basement or they will vibrate.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Violent shaking
You urgently need to find a competant repairman. It sounds like the bearings on the drum are dangerously worn or the straps/springs/blocks balancing the drum has some issues. Hope I was some help.
Aug 19, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Flood Damage?
Do error is a Door open error code.. but if it is closed it could be a faulty door lock or a control.. check to see if you can open the door..hope this helps let me know.
Aug 25, 2007 | Maytag Neptune MAH5500B Front Load Washer
Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Jun 22, 2007 | Bosch WFMC 3200 Front Load Washer
EuroTech EWC177 Front Load Washer / Dryer Logo
75 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
