Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
ASSEMBLING BRUSH HOLDER TO STAY IN PLACE
THE TOURQUOISE PIECE THAT HOLDS THE BRUSHED IN PLACE DOES NOT STAY IN THE MACHINE. HOW DO YOU GET IT TO STAY IN. BOTH PIECES ARE SEPERATE PIECES AND WHEN I CLEANED LAST TIME I TOOK THE PIECE THAT THE BRUSHES ATTACH TO OUT AND NOW I DON'T KNOW HOW TO GET IT TO STAY IN PLACE. WITHOUT IT STAYING IN PLACE THE BRUSHES FALL OUT OF THE MACHINE AND DO NOT STAY IN PLACE.
  • Nancy Greenside Apr 29, 2007
    I MEANT TO SAY HOLDS THE BRUSHES IN PLACE, INSTEAD OF BRUSHED IN PLACE.
  • 625 Answers
Try thehooverstore this online site has your machine with exploded diagrams. you should be able to figure out how it goes together
Posted on Sep 22, 2007
How do I replace the motor brushes in an Oreck xl upright vacuum? I have the motor out, but I can't figure out what holds the long brass brush holder in the plastic motor housing
im holding an oreck motor as i write this and to the right of where the plastic casing that holds the brush there is a small round plastic piece sticking up, around that should be a metal coil which slips over the plastic piece the theres a piece of the metal wire on one end is the coil the other end is like a hook which hooks into the plastic housing piece causing a sort of resistance, like a spring action. good luck
Nov 27, 2017 | Oreck Vacuums
My brush piece is corroded
El8807 - call customer service at 800-896-9756 push 1 or 2, then push 3. They sent me a new replacement, no cost. Need your Serial Number so they know date of purchase. 5 year warranty. Best vacuum ever, better than dyson and cheaper by 100%, but the brush stopped working after getting tangled. Called support and they replaced. Great. Cheers!!!
Apr 21, 2014 | Electrolux EL8807A Precision BrushRoll...
Brush does not rotate when switch is on
Hi, mine did the same thing last week. I took off the end cap that holds the brush in place, and noticed inside the cap a piece was broken. Got a new end cap from Dyson, and it works fine now. Also, roller will not work in the upright position. You should recline the handle, then turn the vacuum on and make sure the brush switch is on. Hope that helps.
Jul 09, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
The brush roller will not engage although the belts look good. Hoover upright windtunnel.
Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly.
Sep 12, 2010 | Hoover Vacuums
Cannot get the brush to rotate when vacuuming
Sep 12, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
THE BRUSH ISN'T TURNING, EVERYTHING ELSE IS WORKING.
Sep 12, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson has lost suction and the brushes do not rotate
Sounds like a broken belt may have been pulled up into the machine. Plan on replacing the belt and cleaning the beater brush. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt if needed, making sure the belt is put on properly.
Sep 11, 2010 | Dyson DC14 All floors Bagless Upright...
Changing a drive belt
Turn the unit upside down and on each side of the roller brush is a red piece of plastic with screws remove and take off roller then you will see the belt drive stem place around stem and on roller and pop back in, Reassemble. Steve
Jun 06, 2010 | Bissell Powersteamer 1694 Upright Vacuum
Need to replace red clips that hold rolling brush on 7901 Proheat
On the bottom of the machine, near the belt access area,
is a red retainer plate that holds the black brush arm and
brush in place. Using a Phillips head screwdriver remove the
screw that holds the red retainer plate in place. p/n 5559113
Jul 12, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Dyson dc14
hi am i right to assume the belt is still in place ie in position around the drive wheel of motor? and you have removed the roller/brush only? and you now have difficulty re assembling the belt on brush and relocating brush into its holder ??
Oct 19, 2008 | Dyson DC14 All floors Bagless Upright...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
88 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
