Question about Goldstar Microwave Ovens
MODEL: MV1526W EVERYTHING WORKS BUT NO HEAT AND A HUMMING SOUND LOUDER THAN NORMAL ALSO A BURNING ELECTRICAL SMELL , COVER OF UNIT IS OFF WHEN IN OPERATION YOU CAN SEE A LITTLE SMOKE FROM DIODE AND CAPACITOR CONECTION AREA.
  • anumaeda Dec 29, 2008
    what can i check t repair it my self , I already have the cover off and removed the diode and capacitor where the burnt smell and smoke was comming from .
    Master:
  • 479 Answers
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
____________________________
for how to check out the parts just click the word components in blue.
thanks.
Posted on Dec 29, 2008
  • 15,935 Answers
You either have a bad magnetron tube or a shorted high voltage rectifier. Seek professional repair.
  • 3 more comments
  • blueextc3221
    blueextc3221 Dec 29, 2008
    Check the thermal cutoffs for both the oven and the magnetron. The thermal cutoffs are little disc shaped devices with a wire connecting the two of them. Remove a lead and set the VOM to RX1. Probe the terminals and look for a reading of zero. If not, replace. Check both thermal cutoffs. If these are OK, check the capacitor and diode as described above. The magnetron or transformer could also be bad, but they need to be serviced by a professional.
  • blueextc3221
    Check the voltage at the outlet supplying power. If it is lower than 115 volts, there is a problem with your electrical service or breaker. A bad turntable motor may also be the cause. To check it, turn the microwave over onto its top. Remove the bottom grill. Set the VOM to RX1 and remove one lead from the motor terminals. Probe the terminals. If the reading is infinity, then replace the motor.
  • blueextc3221
    Test the capacitor by removing the leads and setting the VOM to RX100. Probe the terminals. The reading should start in the low ohms and increase toward infinity. Reverse the probes and re-test. The reading should do the same thing. If not, it's bad. To test the diode, disconnect the diode from both the appliance and the capacitor. With the VOM set to RX100, probe the wires. Then reverse the probes and read again. You should get infinity for one reading and low ohms for the other reading. If not, replace
  • blueextc3221
    The U. S. Consumer Product Safety Commission
    (CPSC) warns against do-it-yourself repairs of
    microwave ovens. Each year, on average, four
    people die from electrocution trying to repair their
    microwave ovens. Microwave ovens use high
    voltage which makes it particularly hazardous for
    consumers to remove the cover and touch electrical
    parts. The possibility for electrical shock
    from a microwave oven still exists even after the
    oven is disconnected from the power source.
    Should certain internal devices fail, even
    unplugged ovens can cause serious injury.
  • blueextc3221
    Removing the cover of your microwave oven
    and touching an electrical part can kill you.
    Have a professional repair your microwave oven.
  • 151 Answers
I think this problem was posted before. Discontinue use and take to licensed technician.
  • djxtreme979
    djxtreme979 Dec 29, 2008
    I cannot offer advice on this topic as I am not licensed. You have a serious electrical failure with your product. My advice is to seek professional "licensed" assistance.
It makes a sound when on and smells like burning
If it's an arcing sound, there may be grease or food particles on or behind the waveguide cover or in the area of the turntable motor.
Otherwise, it's likely to be a failing high voltage part:
- A sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound. Usually it will not heat is this is the case.
- A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but if this were the case, it would not heat.
- Sometimes a high voltage transformer will cause a loud hum and burning smell, too.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your specific symptoms.
Let us know which of the examples we gave seems to be closest to the sound you're experiencing.
Jan 29, 2010 | GE JVM1650 1000 Watts Microwave Oven
Oven humms and doesn't heat anymore....
if you say 'seems like common problem with this model' then just replace it and get another good model.
it gives peace in long run.
May 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Noise while not running
don;t worry;
all you need to do is lubricate the fan bearings with light machine oil and make sure the fan is not hitting anything
Apr 18, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
My goldstar mv1501B won't heat anything. What' wrong?
everything works except the heating system what shell i do?
Mar 25, 2009 | Goldstar MV-1501 Microwave Oven
GE Spacemaker XL1800 does not heat. All other functions appear to be working normally, the light comes on and the turntable functions. When turned on, it makes a humming noise slightly louder than normal,...
Possible bad heating element, You should remove the cover of the unit and look at the heating element with the power off. Until you get your problem resolved I would recommend not to even turn it on due to the fact that you are unsure what is going on and you smelt some burnt smell. Just for safety until you fine the problem
Feb 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1440BD Won't Heat
If it making a louder than normal humming or grunting sound when operating, than it's a sure bet it's the MAG.
Jun 09, 2008 | Microwave Ovens
Humming sound and burning smell.
I had the same problem. I replaced the wave guide/cover and everything was fine. It is a piece of cardboard inside the microwave that covers the magnetron. Mine was saturated with grease, and was damaged by the fire. If yours is still intact and not that greasy, You can carefully remove it. Clean both it and the area inside the cavity with an alcohol based cleaner. If there is so much as a pin hole in the cover it will need to be replace. When grease somehow gets behind the cover an arc is formed which causes the problem.
Dec 12, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
93 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
