Question about Bernina Bernette Deco 600
Needle/Bobbin issues with Bernina Deco 600
While sewing with her Bernina Deco 600 my wife heard a loud pop and the machine locked up on her. After clearing the machine she tried again and it would sew for less than 30 seconds and then jam again.
I removed the bobbin cover and turned the machine by hand to observe the needle/bobbin operation. The needle is definitely contacting the bottom of the casing on about every other stroke and is coming down while the hook is about 180 degrees away. Also, the hook seems to brush against the needle as well.
I am not sure what proper timing looks like so I will need to know that as well. Please help me get the timing on this set properly.
Thanks,
Jim
  • livn4christ Jan 03, 2009
    This is exactly the information I was looking for. Thank you so much for you help.
  • 19 Answers
Jim!
Perfect phrasing of the question, you have all the lingo/parts down pat!
First make sure your new needle is straight, then check to make sure it lines up in the center of the hole in the stitch plate.
There is basically a 1/2 sheet of papers (we use the fine waxy sticker backing paper as our guages don't fit well .1mm! ) distance between the hook and the needle.
Rotate your hook so that it is aligned with the needle in the center position, there should be 2mm between the top of the needle eye and the bottom edge of the hook.
Posted on Jan 03, 2009
Is the bobbin supposed to move on the Bernette Deco 600?
Could you please let me know how you got this resolved. I just got this same machine and I am wondering the same thing...it just stopped picking up the bobbin and I have never really looked at it before that but the bobbin does not spin as well
Jul 21, 2014 | Bernina Bernette Deco 600
The bobbin will move only when the thread is being pulled. The problem with your machine is that the timing has missed aligned. It will need service. 99% of all sewing machine misalign due to continued use.
The machine jams
make sure the top thread isn't coming off the thread take up lever and also the sewing machine may need to be checked for a timing problem.
Aug 08, 2013 | Bernina Bernette Deco 600
Deco machine will not pick up bottom threat
try changing the needle--make sure the needle is the correct
one for the fabric being sewed
try rethread the machine top & bobbin--use every thread guide
clean under the needle plate & in the bobbin area for lint
it's also possible that the timing needs to be checked at a sewing
machine shop
Oct 03, 2012 | Bernina Bernette Deco 600
Deco will not pick up bottom threat
change needle
if these suggestions don't help then the sewing machine needs the
timing checked at a sewing machine shop
My Bernette Deco 600 is not picking up the bobbin thread. I have cleaned the machine and retreaded many times. The sensor thinks there is no tread on the bobbin. What can I do to resolve this problem?
At the very worst you may need to retime the machine if you have already checked that the needle is in the correct way round and is a good one, I can attach timing instructions if you email me drivewithken@blueyonder.co.uk
Nov 02, 2009 | Bernina Bernette Deco 600
Just got my used Bernina deco 650 from the shop. Tension off
The tensions are not calibrated properly. To get by, or if you do not want to take it back to the shop, just lower the upper tension a little at a time until it looks ok.
I have 25 years experience working on sewing machines
Jun 29, 2009 | Bernina Bernette Deco 600
Bernette Deco 600 makes loud noise after stitching
hi! there,
open needle plate if the shuttle race and the bobbins has been pull out that making noise,or accumulation of thread under bobbins, if nothing there, run machine and check if shuttle race and bobbins are moving,also with the needle if not,there are opening at the bottom of machine try to open if some gears are broken,or belt is slip.
if broken gears there a lot of parts before you can pull out gear, beside the timing order you cannot put back.this should be done by technician expert
in sewing machine.take this to service center.
cheers have a nice day just rate me.
Apr 09, 2009 | Bernina Bernette Deco 600
Bernina deco noise
See if drive belt is not running against the plastic body on right side.!
Nov 17, 2008 | Bernina Bernette Deco 600
Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
May 19, 2008 | Bernina Bernette Deco 600
Sewing Machines Logo
234 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
