Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
"Pop"...now oven doesn't work.
We were preheating the oven when we heard a "pop". Now the oven doesn't heat up. The stove top, oven light, 'element on' and 'hot surface' lights work, but nothing related to the oven work. The display for oven including clock is out as well. Any ideas?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 17 Answers
Do you have the fuses on the top of stove back??
Posted on Jan 13, 2017
  • 640 Answers
Power surge,,replace board
Posted on Dec 29, 2008
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    While cleaning oven I lifted bottom element heard a pop. Now neither the stove or oven will not come on. The indicator lights do not light up either.
    The "pop" was the sound of the heating element shorting to ground so naturally nothing works now.
    Jan 18, 2017 | Ovens
    Oven temp heats higher than set
    The control board is bad. One of the relays has fused and you will need to replace the control board.
    Jan 07, 2012 | General Ovens
    Frigidaire gallery stove, oven not working,
    Morison,
    The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
    May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Frigidaire oven will not light
    The control panel behind the knobs is the most likely problem.
    The heating element rarely fails.
    Apr 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    I was just preheating my GE JT950 oven and there was a loud "pop" sound from the top fan, and then smoke emanated from the oven. The circuit breaker in the home is fine, as no fuses were blown. Any advice
    bake element do pop when they burn out and some will act like a sparkler and burn and burn .. I would look for a bad spot in the element of the oven that you wer heating . mm
    Dec 03, 2009 | GE Profile JT952 Electric Double Oven
    Element blew in oven; now stove doesn't work....
    Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
    Sep 14, 2009 | Frigidaire Ovens
    Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
    733 people viewed this question
    Top Frigidaire Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    ashburton
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
