Question about Maytag SAV365Z Top Load Washer
Maytag model# sav365zaww squeeks
I have a model# sav365zaww and it sqeels while spinning. It als throws water out during the first spin cycle. it drains the water out while spinning it shoot more water into the drum of clothes?
  • 179 Answers
Check your pump the bearings in your pump
could be going out this will cause the water not to be pumped out properly and will also cause a squeek
Posted on Dec 29, 2008
  •  Sherman
    Sherman Dec 30, 2008
    why is this inappropriate
A knocking noise during agitation wash cycle
could be a bad counter balance , u can remove the front panel and run a spin or wash cycle and listen to where its coming from so u don't have to replace all the balancers. on some models theres a heavy ceramic weight at bottom that at times goes bad and throws it off balance, just run it and look where noise is coming from
Jul 25, 2014 | Maytag Performa PAV2200
Sav365zaww skips the drain and spin cycle - sometimes
it could be that you have somthing stuck in the pump or outlet hose I went to a machine the other day and it had a intermitent fault like yours and it was a coin stuck in the drain hose on the pump when it washed in cold it was ok but when it was a hot wash it expanded the hose enough to allow the coin to flap up into the pump outlet hole hope this might help you
Dec 01, 2011 | Maytag SAV365ZAWW 3.3 cu.ft.
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Maytag atlantis washer mav6300aww drains water but does not spin
my maytag washer model #MAV6300AWW will not spin out during cycle but can turn it back to spin and will spin out
May 30, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Maytag SAV365Z Top Load Washer Logo
132 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
