Question about PANDIGITAL 6.0-Inch Digital Picture Frame w/Black Wood Frame (892235000623)
Unable to view slideshow
I have copied images from camera memory card onto internal memory - or at least I think I have. In the directions it states to depress the "setup" button on the file to bring up the on-screen display - when I do the display is the start scheduled on/off, clock display and photo date/time stamp. This is not the information that is displayed in the information sheet which shows copy file etc. Instead I have used the buttons on top of the from and when the image that I want to save I press the enter button and it appears to be saved. However, when I go to play slide show as per instructions - "Set Up the Slideshow for All Photos" I am unable to view the slide show. Any suggestions. I have been trying to contact the 1-800-715-5354 for customer service but line is always busy. Thanks so much!
5 Suggested Answers
  • 3 Answers
SOURCE: Not all jpeg images will load on 7'' Pandigital Photo Frame
I was having a problem too with my Smartparts frame. All the pics were from the same camera but some of the vertical (portrait) orientation shots wouldn't show right. Just a bunch of thin colored lines. After some phone calls I did try to "resize" the photos to the "resolution" of my frame (had to look that up too). My frame is 640 width by 480 high. So I took a shot and changed all the goofy photos to 480 width (since they were vertical) and let Photoshop change the the other number. Low and behold the buggers are showing up fine now. Well on to my next problem - focusing with the new D90. I think that one is going to be more challenging yet. Hope this helps you out.
Posted on Dec 30, 2008
SOURCE: dpf-1411 locked in slideshow
To fix the freezing problem, all you have to do is change the file names to basic numbers. If you have long file names, it causes the pictures to freeze up. Change the names, and the problem stops!
Posted on Dec 31, 2008
SOURCE: Unable to bring up the setup screen for display option
can't get the frame to cut off and start back up to show the setup program
Posted on Apr 02, 2009
  • 157 Answers
SOURCE: new xD M+ card won't work in the digital photo frame.
Alot of the digital photo frames will only display images up to a certain resolution. There is a good chance your camera resolution is too high for the photo frame. try change the settings on your camera to 3mp or so and take a few photos and see if they will display.
Posted on Jun 16, 2009
  • 121 Answers
SOURCE: How do i put my photos on slideshow
you can only do that with the remote control;
Posted on Oct 28, 2009
Intova internal memory photos
The internal memory for Sport HD II is not meant for storing and downloading images/videos. It is used for the cameras operating software. Unfortunately there is no function in the camera to download images stored in the internal memory. However, you can delete these files by going to the view images screen by pressing the OK button in either video or photo mode and then pressing the menu button and following the prompts. As stated in our user manual, Sport HD II must be used with a properly installed micro SD card up to 32GB size maximum and class 6 or 10 speed required. If you need further assistance, please contact Intova directly by phone, (808) 837-0074 or email shallyn@intova.net
Thank you,
Intova
May 30, 2014 | Intova Sport HD II Waterproof Action...
Tip
If your camera will not read or transfer internal images on to memory card
When your camera will not transfer images onto memory card this is often because the image storage has been set to 'Auto'. You need to set it back to internal memory temporarily to allow you to copy the images over to the card. Once you have done this you can set the camera back to 'Auto' and this will reset the system and you will now have access to all of the images on the card.
This particular procedure works with all cameras but the steps outlined here are for Kodak in particular.
Please follow these steps;
1) Insert the card
2) Turn the camera to Auto
3) Press review - "reading memory card"
4) Press menu and scroll down to image storage and press ok
5) Select Internal Memory and press OK
6) Scroll down to Copy - Copy Pictures to memory card
7) Scroll down to ALL and press OK - you should see "Copying" displayed
8) When the screen goes back to the main menu - Scroll to Image storage again and select Auto - OK - "Reading memory card"
You should now be able to see the pictures from your internal memory saved onto your memory card and your camera is once again ready to use.
Hope this helps. Please do register your vote using the Yes/No buttons below to reflect the helpfulness of this Tip.
on Dec 22, 2009 | Cameras
I can't view images on Internal memory when SD card is inserted.
Put the card in, then select "Copy" from the playback menu. You will then be given the option of copying individual images or all of them. See the instructions beginning on page 99 of the manual: http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s5700_s700_s5800_s800_manual_01.pdf
Jul 11, 2013 | Cameras
Hi there I have pictures saved on the camera, not the memory card. How can I transfer them to the memory card so that I can put them onto my computer etc? The camera is samsung s760. Thank you.
Most of the Cameras will be having an option 'COPY' to transfer images from internal memory to memory card. If the camera does not have the option, remove the Memory card from the CAmera and connect it to computer to view the pictures from internal memory on the Computer.
Thanks for understanding..
Please let m know if you require further assistance. Thanks
Jan 05, 2011 | Cameras
Camera keeps saying internal memory is full, even after putting a
Your internal memory is separate from your memory card. Think of it as two folders, the internal memory cannot be removed, and the memory card is one you can take with you. You can put new memory cards in it all day, the internal memory will still have pictures in it. You may wish to consider copying all internal memory to the memory card. To do this, make sure your camera has a memory card in it. View pictures on your internal memory, then from the menu option select 'copy all images to external memory.' In doing this, all of your photos will be moved, you can then clean out your internal memory by deleting everything/formatting it. :)
Apr 04, 2010 | Kodak EasyShare Z812 IS Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    How do i switch off internal memory
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
      After you have done so I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 17, 2010 | Kodak EasyShare C613 Digital Camera
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
      1. Menu
      2. Cam settings
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    Can't access photos
    Insert the card...go into the menu and scroll to "copy". Follow the directions for copying the internal memory to the memory card.
    Nov 21, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
    Need to put Pictures from Camera onto Memory Card
    Hi there. Here is how you do it. Go into the menu and navigate to the Copy screen. Choose an option. One is to copy pictures from the camera's internal memory to the SD card, and the other is copy from the SD card to the camera's internal memory. Then press OK. On the next screen, you have two option choices, either copy all images, or selected images. Hope that helps.
    Feb 14, 2009 | Kodak EasyShare C330 Digital Camera
    PANDIGITAL 6.0-Inch Digital Picture Frame w/Black Wood Frame (892235000623) Logo
    74 people viewed this question
    Top PANDIGITAL Photography Experts
    LP
    Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
