Question about Brother HL 5250DN Laser Printer
Brother HL-5250 is printing a solid black page
Could this be a drum related issue?
  • 2,120 Answers
Yes. Remove and re-insert, look for bent contacts.
Posted on Dec 29, 2008
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
Brother HL-4070 printing out black whole page. Is this drum problem?
Try swapping the black and the magenta (red) cartridge.
This will not damage the printer and you can see if the toner or the drum is defective.
If you get a red page, drum
Black page, toner cartridge
Mar 26, 2010 | Brother HL-4070CDW Printer
I have a Brother HL-5250, drum light on, not printing
When the drum light is on solid, it's time for a new drum, if you have a new drum, just open the front door and hold the go button til all lights flash and the drum is reset. Press the go button 3 times and it will print a sheet showing the drum status.
Sep 15, 2009 | Brother HL 5250DN Laser Printer
Brother printer prints solid black on one side
This is caused by a faulty drum/charging circuit or laser unit. The drum is positively charged with static electricity and a laser draws the image onto the drum (changing the charge to negative) the toner is positively charged to it will adhere to the negatively charged image which is now on the drum. your problem is that the drum is either not being positively charged or the laser is charging the whole drum. There is a corona wire on the drum, remove the drum, sweep the corona wire (there will be a tab that moves left and right) and try it again. next step is to replace the drum. if you dont have a spare drum or one from another printer then it may be more cost effective to buy another printer as drums are quite expensive and it may not even be the problem.
Jun 16, 2009 | Brother HL-5240 Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Black horizontal lines in printout
Seems like the drum needs changing. This is the most common cause for print problems in these printers. If using the high yield TN 6600 toner then you need to change the drum every 3-4 toners. If using the low yield TN 6300 toner then the drum will need replacing every 6-7 toners. Hope this helps
Nov 16, 2008 | Brother HL 1440 Laser Printer
in laser printers, theres a charging corona wire that gives the paper a 600v positive charge which attracts the toner. once the paper hits the drum, a laser with a 600v negative charge is shot at the paper which discharges the paper and the toner isnt attracted to that area anymore.
either the laser is malfunctioning and not shooting a beam at the drum which would make all the toner go to the paper, or theres something wrong with the toner cartridge.
try going to the brother website and downloading the driver again (cheap and easy) and if that doesnt fix the problem, replace the cartridge, i know, not cheap. if neither fixes the problem, call the brother support line and see what they can do for you. maybe the warranty will cover the repair costs for you.
hope this helps.
Aug 24, 2008 | Brother HL 1230 Laser Printer
Printer is printing BLACK PAGES
Solution from brother
Jul 11, 2008 | Brother HL-2040 Laser Printer
HL 5250 dn
first you most clean the printer carefully then you most change the drum unit
Feb 28, 2008 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
112 people viewed this question
James Cagle
James Cagle
Jim Keysor
