Question about Dual XDVD8265 Car Video Player
Dual XDVD8265 I've installed this model in my car and it worked GREAT for roughly a week and a half. I pulled the unit out to hook up my amplifier, did not touch any of the other wiring, then put it back in place in my dash. When I turned the car on again my screen was all white. Everything audio still works. I've tried the reset button to no avail. Also tried to use the manual to guess approximately where the buttons would be on the touchscreen to try and reset the video settings to factory. Nothing works. I checked all connections in the back..everything seems fine. I've also completely removed and reinstalled the unit. NO avail. I bought this product off ebay and I'm concerned about how well the customer service will be to replace or repair the unit. Are there any tricks of the trade to fix the screen?
  • Jordan407 Dec 28, 2008
    i have the same problem i hooked it up and the screen is white, the audio works but there is no display. what did u do?
    Top Expert:
  • Dual Master
  • 82,322 Answers
You must have damaged the screen somehow, no other explanation.
Posted on Mar 17, 2017
hogan doan
  • 227 Answers
SOURCE: DUAL XDVD8181 car unit - motorized TFT screen won't come out!
Open it again and check the ribbon cable for cracks, the one that get drag in and out every time it open and close. Because it is a defect for Pioneer too, and Pioneer would replace it free. Goodluck.
Posted on Mar 07, 2008
  • 3 Answers
SOURCE: screen white and touch screen not working
some wire is probably touching
Posted on Apr 28, 2008
Sphynkter
  • 221 Answers
SOURCE: THERE IS NOT 2 RCA HOOK UPS FOR THE SUBS HOW KAN I HOOK UP MY AMP SO MY 2 12S WILL HIT
If there's only a single sub-out RCA cable, you have two options. The amp may have a manual switch that puts it in Mono mode, in which case you only use 1 of the 2 RCA jacks. The other option is to go get an RCA splitter. This will take your single sub-out cable and feed the exact same signal to both left/right of your amp. Either way, you get the same result. If the 1200W amp is for your sub(s) only, you should set the high-pass filter and subsonic filters to help your bass "hit harder" and cleaner.
Posted on May 17, 2009
  • 87 Answers
SOURCE: trying to identify the correct wires
Parking brake wire can be grounded. If you need to turn the barking brake on and off, install a toggle switch in line with the ground.
Posted on Jun 02, 2009
SOURCE: dual xdvd8183 screen doesnt come out
hey i have a dual xdvd 8183 and my screen doent pop out but it plays and you an see that the screen is playing inside can anyone help
Posted on Jul 19, 2009
Zx750.1 kicker amp cutting out
Also check your fuses. there may be a fuse for the in-tank fuse.
Jan 05, 2014 | Kicker (ZX750.1) Car Audio Amplifier
The radio keeps going back to old stations
Do you have the yellow wire connected to a constant power source. The yellow wire controls the memory and has to have 12v going to it even with the key off.
Nov 30, 2011 | Dual XDVD8265 Car Video Player
Amp want power off
Hello
If your Dual Car Amp refuese to switch ON check the following.
+12V wire is not connected or incorrect voltage.
REM wire is not connected or incorrect voltage.
Ground wire is not connected.
Fuse(s) are blown.
If the fuse blows repeatedly, check whether the +ve voltage wire touche the chasis of the vehicle. If it is OK, the fault is with the univt itself. That is, the output of the unit has a short. Check for any output IC failure. OK.
May 11, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
I hooked up a dual mosfet 4 channel amp and i am not getting power to it. the way it is setup is from battery to 100 amp fuse, from fuse to inside cab of truck then to 500 K farad, Split from + to power on...
Bad ground sounds like you may have paint or undercoating stopping the ground from making good contact or unhook the remote wire and run a small wire from the main power to the remote hook up and see if it works ...... May have a faulty remote
Apr 25, 2011 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Sony amp 1000w
Check the wiring of the speakers (both inside the box and between the box and the amp). It sounds like one speaker is wired incorrectly at one connection point.
Sep 09, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
How do i bypass the parking brake switch in order for my video to play
get a toggle switch hook to a ground then to the e-brake wire flip on and off 3 times 4th time leave on worked for me
Mar 19, 2008 | Dual XDVD8265 Car Video Player
P2002 Amp is weak
Please provide details on the head unit, sub box, and sub box location of both your old setup and your neighbor's new setup.
Feb 26, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Car audio amp or speakers bad?
If you know how to use a multimeter, you can test the amp this way:
-unhook the subs
-hook up a cheapie speaker you know for sure works to one of the channels
-unhook the audio inputs
-turn the amp on
-set your meter to VDC
-put the positive probe on the inside of the input connector, being sure you make contact with th inner contact
-take the negative probe and tap it on the outside of the connector
What you are doing is sending a low voltage (replicating an audio signal) into the amp audio circuit and allowing the amp to amplify it. If the amp makes the speaker pop each time you strike the probe, the amp is working.
There is an inherent problem with band passes. The naturally filter out high frequencies like a crossover, including distortion, so it makes it hard to hear when the subs begin to protest.
Nov 22, 2007 | Dual XAF-460 Car Audio Amplifier
Car Audio & Video Logo
127 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
